That’s a support community for github itself, no affiliation with home-assistant. You also didn’t include any logs. Create your issue against home-assistant/core located here:
Please post logs in the issue after you update and the entity appears as unavailable.
I have a raspi 4 with zwavejs2mqtt and deconz running on it. HA is a VM in VMware connecting via the websocket. Every time I update HA it requires an updated version of zwavejs2mqtt which breaks my zwave devices. All of my devices are still connected to zwavejs2mqtt but they always show up as generic devices in HA. Even if I name them within zwavejs they still show as generic node 26 et cetera.
How can I do this so that all the devices retain their device names during an HA upgrade or zwavejs2mqtt upgrade?
On a side note - I have to keep them separate because the raspi 4 is located near the center of my house and provides the best experience this way.
Anyone having problem in restore backup on the fresh install HA Supervised? I forget about this during my recovery process after breaking changes. The link is basically unclickable.
I’m not sure if this is something that happened as a result of the 2021.11 update or the ZWave JS update from 0.1.45 to 0.1.46 (as I basically did both at the same time) but some of my Aeotec Multisensors are no longer updating the lux level, however motion etc are still updating fine.
I did not have the atomic-calendar-revive integration installed, I had it previously but it was removed some versions ago. Now after installing it again al my card in some of my views have returned.
After 2021.11.2 the BMW Connected integration doesn’t work anymore…
2021-11-09 22:02:13 ERROR (MainThread) [homeassistant.components.sensor] bmw_connected_drive: Error on device update!
File “/usr/src/homeassistant/homeassistant/helpers/entity_platform.py”, line 431, in _async_add_entity
await entity.async_device_update(warning=False)
File “/usr/src/homeassistant/homeassistant/helpers/entity.py”, line 651, in async_device_update
await task
File “/usr/local/lib/python3.9/concurrent/futures/thread.py”, line 52, in run
File “/usr/src/homeassistant/homeassistant/components/bmw_connected_drive/sensor.py”, line 528, in update
self._attr_native_value = getattr(vehicle_state, sensor_key).value
AttributeError: ‘NoneType’ object has no attribute ‘value’
2021-11-09 22:02:13 ERROR (MainThread) [homeassistant.components.binary_sensor] bmw_connected_drive: Error on device update!
await task
File “/usr/src/homeassistant/homeassistant/components/bmw_connected_drive/binary_sensor.py”, line 251, in update
self._attr_is_on = self.entity_description.value_fn(
File “/usr/src/homeassistant/homeassistant/components/bmw_connected_drive/binary_sensor.py”, line 102, in _is_vehicle_charging
extra_attributes[“charging_status”] = vehicle_state.charging_status.value
I would like to propose for one of the next releases the ability to separate Automations and Scripts into groups, for example all automations that involve lighting will be grouped in a group called Lighting. Since I have around 150 automations, this would help me a lot when searching for a certain automation or script.
Update: Two ZWave multisensors still not updating their temp or humidity values to HA. I updated ZWave JS to 0.1.47 and no improvement. Multiple HA restarts and device power cycles has not fixed them. Time for me to report it on GitHub
You may need to reinterview the device (select device from Configuration → Devices, then Re-interview under Device info). If that fails, delete it and then re-add.
@frenck Nice update! Really liking the new entity category feature. Previously, I used to just disable entities that are not controls so they don’t show up over HomeKit.
However… is it possible to define/override entity categories in the UI? I use zigbee2mqtt for a number of my devices, and looking at the docs, entity_category seems like something for the developer to implement. However, in my situation, I’m not sure if it’s going to be zigbee2mqtt’s job or MQTT’s job, and config switches are still showing up under “Controls” in the device’s pane:
