Yes have the same issue, i used the flash optin in an automation, and not working anymore.
Thats great news Petro, thank you looking forward for the implementationš
Itās a straight name swap see this PR:
Thanks for the update; some nice features to test. But I have a problem as well
I use 2 Hue touch buttons that are build into wall switches. These are the last ones to use my Hue bridge as everything else is migrated to ZHA.
The Hue touch buttons are part of an automation that tests if a specific event comes in via the Hue integration.
alias: Hue Touch Keuken Scenes
description: Process scene commands coming from Hue Touch
- platform: event
event_type: hue_event
event_data:
unique_id: 00:00:00:00:00:45:0e:ff-f2
condition: []
- choose:
# switch left top
- conditions:
- condition: template
value_template: "{{trigger.event.data.event == 16}}"
sequence:
- service: scene.turn_on
data_template:
entity_id: scene.woonkamer_cosy
- service: logbook.log
message: Button linksboven
after updating to Home Assistant 2021.12.1 events do not come in any more. Have restarted the system, removed and readded the integration. Not sure what else I can do?
Edit: added correct HA version
Weāll it showed that I had to
change the unique_id to device_id
change ātrigger.event.data.event == 16ā to ātrigger.event.data.subtype == 2ā
So probably something changed to the unique_id (no longer unique) and the trigger events changed label and number.
Hue_event output:
Event 18 fired 23:00:
"event_type": "hue_event",
"data": {
"id": "hue_tap_switch_2_button",
"device_id": "25ee5fa89a0b3476e093c87eb6f12741",
"unique_id": "479d9056-f300-474e-b618-d7f15f82b81c",
"type": "initial_press",
"subtype": 2
"origin": "LOCAL",
"time_fired": "2021-12-13T22:00:28.562153+00:00",
"context": {
"id": "69919057de08fe1fa0eedad2a9c4bd5a",
"parent_id": null,
"user_id": null
The subtype numbers now are 1, 2, 3 and 4. They used the be the event numbers 16, 17, 34 and 18. Probably missed all of that in the breaking changes.
Hue transition times are still not working on my end with 12.1. Everything still behaving like 12.0.
Any others experiencing this?
Using:
Call service
Light.turn_off
I have a problem where I updated Hass core to 2021.12, but now I have two pending updates that when I click āShowā there is a black screen and I canāt do anything. My Hass Supervisor is still at 6.6ā¦
Can anyone help? I tried to restart my RPI/Hassio but this still happens.
clear your browser cache
Edit: SOLVED!
It was caused by an own copy of the rest integration which wasnāt compatible with 2021.12 anymore. Removing my custom component solved the problem.
When checking my config after the update Iām getting the following error:
Platform error notify.rest - cannot import name 'HTTP_BAD_REQUEST' from 'homeassistant.const' (/usr/src/homeassistant/homeassistant/const.py)
What could I do to solve this?
Additionally in the logfile Iām getting
Platform error: notify
File "/usr/src/homeassistant/homeassistant/config.py", line 887, in async_process_component_config
platform = p_integration.get_platform(domain)
File "/usr/src/homeassistant/homeassistant/loader.py", line 530, in get_platform
cache[full_name] = self._import_platform(platform_name)
File "/usr/src/homeassistant/homeassistant/loader.py", line 535, in _import_platform
return importlib.import_module(f"{self.pkg_path}.{platform_name}")
File "/usr/local/lib/python3.9/importlib/__init__.py", line 127, in import_module
return _bootstrap._gcd_import(name[level:], package, level)
File "<frozen importlib._bootstrap>", line 1030, in _gcd_import
File "<frozen importlib._bootstrap>", line 1007, in _find_and_load
File "<frozen importlib._bootstrap>", line 986, in _find_and_load_unlocked
File "<frozen importlib._bootstrap>", line 680, in _load_unlocked
File "<frozen importlib._bootstrap_external>", line 850, in exec_module
File "<frozen importlib._bootstrap>", line 228, in _call_with_frames_removed
File "/config/custom_components/rest/notify.py", line 15, in <module>
from homeassistant.const import (
ImportError: cannot import name 'HTTP_BAD_REQUEST' from 'homeassistant.const' (/usr/src/homeassistant/homeassistant/const.py)
I canāt seem to find any docu on what type of devices and entitites that will show up on the area card. Did some testing now with my living room. It seems to only find lights, even though reciever and other media devices are assigned to that area.
Am I missing something here?
Hello.
Iām using 2 separate themes, one is set in my profile, another one as a theme for every lovelace tab. One of the differences is card-background-color
variable, tabs use theme with more transparent color, this way cards blend better to the gradient page background, while popups with more info keep more opaque color from main theme to maintain text readability.
After this update theme set for tabs doesnāt respect card-background-color
variable anymore, instead it uses the value from main theme. This behavior isnāt consistent though, as some cards added from HACS (e.g. mini-graph-card
) still use the right value, which results in different backgrounds for different cards.
Hereās a screenshot from 2021.11:
ā¦and from 2021.12:
Expand main theme code
synthwave-mod:
# text
primary-text-color: '#eee'
secondary-text-color: '#eeeeeeca'
text-primary-color: '#e4ddd4'
disabled-text-color: '#acacac'
# main interface colors
primary-color: '#f650b9'
primary-background-color: '#3a3c55'
dark-primary-color: '#f650b9'
light-primary-color: '#323149'
accent-color: '#f650b9'
divider-color: '#49549539'
paper-dialog-button-color: '#fff'
switch-unchecked-button-color: '#fff'
# iron-icon-fill-color: '#fff'
yellow: '#ffcc00'
green: '#72f1b8cc'
# background and sidebar
card-background-color: '#3f486de6'
app-header-background-color: 'var(--primary-background-color)'
paper-card-background-color: 'none'
secondary-background-color: 'none' # behind the cards on state
ha-card-border-radius: '8px'
# sidebar menu
sidebar-text-color: 'var(--secondary-text-color)'
# sidebar-background-color: 'var(--paper-listbox-background-color)' # backward compatible with existing themes
sidebar-icon-color: 'var(--secondary-text-color)'
sidebar-selected-text-color: 'var(--primary-text-color)'
sidebar-selected-icon-color: 'var(--primary-text-color)'
# mwc - for some reason it's buttons
mdc-theme-primary: 'var(--dark-primary-color)'
mdc-theme-secondary: 'var(--dark-primary-color)'
# shadows
ha-card-box-shadow: '0'
# icons
paper-item-icon-color: 'var(--secondary-text-color)' # Off
paper-item-icon-active-color: 'var(--accent-color)' # On
# switches
toggle-button-color: 'var(--primary-color)'
# --toggle-button-unchecked-color: 'var(--accent-color)'
paper-toggle-button-checked-button-color: 'var(--primary-text-color)' # Knob On
paper-toggle-button-checked-bar-color: 'var(--dark-primary-color)' # Background On
switch-checked-color: 'var(--dark-primary-color)' # Background On
paper-toggle-button-unchecked-button-color: 'var(--primary-text-color)' # Knob Off
paper-toggle-button-unchecked-bar-color: 'var(--disabled-text-color)' # Background Off
# Sliders
slider-color: 'var(--primary-color)'
slider-secondary-color: 'var(--light-primary-color)'
slider-bar-color: 'var(--disabled-text-color)'
paper-slider-knob-color: 'var(--accent-color)'
paper-slider-knob-start-color: 'var(--accent-color)'
paper-slider-pin-color: 'var(--accent-color)'
paper-slider-active-color: 'var(--dark-primary-color)'
# paper-slider-container-color: 'linear-gradient(var(--primary-background-color), var(--secondary-background-color)) no-repeat'
paper-slider-secondary-color: 'var(--secondary-background-color)'
paper-slider-disabled-active-color: 'var(--disabled-text-color)'
paper-slider-disabled-secondary-color: 'var(--disabled-text-color)'
switch-unchecked-track-color: 'var(--primary-text-color)'
# radio buttons
paper-radio-button-checked-color: 'var(--paper-toggle-button-checked-button-color)'
paper-radio-button-unchecked-color: 'var(--paper-toggle-button-unchecked-button-color)'
# other
state-icon-color: 'var(--green)'
table-row-background-color: 'var(--card-background-color)'
table-row-alternative-background-color: 'var(--card-background-color)'
# UI
paper-card-header-color: 'var(--text-primary-color)' # Title in settings
# Left Menu
paper-listbox-background-color: 'var(--light-primary-color)' # Background
sidebar-background-color: 'var(--light-primary-color)'
# bar-card compatibility
# https://github.com/custom-cards/bar-card
custom-bar-card-color: 'var(--accent-color)'
# fix dropdown background
material-background-color: 'var(--light-primary-color)'
# Scrollbar
scrollbar-thumb-color: 'var(--divider-color)'
# simple-thermostat buttons
# https://github.com/nervetattoo/simple-thermostat
st-mode-background: 'var(--primary-background-color)'
st-mode-active-background: 'var(--dark-primary-color)'
### SYNTAX MOD ###
# NORD
codemirror-keyword: "#81A1C1"
codemirror-operator: "#81A1C1"
codemirror-variable: "#d8dee9"
codemirror-variable-2: "#d8dee9"
codemirror-variable-3: "#d8dee9"
codemirror-builtin: "#81A1C1"
codemirror-atom: "#b48ead"
codemirror-number: "#b48ead"
codemirror-def: "#8FBCBB"
codemirror-string: "#A3BE8C"
codemirror-string-2: "#A3BE8C"
codemirror-comment: "#bc9262"
codemirror-tag: "#bf616a"
codemirror-meta: "#81A1C1"
codemirror-attribute: "#8FBCBB"
codemirror-property: "#8FBCBB"
codemirror-qualifier: "#d8dee9"
codemirror-type: "#d8dee9"
Expand tabs theme code
synthwave-mod-lovelace:
# text
primary-background-color: 'linear-gradient(3deg, #363553, #6f617e, #689ac1)'
yellow: '#ffcc00'
green: '#72f1b8cc'
card-background-color: '#3f486d77'
# sidebar menu
# shadows
# icons
# switches
# Sliders
# radio buttons
# other
# UI
# Left Menu
# Scrollbar
same here. did you solve?
I have to say Iām going to buck the trend now. Having used the new configuration UI for three days I found myself forgetting it had changed. Just like when MS moved from Windows 10 to 11 or other such examples.
It takes time but I honestly believe it was done for the good reasons - there are things Iāll be feeding back on sure and hopefully they go towards improving the next incremental change. Just felt it worth saying as some comments very very negative and must crush those who work on it.
I have the same problem with my Xiaomi Philips Zhirui downlights. As far as I can see on Github (https://github.com/rytilahti/python-miio/pulls) they are working on it.
Exact same issue with the lumi.gateway.v3
Only the illuminance is working
Well done to everyone involved with this release. The upgrade went smoothly for me other than having to reinstall the WebRTC Cmaera integration (simple fix).
I like the new UI. Sure it will take a little while to navigate as quickly as I did with in the old version but that isnāt a bad thing, all change takes getting used to. It seems there are far too many people on here that canāt handle change!
Is anyone else having trouble with the Evil Genius Labs integration? Iām trying to add my Fibonacci 256, and when I enter in its IP address, I get a āFailed to connectā error. I both my Fibonacci and my HA Blue are on an IoT VLAN, and the HA Blue is able to ping my Fibonacci, so Iām not sure why itās not able to connect.
Dont forget the Quick Bar. If you want fast that is the way. Press c
and a couple of related letters and all commands and navigation options are right there.
I think the duplicate server controls are due to my panel redirects.
