Hi, I’m running version: 2021.12.2.
Since my last restart I experience issues starting the system.
Doing “ha core check” I’m receiving the message below. Does anybody has an idea which part of the config to check?
Error: Testing configuration at /config
INFO:homeassistant.helpers.storage:Migrating core.device_registry storage from 1.2 to 1.3
Fatal error while loading config: 'int' object is not iterable
Failed config
General Errors:
- 'int' object is not iterable
Successful config (partial)
After updating to 12.3, all of my media_player (I use Chromecast Audio) states report ‘idle’ while the state should report ‘playing’, resulting in the situation that my automation flows do not work anymore.
After restoring to 12.1, everything is working again. I can’t test if 12.2 also has the issue as I don’t have a backup of 12.2.
Hello there,
I think since the 2021.12 update , I can’t SSH out from within scripts and automations …
I use “ssh and web terminal” addon (but even with Terminal & SSH addon) .
When I launch an ssh command from the terminal of “ssh and web terminal” , it works but when it’s whtin a script (same command) or an automation , it’s simply not working …
Any idea ?
Playing a file or streaming to a media player (both working on 2021.11.5) doesn’t work but the media player state shows ‘playing.’ What’s annoying is that controlling the media player (e.g. stopping it) doesn’t work either.
I’m not a big fan of the new Configuration UI but I’m happy to wait to see how it develops.
HOWEVER…
How are non admin users supposed to change their settings in the Companion App?
(Or is that by design? Because I could understand if it were but it would also be very annoying.)
Since upgrade from 2021.11.3, all my zwave events automations are broken: Got error 'TemplateError: str: Use of 'device_id' is not supported in limited templates' when setting up triggers for some light double click down
