2021.12: New configuration menu, the button entity, and gorgeous area cards!
need to specify Andriod or iOS or are they called differently?
as mentioned 2 comments above yoursā€¦HA core and not the mobile apps.
Suddenly also the ā€œvolume_setā€ service is brokenā€¦
This is what i can see in the log:
Error executing service: <ServiceCall media_player.volume_set (c:22f001f9e13158937236415ef241318e): entity_id=all, volume=0.6>
Weird, I was using this ever since I upgraded to zwave JS a few versions ago up to 2021.11.3 until 2021.12.
If this is not supported, is there another way to trigger on zwave event of a specific device? Hardcoding the device_id is not very friendly unfortunately.
I could put it in a condition, but it is not really clean either.
And you have to chose between one or another suboptimal build
you can vote for making HA more modular in terms of deployment. Not that it will resolve all issues.But likely would help a lot
Just noticed with the 2021.12 release that the TP-Link Kasa Smart integration creates two switch entities for every plug that has a lamp. For the plug I use to turn my Christmas tree on and off, the first entity is named switch.christmas_tree and the second entity is switch.christmas_tree_led. This did not happen with 2021.11 or earlier.
On the device page for this plug, switch.christmas_tree is listed under Controls and switch.christmas_tree_led is listed under Configuration. Both entities turn the light on or off.
As far as I can tell, the integration is adding the switch.X_led entity based on icon selected in the Kasa app as I have two plugs that used for battery chargers and there are no switch.X_led entries for those plugs. So itā€™s only a lamp or light that has the switch.X_led entity added.
I canā€™t find anything about this in the documentation or in the release notes as to the change or purpose. I donā€™t appreciate the integration assuming that the lamp plugged into the plug is an led - because at least two of the lamps arenā€™t leds.
My two TP-Link smart plugs donā€™t control lamps, and donā€™t have any lamp-like icon associated with them.
But I checked, and yes, I have the _led entities there now, too. Likewise, some previous release changed the name of the ā€œconsumptionā€ entities, but I figured that out and changed everything over to the new one.
I agree that these kinds of changes need to be better communicated.
Hello @CaptTom and @VincentClement1
This change to Tp-Link/Kasa is there a few releases now (.9 or .10 I think) and was documented. Itā€™s not a change in .12 so is not mentioned here. Maybe worth a read of the older release notes/blogs before jumping into posting, particularly if youā€™re not just upgrading one version number.
The ā€œ_ledā€ entity for the plugs does pretty much what it suggestsā€¦it controls the LED light on the plug and can turn this on/off :+1:t2:
oh sorry, got mixed up with a different comment.
Thanks but doesnā€™t seems to bring the solution.
Just tested with an VM and my backup before updating from 2021.12.1 to 2021.12.2. Everythingā€™s fine before doing the update. After ā€œha core checkā€ came up with the error.
Unfortunately I canā€™t downgrade easily.
Thanks for the tip!
Just the fact that the last updates, within a few days immediately two, three, four more updates are delivered, but clearly shows that there is a problem with the quality and reliability.
Apart from that, the documentation is simply bad. Especially when it comes to the impact of new features or changes on the previous configuration or hardware.
Contact. The. Author.
Is python 3.8.6 supported by HA core 2021.12?
You can always help by joining the effort in making things better like everyone else.
Yes Iā€™m having the same issue. Latest upgrade didnā€™t help, still doing it
Is it me or there seems to be inconsistency with the Entities UI card in this new release?
Previously: Any toggle in entities card are treated the same across mobile and desktop: a toggle.
Now: Tapping Automation and Remote entities toggle opens up the more-info card on mobile, itā€™s the old toggle behaviour on desktop.
There is no text in Configuration section, in Hebrew translation.
7 posts were merged into an existing topic: Helping with trigger variables & inputs
Iā€™ve noticed this also.
Same for me - media stop stopped working.
