I have several xiaomi devices and almost all of them are unavailable after update to 2021.12.x
Iām not sure if this has already been reported or not, updates are not showing up in the supervisor panel anymore even days after the release, the only way to update is to use the terminal
ha core update ...
Updates were consolidated to the configuration page. Thatās where they will show up. At the top of the page.
Not really consistent, which confuses users.
See in this case I have an update for glances showing up in the configuration.
And if I go to supervisor panel, I see it there too.
But the same is no longer true for Home Assistant Core Update.
Note that, at this point I canāt even check if core update showed up in configuration page, because Iām already updated to the latest, but I suppose it did.
Core would show up there if there was an update. You can see it on my screenshot.
EDIT: It doesnāt show up on the supervisor addon page that doesnāt make sense. Addon page shows addons. It just used to be on that page because there was no where else to put it. Now thereās a place to put it. Addons themselves show when they have an update. The info page on core / supervisor also show that. They just donāt have a nice little highlight.
Thanks, that makes sense
Should it perhaps also show up in /hassio/system
with the ability to update from there?
Just a suggestion.
The goal was the opposite (to make the behavior especially with the shown cursors more consistent), but that unfortunately introduced some side effects that are already fixed and will be in 2021.12.4.
The translations themselves are handled by the community (see https://developers.home-assistant.io/docs/translations/). However, if some translations are missing there should still be the English ones as fallback I think. Is the page showing no text at all?
After upgrading from 2021.11.5 to 2021.12.3 media_player is not working properly:
following script
play_pause_music:
alias: Musik play/pause
icon: mdi:play-pause
sequence:
- service: media_player.media_play_pause
entity_id: media_player.kinderzimmer
leads to following exception
Logger: homeassistant.components.script.play_pause_music
Source: components/cast/media_player.py:419
Integration: Skript (documentation, issues)
First occurred: 22:25:21 (3 occurrences)
Last logged: 22:29:11
Musik play/pause: Error executing script. Unexpected error for call_service at pos 1: Namespace urn:x-cast:com.google.cast.media is not supported by running application.
File "/usr/src/homeassistant/homeassistant/helpers/script.py", line 381, in _async_step
await getattr(self, handler)()
File "/usr/src/homeassistant/homeassistant/helpers/script.py", line 584, in _async_call_service_step
await service_task
File "/usr/src/homeassistant/homeassistant/core.py", line 1495, in async_call
task.result()
File "/usr/src/homeassistant/homeassistant/core.py", line 1530, in _execute_service
await handler.job.target(service_call)
File "/usr/src/homeassistant/homeassistant/helpers/entity_component.py", line 209, in handle_service
await self.hass.helpers.service.entity_service_call(
File "/usr/src/homeassistant/homeassistant/helpers/service.py", line 663, in entity_service_call
future.result() # pop exception if have
File "/usr/src/homeassistant/homeassistant/helpers/entity.py", line 896, in async_request_call
await coro
File "/usr/src/homeassistant/homeassistant/helpers/service.py", line 700, in _handle_entity_call
await result
File "/usr/src/homeassistant/homeassistant/components/media_player/__init__.py", line 877, in async_media_play_pause
await self.async_media_play()
File "/usr/src/homeassistant/homeassistant/components/media_player/__init__.py", line 670, in async_media_play
await self.hass.async_add_executor_job(self.media_play)
File "/usr/local/lib/python3.9/concurrent/futures/thread.py", line 52, in run
File "/usr/src/homeassistant/homeassistant/components/cast/media_player.py", line 419, in media_play
media_controller.play()
File "/usr/local/lib/python3.9/site-packages/pychromecast/controllers/media.py", line 410, in play
self._send_command({MESSAGE_TYPE: TYPE_PLAY})
File "/usr/local/lib/python3.9/site-packages/pychromecast/controllers/media.py", line 371, in _send_command
self.send_message(command, inc_session_id=True)
File "/usr/local/lib/python3.9/site-packages/pychromecast/controllers/__init__.py", line 87, in send_message
raise UnsupportedNamespace(
pychromecast.error.UnsupportedNamespace: Namespace urn:x-cast:com.google.cast.media is not supported by running application.
Am I the only one with this kind of exception? I would be grateful if someone could help
No you are not the only one. Read the thread
only for Alexa?
Thanks for this update. Great job !
For me, after the update, I notice that all my switch sensor (Ikea Tradfri & Aqara) are disappeared from the Entities list. Only, the Battery Level entities for these device are there.
I use the Deconz add-on with the recommended installation (HA OS). I also notice that the events, like click on button switch, are received by node-red add-on.
Please let me know if do you have the same behaviour and if you find how to fix it.
Did you read the Release Notes to look for any behaviour changes? Especially Breaking Changes? That is recommended standard practice before performing any updates.
I suspect if you read this thread you may find others that had similar issues and possibly how to update your configuraiton.
the problem for xiaomi miio has not yet been resolved in Release 2021.12.4?
What issues? My integration is working perfectly.
there is nothing in the release for 2021.12.4 that mentions miio, so thats probably why
Release 2021.12.4 Ā· home-assistant/core (github.com)
did someone having this problem? I seems to see 2 update, one for home-assistant core and one for addon ESP Home. So I decided to upgrade HA Core first. Upon upgrade ESP Home seems to lost its update, so any idea?
Did anyone update HA OS to Version 2021.12.4 ?
I tried to update and I get an error:
21-12-21 09:50:46 ERROR (SyncWorker_4) [supervisor.docker.interface] Canāt install ghcr.io/home-assistant/qemux86-64-homeassistant:2021.12.4: 404 Client Error for http+docker://localhost/v1.41/images/ghcr.io/home-assistant/qemux86-64-homeassistant:2021.12.4/json: Not Found (āno such image: ghcr.io/home-assistant/qemux86-64-homeassistant:2021.12.4: No such image: ghcr.io/home-assistant/qemux86-64-homeassistant:2021.12.4ā)
21-12-21 09:50:46 WARNING (MainThread) [supervisor.homeassistant.core] Updating Home Assistant image failed
It happens to me on Core and Supervised install too so I used the HA OS VM method.
Something is really wrong.
Upgrade worked fine for me (RPi4 though). The qemux86-64 version however also seems to be online for me, so that should work.
