This bricked my entire installation on my Raspberry Pi 4. I clicked update last night, and the system never came back online.
How do I revert to the old version?
Restore the backup you made before updating.
I’ve got a backup, of course. But I can’t even get the device to start so that I can access it. It just keeps telling me the connection is refused.
Can you connect via SSH?
If you can get via SSH, check the logs before restoring backup. There were a number of breaking changes, might be just a small config change is required to be compatible with the latest version.
This was mine
And after reboot back to under 30 %
OK, we’ll see. I had a really well functioning Z-Wave system and I’m worried that this just wiped out everything.
tts not working here (ha supervised). Only works on the google media card filling the text manually (i dont use Nabu Casa).
What xiaomi devices are you thinking of? Most of them are zigbee devices that work very well in HA. At least with deConz and a Conbee stick.
There are, however some BLE (Bluetooth Low Energy) ones that need to be quite close to a RPi or an esphome device collecting and forwarding them. Some of those can be quite tricky to talk to,
If you just updated, nothing with your zwave changed. It’s best to create a separate post with the errors from you logs. I noticed that tensorflow caused my system to hang just the other day. I’ve since removed it. Your best option is to go through the list of breaking changes, Look at your logs and verify that they didn’t impact you. And I’d like to be clear: There are no breaking zwave changes, this update simply contains another path for zwave that is 100% separate from the current zwave integration
Oh wow, I totally overlooked this in the release notes. Glad I read this thread!
So has anyone made a transition from @upsert’s Lutron Caseta Pro custom component to the new Pico support via the built-in integration? If so, how well is it working?
The custom component has been so reliable that I’m reluctant to switch prematurely.
I think there are a few things that people are not understanding about the new Z-Wave JS implementation. How I summarize it, and others may have different input, is:
My (way more than) $0.02 on the recurring questions that keep popping up.
i had trouble with the upgrade, in the night a made a clean “install” with raspberry pi 4 32bit image and recovered a backup. but in the morning i hat troubles again.
now i plugged in the network cable - now all works fine or ok.
something changed with the wifi…
TADO - Hi guys.
The tado hot water power sensor used to be off and only on when the hot water was actually on heating up the boiler.
Since 2021.2 and the new binary sensors, the hot water power sensor is now saying its on all the time.
I thought the overlay may be the answer but its not.
What sensor can I use to tell when the actual hot water is heating the water ?
Martyn
I think that they are being pretty clear here. The message I took away is that if you are starting out, it is better to start with ZWaveJS than the other two, because it is under very rapid development, whereas the other two are stalling out. That seems reasonable. They are also saying that they are working on a way to make the transition smoother, which tells me to wait a bit before transitioning over.
Funny enough, I just started using zwave a couple of weeks ago and had to decide which path to take from the options. I wish I had waited until now, but, since I have only a few devices the transition is pretty painless to ZwaveJS. If someone has a bunch of devices, you are right: it is better to wait, and there is no hurry.
Good work guys.
But, this version doesn’t work within my environment, although I’m not using special stuff, only deconz and some other core addons.
Reverting back to 2021.01.5 !
Besides having to rename 60+ instances, the migration is not what’s concerning. An added bonus is that half my stuff is no longer showing, so that gives me less to rename
Just updated ands moved from openzwave beta to Zwave-JS and, after struggling with a not-recognized device.
It was queried, updated and configured in no time.
And it is overall blazingly fast, too.
Keep going people!
Still wondering why it isn’t called Z-Wave WS … isn’t the main difference it now communicates over websocket.
TADO - hey guys, anybody else having problems with Tado not taking the climate.set_temperature commands? I already deleted and added the integration but it’s still not working. Sensors are working fine
