hmm nothing has worked for my GFs phone… update app, enabled an extra sensor… disabled enabled the missing sensors, still the same
The new “official” VLC intergration is really lacking in information, no information in the documentation on how to find the password for configuration. And no files showing up and the addon logging “no media in playlist main” even though .mp3-files have been placed in config/www, /media and /share.
well I’ve tried installing the 2021.03.1 release and for 20 mins now my hassos has been spinning its wheels… wonder if its killed it?
Same here but after 20 minutes I get a window asking me if I want to cancel.
mine has no web connection nor ssh… but its virtual machine is still hitting the cpu 20% and there is some disk activity so I’ve left it… otherwise I would of restarted it
Issue can be resolved by installing aiohttp again with a force-reinstall
pip3 install aiohttp --force-reinstall
a reboot fixed it
I discovered that anomaly also. I happened to click on the last line displayed and it resumed displaying the rest. Now just very annoying rather than a catastrophic bug…
Anyone else tried editing their Adaptive Lighting instances (or adding a new one)?
I cannot…
** Resolved **
Re-installed integration from HACS…
It depends… My average script is ~2500 lines and 100% of those require text mode - I use editor only for sake of syntax errors checks - very convenient, when works properly…
For anybody else who may also have issues, after entering the IP Address and the token, I had to enter the token again and select roborock.vacuum
as a device model.
Leaving this field blank fails to connect for me…
(and yes I did upgrade to 2021.3.1 this morning)
After Updating HassOS on pi4, i have Problems with “cover.set_cover_position”.
The Entity says it`s done, but in real nothing happened. No Errors
Also it seems that the “opened/closed” state are reversed right now “o” are open “100” are closed.
The Cover Card-Buttons are working fine. Im Using RF-Bridge with Tasmota and “custom-components-cover-rf-time-based” Integration for properitary 433 Mhz. Any Ideas?
2500 lines for a single script? What the hell are you doing with your script? XD
…and that’s only his average script!
Try
Unfortunately, no “magic” here !
Stilll the same issue with core-2021.3.1 after a few minutes.
I"ve update the MariaDB url in the recorder config, rebooted Home Assistant, uninstall and reinstall MariaDB addon.
In the MariaDB addon logs :
2021-03-05 11:39:55 28 [Warning] Aborted connection 28 to db: 'homeassistant' user: 'hass' host: '172.30.32.1' (Got an error reading communication packets)
I will give SQLite a try.
Since this update I have a weird thing… Normally I have some multiple tabs open… node-red, homeassistant frontend, esphome etc… and they all stay open.
Now when I switch between tabs it reloads when opening the tab! That makes me loose ongoing changes in nodered and esphome!?
Why and what that?
You asked, I answered, if you want to believe “disable forever is not temporary” that’s your choice, I’m not going to argue with a stranger after giving them my time. You’re welcome.
Simple - dialogue management for the events comming from rhasspy - recieve data, process data… If you want feel like you are talking to a ‘living’ person, you need to consider many options. And I’ve built - lighting_assistant, sound_assistant, engineering_assistant, climate_assistant - bunch of guys talking to me when I need hand with something…
Agree @Mariusthvdb - using the standard HA dark theme I can barely see anything when editing:
Is there some configuration somewhere I can “tune” my preferences here do you know?
EDIT: it actually looks clearer in the screen shot enlarged than when editing in realworld
