I have a similar error, but not running Dwain’s UI.
Testing configuration at /tmp/config
Fatal error while loading config: Secrets not supported in this YAML file
Failed config
General Errors:
- Secrets not supported in this YAML file
Is Lovelace_gen a custom component or what I used when I let HA control the UI?
As a heads up, I added Ids to all my automations, restarted and still have my formatting and all my comments. Im guessing if you actually edit an automation using the UI editor, all bets are off.
I also don’t have all my automations in a single file, they are in a single folder in multiple files using automation: !include_dir_merge_list automation/
Now to wait a bit for some automations to run and see if the tracing works.
2021-04-08 14:32:25 WARNING (Recorder) [homeassistant.components.recorder.migration] Modifying columns event_data in table events. Note: this can take several minutes on large databases and slow computers. Please be patient!
2021-04-08 15:01:25 WARNING (MainThread) [homeassistant.bootstrap] Waiting on integrations to complete setup: recorder
2021-04-08 15:01:55 WARNING (Recorder) [homeassistant.components.recorder.migration] Modifying columns attributes in table states. Note: this can take several minutes on large databases and slow computers. Please be patient!
2021-04-08 15:02:25 WARNING (MainThread) [homeassistant.bootstrap] Waiting on integrations to complete setup: recorder
It really seems like database upgrades should be done in the background, Home Assistant was perfectly capable of continuing to run in the past when the database was unavailable. So, it doesn’t store any information in the period of time that the database is upgrading, that’s still preferably to having no web interface or working system (my heating is now unavailable).
Obviously nothing can be done about it now, but perhaps something to consider for the future.
Also I would echo comments from others, some sort of progress meter so we have at least a very rough estimate as to how long this will take. As it stands I have no idea, whether I am on the last step of the upgrade or if there are another 100 columns it is going to need to alter at 30mins each time…
EDIT:
For people looking for estimated times.
Database Size:
I’m having a massive issue with the upgrade. Somehow it keeps crashing on my MariaDB add-on. On restart, Home Assistant is not reachable for more than 30 minutes and then comes online with:
The MariaDB add-on logs then shows the DB might be corrupted and need repairs. Repairs it and after a restart of the add-on everything seems fine:
210408 16:29:48 mysqld_safe Logging to '/data/databases/mariadb.err'.
210408 16:29:49 mysqld_safe Starting mysqld daemon with databases from /data/databases
2021-04-08 16:29:49 0 [Note] InnoDB: Using Linux native AIO
2021-04-08 16:29:49 0 [Note] InnoDB: Mutexes and rw_locks use GCC atomic builtins
2021-04-08 16:29:49 0 [Note] InnoDB: Uses event mutexes
2021-04-08 16:29:49 0 [Note] InnoDB: Compressed tables use zlib 1.2.11
2021-04-08 16:29:49 0 [Note] InnoDB: Number of pools: 1
2021-04-08 16:29:49 0 [Note] InnoDB: Using SSE2 crc32 instructions
2021-04-08 16:29:49 0 [Note] mysqld: O_TMPFILE is not supported on /var/tmp (disabling future attempts)
2021-04-08 16:29:49 0 [Note] InnoDB: Initializing buffer pool, total size = 128M, instances = 1, chunk size = 128M
2021-04-08 16:29:49 0 [Note] InnoDB: Completed initialization of buffer pool
2021-04-08 16:29:49 0 [Note] InnoDB: If the mysqld execution user is authorized, page cleaner thread priority can be changed. See the man page of setpriority().
2021-04-08 16:29:49 0 [Note] InnoDB: 128 out of 128 rollback segments are active.
2021-04-08 16:29:49 0 [Note] InnoDB: Creating shared tablespace for temporary tables
2021-04-08 16:29:49 0 [Note] InnoDB: Setting file './ibtmp1' size to 12 MB. Physically writing the file full; Please wait ...
2021-04-08 16:29:49 0 [Note] InnoDB: File './ibtmp1' size is now 12 MB.
2021-04-08 16:29:49 0 [Note] InnoDB: Waiting for purge to start
2021-04-08 16:29:49 0 [Note] InnoDB: 10.4.17 started; log sequence number 222990187316; transaction id 15365475
2021-04-08 16:29:49 0 [Note] InnoDB: Loading buffer pool(s) from /data/databases/ib_buffer_pool
2021-04-08 16:29:49 0 [Note] Plugin 'FEEDBACK' is disabled.
2021-04-08 16:29:49 0 [Note] Server socket created on IP: '::'.
2021-04-08 16:29:49 0 [Note] Reading of all Master_info entries succeeded
2021-04-08 16:29:49 0 [Note] Added new Master_info '' to hash table
2021-04-08 16:29:49 0 [Note] /usr/bin/mysqld: ready for connections.
Version: '10.4.17-MariaDB' socket: '/run/mysqld/mysqld.sock' port: 3306 MariaDB Server
2021-04-08 16:29:49 0 [Note] InnoDB: Buffer pool(s) load completed at 210408 16:29:49
[16:29:49] INFO: Check data integrity and fix corruptions
mysql.column_stats OK
mysql.columns_priv OK
mysql.db OK
mysql.event OK
mysql.func OK
mysql.global_priv OK
mysql.gtid_slave_pos OK
mysql.help_category OK
mysql.help_keyword OK
mysql.help_relation OK
mysql.help_topic OK
mysql.index_stats OK
mysql.innodb_index_stats OK
mysql.innodb_table_stats OK
mysql.plugin OK
mysql.proc OK
mysql.procs_priv OK
mysql.proxies_priv OK
mysql.roles_mapping OK
mysql.servers OK
mysql.table_stats OK
mysql.tables_priv OK
mysql.time_zone OK
mysql.time_zone_leap_second OK
mysql.time_zone_name OK
mysql.time_zone_transition OK
mysql.time_zone_transition_type OK
mysql.transaction_registry OK
homeassistant.events OK
homeassistant.recorder_runs OK
homeassistant.schema_changes OK
homeassistant.states OK
nginxproxymanager.access_list OK
nginxproxymanager.access_list_auth OK
nginxproxymanager.access_list_client OK
nginxproxymanager.audit_log OK
nginxproxymanager.auth OK
nginxproxymanager.certificate OK
nginxproxymanager.dead_host OK
nginxproxymanager.migrations OK
nginxproxymanager.migrations_lock OK
nginxproxymanager.proxy_host OK
nginxproxymanager.redirection_host OK
nginxproxymanager.setting OK
nginxproxymanager.stream OK
nginxproxymanager.user OK
nginxproxymanager.user_permission OK
[16:29:50] INFO: Ensuring internal database upgrades are performed
This installation of MariaDB is already upgraded to 10.4.17-MariaDB, use --force if you still need to run mysql_upgrade
[16:29:50] INFO: Ensure databases exists
[16:29:50] INFO: Create database homeassistant
[16:29:50] INFO: Ensure users exists and are updated
[16:29:50] INFO: Update user hass
[16:29:50] INFO: Init/Update rights
[16:29:50] INFO: Granting all privileges to hass on homeassistant
[16:29:50] INFO: Successfully send service information to Home Assistant.
[cont-finish.d] executing container finish scripts...
[cont-finish.d] done.
[s6-finish] waiting for services.
2021-04-08 16:33:55 0 [Note] /usr/bin/mysqld (initiated by: root[root] @ localhost []): Normal shutdown
2021-04-08 16:33:55 0 [Note] Event Scheduler: Purging the queue. 0 events
2021-04-08 16:33:55 0 [Note] InnoDB: FTS optimize thread exiting.
2021-04-08 16:33:55 0 [Note] InnoDB: Starting shutdown...
2021-04-08 16:33:55 0 [Note] InnoDB: Dumping buffer pool(s) to /data/databases/ib_buffer_pool
2021-04-08 16:33:55 0 [Note] InnoDB: Buffer pool(s) dump completed at 210408 16:33:55
2021-04-08 16:33:57 0 [Note] InnoDB: Shutdown completed; log sequence number 222990187325; transaction id 15365495
2021-04-08 16:33:57 0 [Note] InnoDB: Removed temporary tablespace data file: "ibtmp1"
2021-04-08 16:33:57 0 [Note] /usr/bin/mysqld: Shutdown complete
s6-svscanctl: fatal: unable to control /var/run/s6/services: supervisor not listening
[s6-finish] sending all processes the TERM signal.
However, restarting Home Assistant, the story is also beginning all over. 30 minutes wait… then error.
unfortunately this is not preventing the following
2021-04-08 16:44:32 ERROR (MainThread) [homeassistant.helpers.template] Template variable error: 'None' has no attribute 'split' when rendering '{% if state_attr(config.entity,'friendly_name') is defined %} {{state_attr(config.entity,'friendly_name').split(' sensor light level')[0]}} {% else %} Tbd {% endif %}'
how can we catch this?
after restart is finished and all sensors loaded, this behaves fine, its just that I happened to check the log while on this view…
thanks for having a look
Notifications are not send - they worked on Core 2021.3.4
File "/usr/src/homeassistant/homeassistant/helpers/script.py", line 359, in _async_step
await getattr(self, handler)()
File "/usr/src/homeassistant/homeassistant/helpers/script.py", line 559, in _async_call_service_step
await service_task
File "/usr/src/homeassistant/homeassistant/core.py", line 1480, in async_call
task.result()
File "/usr/src/homeassistant/homeassistant/core.py", line 1515, in _execute_service
await handler.job.target(service_call)
File "/usr/src/homeassistant/homeassistant/components/notify/__init__.py", line 160, in _async_notify_message_service
await self.async_send_message(**kwargs)
File "/usr/src/homeassistant/homeassistant/components/notify/__init__.py", line 137, in async_send_message
await self.hass.async_add_executor_job(
File "/usr/local/lib/python3.8/concurrent/futures/thread.py", line 57, in run
File "/usr/src/homeassistant/homeassistant/components/notify_events/notify.py", line 124, in send_message
if data.get(ATTR_TOKEN, "").trim():
AttributeError: 'str' object has no attribute 'trim'
Shouldn’t it be .strip() ?
In case it matters, it’s a standard automation:
alias: Haustuer unten wurde geoeffnet
description: ''
- platform: state
entity_id: switch.shelly_shsw_1_10e0dc
to: 'on'
condition: []
- service: notify.events
message: Haustuer geoeffnet
title: Haustuer geoeffnet
mode: single
How big is/was your database? I’m on a similar set up but using MySQL on my synology, and sitting at 4GB of database, wondering if I should go get a drink…
that’s just the thing, the split is on state_attr(config.entity,'friendly_name') , hence the {% if state_attr(config.entity,'friendly_name') is defined %}
and, even when I also check for the config.entity to be defined this still leads to
2021-04-08 16:56:35 ERROR (MainThread) [homeassistant.helpers.template] Template variable error: 'None' has no attribute 'split' when rendering '{% if config.entity is defined and state_attr(config.entity,'friendly_name') is defined %} {{state_attr(config.entity,'friendly_name').split(' sensor light level')[0]}} {% else %} Tbd {% endif %}'
got it. its saying “WARNING (MainThread) [homeassistant.bootstrap] Waiting on integrations to complete setup: recorder”…its been 3 hours since i started the update
since my upgrade to v2021.4.0 my Speedtest.Net integration does not work anymore and I get the following log-entries:
2021-04-08 14:56:13 ERROR (MainThread) [homeassistant.config_entries] Error setting up entry SpeedTest for speedtestdotnet
File "/usr/src/homeassistant/homeassistant/config_entries.py", line 249, in async_setup
result = await component.async_setup_entry(hass, self) # type: ignore
File "/usr/src/homeassistant/homeassistant/components/speedtestdotnet/__init__.py", line 75, in async_setup_entry
await coordinator.async_setup()
File "/usr/src/homeassistant/homeassistant/components/speedtestdotnet/__init__.py", line 194, in async_setup
self.api = await self.hass.async_add_executor_job(speedtest.Speedtest)
File "/usr/local/lib/python3.8/site-packages/speedtest.py", line 1091, in __init__
self.get_config()
File "/usr/local/lib/python3.8/site-packages/speedtest.py", line 1173, in get_config
ignore_servers = list(
ValueError: invalid literal for int() with base 10: ''
Reinstalling the integration did not help.
Otherwise: I LOVE the tracing function of the automations. GEAT JOB. THANKS!!!
Unrelated to the new HA version (the timing just by accident coincided). Was an issue in the upstream library that was fixed an hour ago. PR to use the new upstream library version is already created for HA.
I’ve gone through the files in /config and /custom_components and replaced secrets with their true values, but continue to get the error with Config Check. Any guesses?
