This feature is GENIUS !!!
Thank you so MUCH @emontnemery @thomasloven @balloob @bramkragten !
after the update everything works correctly but the xiaomi_miio integration is problematic, the logs are full of errors
Logger: homeassistant.components.xiaomi_miio
Source: components/xiaomi_miio/__init__.py:98
Integration: Xiaomi Miio (documentation, issues)
First occurred: 11:39:53 (1105 occurrences)
Last logged: 13:11:54
Got exception while fetching the state: Got an exception while sending command get_bright
2021-04-10 13:12:37 ERROR (SyncWorker_61) [homeassistant.components.xiaomi_miio] Got exception while fetching the state: Got an exception while sending command get_bright
2021-04-10 13:12:44 ERROR (SyncWorker_63) [homeassistant.components.xiaomi_miio] Got exception while fetching the state: Got an exception while sending command get_bright
2021-04-10 13:12:47 ERROR (SyncWorker_31) [homeassistant.components.xiaomi_miio] Got exception while fetching the state: Got an exception while sending command get_bright
2021-04-10 13:12:54 ERROR (SyncWorker_42) [homeassistant.components.xiaomi_miio] Got exception while fetching the state: Got an exception while sending command get_bright
2021-04-10 13:12:57 ERROR (SyncWorker_62) [homeassistant.components.xiaomi_miio] Got exception while fetching the state: Got an exception while sending command get_bright
2021-04-10 13:13:04 ERROR (SyncWorker_16) [homeassistant.components.xiaomi_miio] Got exception while fetching the state: Got an exception while sending command get_bright
The mistakes don’t stop …
After upgrade 5h Db not working .every restart is long 3-4 hours.rpi3 + ssd.going back on old version.
Anybody else experiencing issues with the Automations tab not being visible or automations not running since the last update?
Looking into the logs I see this:
Logger: homeassistant.setup
Source: components/device_automation/__init__.py:86
First occurred: 13:41:37 (1 occurrences)
Last logged: 13:41:37
Error during setup of component automation
File "/usr/src/homeassistant/homeassistant/components/device_automation/__init__.py", line 83, in async_get_device_automation_platform
integration = await async_get_integration_with_requirements(hass, domain)
File "/usr/src/homeassistant/homeassistant/requirements.py", line 52, in async_get_integration_with_requirements
integration = await async_get_integration(hass, domain)
File "/usr/src/homeassistant/homeassistant/loader.py", line 553, in async_get_integration
raise IntegrationNotFound(domain)
homeassistant.loader.IntegrationNotFound: Integration '' not found.
File "/usr/src/homeassistant/homeassistant/setup.py", line 240, in _async_setup_component
result = await task
File "/usr/src/homeassistant/homeassistant/components/automation/__init__.py", line 219, in async_setup
if not await _async_process_config(hass, config, component):
File "/usr/src/homeassistant/homeassistant/components/automation/__init__.py", line 623, in _async_process_config
await async_validate_config_item(hass, raw_config),
File "/usr/src/homeassistant/homeassistant/components/automation/config.py", line 81, in async_validate_config_item
config[CONF_ACTION] = await script.async_validate_actions_config(
File "/usr/src/homeassistant/homeassistant/helpers/script.py", line 232, in async_validate_actions_config
return await asyncio.gather(
File "/usr/src/homeassistant/homeassistant/helpers/script.py", line 276, in async_validate_action_config
choose_conf[CONF_SEQUENCE] = await async_validate_actions_config(
File "/usr/src/homeassistant/homeassistant/helpers/script.py", line 247, in async_validate_action_config
platform = await device_automation.async_get_device_automation_platform(
File "/usr/src/homeassistant/homeassistant/components/device_automation/__init__.py", line 86, in async_get_device_automation_platform
raise InvalidDeviceAutomationConfig(
homeassistant.components.device_automation.exceptions.InvalidDeviceAutomationConfig: Integration '' not found
Re: Error loading /config/configuration.yaml: Secrets not supported in this YAML file
I have used the Check Configuration (against 2014.4.3) and get the same result. I’m not using lovelave_gen or dwains dashboard. I have checked all the YAML files in /Config for a reference to Secret. Could the problem be with existing addon integrations?
I’ve opened an issue. You can add logs if you want to help.
The log shows, that an integration wasn’t found.
Did you check all your integrations. Are they all available?
Maybe it should be mentioned, that with 2021.3.4 I manually have to reload MET.no after every HA restart. So the issue might be older. Running HA OS on an raspb3+
almost slipped by, but I see we now can filter log messages https://www.home-assistant.io/integrations/logger/#log-filters
this might be the only option on the terribly annoying NMBS integration errors that are not to be avoided (issue in Github has been there for ages, and wont get resolved any time soon I fear)
this is in the logs, in many variants daily, mostly during the night, but also randomly at daytime
2021-04-10 09:27:10 ERROR (MainThread) [homeassistant.helpers.entity] Update for sensor.brussel_noord_essen fails
File "/usr/src/homeassistant/homeassistant/helpers/entity.py", line 292, in async_update_ha_state
await self.async_device_update()
File "/usr/src/homeassistant/homeassistant/helpers/entity.py", line 498, in async_device_update
await task
File "/usr/local/lib/python3.8/concurrent/futures/thread.py", line 57, in run
File "/usr/src/homeassistant/homeassistant/components/nmbs/sensor.py", line 272, in update
if connections is None or not connections["connection"]:
KeyError: 'connection'
2021-04-10 09:34:40 ERROR (MainThread) [homeassistant.helpers.entity] Update for sensor.essen_brussel_noord fails
await task
How could I filter that given the fact that the main Error is on homeassistant.helpers.entity
but the significant bit is at the end:
and the KeyError
is not always identical ? eg
File "/usr/src/homeassistant/homeassistant/components/nmbs/sensor.py", line 155, in update
if liveboard is None or not liveboard["departures"]:
KeyError: 'departures'
thanks for having a look, hope this can be done.
Same here. I have upgraded yesterday to 2021.4.2 using Supervisor. Everything seemed to be OK. No update pending message.
Then this morning, I get this:
I had to replace all secrets in my configuration files with their actual values before I could pass a config check to 2021.4.x.
No do not downgrade, not needed. Just wait for this bug to be solved
Related feature request:
Are you sure that’s not an old dev version?
I’m pretty sure the Dev repo isn’t needed anymore
Yes and no… before it was sufficient to use “dev”. But now the official documentation states to do so:
Any hope the severe bugs related to IOS get addressed?
It is impossible to edit anything on IOS. The minute you need to type anything in a code window you cannot. You can only view and click in the UI. The minute want to change something you get stuck because you cannot edit text in any place that uses code editor. That is developer tools. Any editing of Lovelace cards. It is all broken. It seems like the code has lost the position of the cursor and think it is on first line first character because when you set the cursor at the end of a line, the backspace is ignored and if you type letters the cursor jumps to start of a line and it all goes garbage. You cannot even work around it. It is broken in a way you cannot use it at all
No problems here on iOS. Your issue is also 3 days old. You’re going to have to be a little more patient. Even if a fix is found and delivered, it wouldn’t be til next release.
EDIT: I’m fully up to date: iOS 14.4.2. I’m able to edit any text box without issue. I can edit the yaml boxes, normal fields, template editor. I tried this on safari, chrome, and the companion app.
My worry is that noone has taken ownership of the bug report. And the experience here is that either a bug gets assigned and fixed quickly or it gets ignored at it moves to page two of the list of bugs.
I am puzzled you say it works. I wonder what you tried. And I would like others to confirm this.
Try these steps (they are in the github)
View ny lovelace tab ob which you have at least one card.
Click Edit Dashboard
Hit Edit on a card. It can be a simple entity card with a few lines
Click Show Code Editor
Click so the cursor is at the end of a line. E.g. the 2nd line.
Let us assume you want to delete the last word. So hit back space. What happens? Nothing!
With the cursor still at the end of a line try and type 4-5 letters. Do you one letter correct and then see the cursor jump to the first position of the first line and the letters you type are added there and not where your cursor was?
You can also try and click in the middle of any line. Does backspace work?
Without the ability to delete any characters and only being able to type anything before the existing text, you cannot practically do anything
It is any feature that uses the code editor that is broken. Same in the developer tools that accept yaml. You can type in other types of text entry fields.
Note this issue was introduced in 2021.4.0. It worked fine before.
Can someone with IOS confirm what I describe here?
