hi, seeking further assistance in my discoveries using Nginx (since yesterday…) I did post NGINX configuration - connection refused - #8 by Mariusthvdb, but we couldn’t work this out completely.
cut it short, during startup I see this logged frequently:
2021/07/19 23:02:51 [error] 222#222: *7441 connect() failed (111: Connection refused) while connecting to upstream, client: 192.168.1.1, server: mydomain.duckdns.org, request: "GET /api/websocket HTTP/1.1", upstream: "http://172.30.32.1:8123/api/websocket", host: "mydomain.duckdns.org:myport"
after startup it seems this is no longer happening.
@Burningstone suggested it might be
Could be that it’s because NGINX starts faster than HA.
which seems reasonable, because after initial startup there’s always a gap of about 2 minutes:
2021-07-19 23:20:05 INFO (MainThread) [homeassistant.setup] Setup of domain proximity took 0.3 seconds
2021-07-19 23:21:56 INFO (MainThread) [homeassistant.core] Starting Home Assistant
during which the system fully loads.
can I prevent these errors in Nginx log somehow. of course I already have the relevant address in the trusted_proxies:
use_x_forwarded_for: true
trusted_proxies:
# - 127.0.0.1
- 172.30.33.7
- 172.30.32.0/24
# - 172.30.33.0/24
thanks for having a look!
