Modbus does not work at all with 2021.7.3 (at least in my case)
Here #52872 it was working at least partially
Must return back to 2021.6.6
Itās been already discussed, but InfluxDB integration still not working in 2021.7.3.
Here is more detailed log:
2021-07-16 14:41:09 ERROR (MainThread) [homeassistant.setup] Setup failed for influxdb: unknown error
File "/usr/src/homeassistant/homeassistant/setup.py", line 201, in _async_setup_component
component = integration.get_component()
File "/usr/src/homeassistant/homeassistant/loader.py", line 490, in get_component
cache[self.domain] = importlib.import_module(self.pkg_path)
File "/usr/local/lib/python3.9/importlib/__init__.py", line 127, in import_module
return _bootstrap._gcd_import(name[level:], package, level)
File "<frozen importlib._bootstrap>", line 1030, in _gcd_import
File "<frozen importlib._bootstrap>", line 1007, in _find_and_load
File "<frozen importlib._bootstrap>", line 986, in _find_and_load_unlocked
File "<frozen importlib._bootstrap>", line 680, in _load_unlocked
File "<frozen importlib._bootstrap_external>", line 855, in exec_module
File "<frozen importlib._bootstrap>", line 228, in _call_with_frames_removed
File "/usr/src/homeassistant/homeassistant/components/influxdb/__init__.py", line 13, in <module>
from influxdb import InfluxDBClient, exceptions
File "/usr/local/lib/python3.9/site-packages/influxdb/__init__.py", line 10, in <module>
from .dataframe_client import DataFrameClient
File "/usr/local/lib/python3.9/site-packages/influxdb/dataframe_client.py", line 12, in <module>
import pandas
File "/usr/local/lib/python3.9/site-packages/pandas/__init__.py", line 22, in <module>
from pandas.compat import (
File "/usr/local/lib/python3.9/site-packages/pandas/compat/__init__.py", line 15, in <module>
from pandas.compat.numpy import (
File "/usr/local/lib/python3.9/site-packages/pandas/compat/numpy/__init__.py", line 7, in <module>
from pandas.util.version import Version
File "/usr/local/lib/python3.9/site-packages/pandas/util/__init__.py", line 1, in <module>
from pandas.util._decorators import ( # noqa
File "/usr/local/lib/python3.9/site-packages/pandas/util/_decorators.py", line 14, in <module>
from pandas._libs.properties import cache_readonly # noqa
File "/usr/local/lib/python3.9/site-packages/pandas/_libs/__init__.py", line 13, in <module>
from pandas._libs.interval import Interval
File "pandas/_libs/interval.pyx", line 1, in init pandas._libs.interval
ValueError: numpy.ndarray size changed, may indicate binary incompatibility. Expected 88 from C header, got 80 from PyObject
It seemās to be this problem, or at leas somehow related: https://docs.oracle.com/javase/tutorial/java/package/namingpkgs.htmlhttps://stackoverflow.com/questions/66060487/valueerror-numpy-ndarray-size-changed-may-indicate-binary-incompatibility-exp
Also note that āCheck configurationā button is not working (spinning for indefinity), but command ha core check
is working just fine.
Is this an external InfluxDB database?
Because the addon is working fine for me.
No, I have influxDB addon, but I donāt think that this is a problem. The log Iāve sednāt you is from home assistant core, so I do believe that problem is somewhere there.
E.g. āCheck configurationā works fine if there is no āinfluxdbā element in configuration.yaml, but if there is any itās been spinning for indefinitely.
Just let me know if you need some more verbose logs or enything.
Hi all,
Just installed 2021.7.3.
From the release notes I gather that āExpose Spotify as a service (@balloob - #53063)ā would mean we would have gained a new service called Spotify, was I wrong?
Iām asking because the service call drop down list doesnāt have anything with āSpotifyā on it.
Can anyone chime in on this please?
@balloob ?
TIA
im not sure I understand. I left the @ when I installed MDB today. worked.
then I read about change and made the changes
%40 and it did not work.
replaced back to @ and its working. am I missing something?
Version | core-2021.7.2 |
Installation Type | Home Assistant OS |
Development | false |
Supervisor | true |
Docker | true |
Virtual Environment | false |
Python Version | 3.9.5 |
Operating System Family | Linux |
Operating System Version | 5.9.16 |
CPU Architecture | aarch64 |
I have the same error in my log and also confirm that āCheck configurationā button is not working (spinning for indefinity)
I believe it means itās discoverable through the ui via network and auto discovered that way, versus having to set it up through configuration.yaml
Please do not tag the creator of home assistant for a question that anyone can answer, just ask the question in the thread. See guideline 16. Thanks.
This is not referencing a home assistant service, itās referencing the ability to connect to spotify devices by detecting them on the network. Youāll only see a change if thereās a spotify device on your network that has not been set up in home assistant.
Hi @petro
Sorry, I donāt understand what you mean by tagging the creator of home assistant.
I merely made a quote from the release notes, surely that canāt hurt.
Well, if this is not referencing a home assistant service, then why are the release notes stating it exposes Spotify as a service?
I know English is not my native language, but my limited proficiency level tells me someone chose the wrong words to describe the feature, and heck if I understand why we the users can be blamed for not getting the underlying reasoning and functionality.
Speaking of which, may I inquire where is the documentation for this feature?
The only thing I can see is the weak documentation on the integration itselfā¦
Iāve been a software developer, DBA, and project manager for some 30 years now, and I can tell you documentation is greatly underestimated.
If I may, and you donāt mind, Iāll leave a suggestion that HASS developers spend a bit more time worrying about documenting the features they implement.
I can assure you they will spend far less time dealing with unnecessary queries like mine here if they do.
Sorry for the rant, but I really canāt get it when someone just doesnāt assume their mistakes.
Have a nice weekend, with far more pleasant things on your mind.
Cheers,
Thank you @moto2000 , I would not have reached that understanding if no-one would have mentioned it.
By the looks of it it does seem to be the case, thanks for clearing it for me, with no judgemental attitudes.
Using the @
followed by a username tags somebody and send them a notification. You tagged balloob, the founder of Home Assistant in that quote from the Release Notes.
I was just about to leave when this thought came along:
What do you guys mean by not having to set my configuration yaml file for HA to detect Spotify?
How will HA guess my client_id and client_secret to be able to connect to my Spotify account at all???
@Prodigyplace yeah, I get that now, but I was not aware balloob was the man behind HASS, shoot me LoL
Jokes apart, I did make the quote without noticing it had the @ inside, it was an unfortunate mistake of mine.
My fault, I realised it too late, sorry, but I really didnāt even know he was the HA creator, really.
I think we have all made similar mistakes. that is one way we learn.
How on earth can I improve the documentation of something Iām seeing for the first time?
The documentation you quoted is the documentation I saw already, and itās really bare metal.
For example I was trying to see how to direct the Spotify music to other devices and that is not even referenced there, same thing for this āexpose Spotify as a serviceā thing.
From 2021.7.2 to 2021.7.3 that page as changed absolutely NOTHING. How is that even possible!?!?
Itās not the end user job to document a new feature, itās a developer or QA job to do so for crying out loud.
Do you use Microsoft Excel? Do you want do write up or improve their online HELP? Of course not.
Actually it kind of is. This is an open source project that relies heavily on volunteers. Iām not a programmer but have helped with clarification of the documentation.
If you canāt make the changes yourself, use the feedback button to suggest what needs improvement.
This bit is what he means
It probably only does this if you have configured the spotify integration.
It is considered bad practice to tag anyone who is not in the conversation already. A reference to a PR doesnāt count - itās not just because Balloob is the founder of HA. No one wants notifications about conversations they are not a part of and itās just rude trying to drag someone in for help when lots of people can and will help you. Donāt take offence to this. We are all volunteers here trying to help other people and that will include helping to improve the docs as well.
