Where is the meter in your setup? Mine is at the feed-in point, if yours is not and elsewhere (e.g. between inverter and consumption) then that could explain it.
Or if your inverter is on one phase but consumption on other phases, it would basically export everything to balance out import on the other phases.
Just to confirm - the real_produced_fronius_meter value matches the energy_total_fronius_inverter value?
Did anyone get their Growatt solar panels added to the energy management console? I can’t seem to get that working and even though I got to the point that I can add my daily production custom entity (through a template) but it says “Key need to start with energy_”.
Youless entities are working now in the new energy management. I put this in my customize.yaml
sensor.youless_net_power_meter:
state_class: measurement
device_class: energy
last_reset: ‘1970-01-01T00:00:00.000000+00:00’
restart and you get then this:
timestamp: 1628245383
unit_of_measurement: kWh
friendly_name: Net Power usage
icon: mdi:gauge
last_reset: 1970-01-01T00:00:00.000000+00:00
Now I can see this in “Configure grid consumption”
Net Power usage
Would be good to have the ability to log/visualise power diverted from excess solar generation that does not go back to grid. For example, amount diverted to battery storage or to domestic hot water.
odd I cannot upgrade from core-2021.7.4. Loads of warnings about incompatible schema. I have a 2nd instance with mariadb and that upgraded fine- almost an identical copy.
Nothing in the breaking changes related to my setup.
Suggestions? Anyone else having this issue?
21-08-06 09:08:28 INFO (MainThread) [supervisor.updater] Fetching update data from https://version.home-assistant.io/stable.json
21-08-06 09:09:10 WARNING (MainThread) [supervisor.addons.addon] Add-on core_mariadb new schema is not compatible
21-08-06 09:09:10 WARNING (MainThread) [supervisor.misc.tasks] Add-on core_mariadb will be ignored, schema tests failed
21-08-06 09:09:10 WARNING (MainThread) [supervisor.addons.addon] Add-on core_duckdns new schema is not compatible
21-08-06 09:09:10 WARNING (MainThread) [supervisor.misc.tasks] Add-on core_duckdns will be ignored, schema tests failed
21-08-06 09:09:10 WARNING (MainThread) [supervisor.addons.addon] Add-on core_samba new schema is not compatible
21-08-06 09:09:10 WARNING (MainThread) [supervisor.misc.tasks] Add-on core_samba will be ignored, schema tests failed
Just updating mariadb addon to see if that makes a difference.
SUCCESS.
Updated mariadb-rebooted. 2 attempts to upgrade and finally all ok
Love the new Energy dashboard! I hope gas consumption will be added soon too.
I have a question regarding energy cost tracking though. I’ve set static prices for my consumption, but what if my prices change (e.g. new contract) and I change my static prices in HA, will my historic pricing remain unchanged? Or will that also (incorrectly) change my historic energy cost?
If historic costs don’t change when changing the price then is there another way to change historic prices? This could be useful if I get new prices but forget to change the price in HA. Lets say I find out I got new prices a month ago, I would want to change the prices in HA from that date instead of today.
