Red1
(Red)
August 10, 2021, 5:03pm
1
My Gosund smart plug (using ESPHome) provides a wattage entity:
I would like to calculate the energy (kWh) based on this sensor and use / display it in the new energy dashboard provided by HA 2021.8.
I have read about utility_meter and that I might need a template sensor to get it converted into kWh. But somehow I don’t have a clue how to realize it. Maybe anyone who can help with a short instruction?
Thanks, red
Use this-
You should also use the “left” method for a more accurate result.
After integrating it using Reimann Sum, you can then use the sensor for Utility Meter to track your consumption (daily, weekly, monthly).
Red1
(Red)
August 10, 2021, 6:42pm
3
ardysusilo:
Thanks @ardysusilo !
At first glance, it sounds easy. I used the following in my sensors.yaml
- platform: integration
source: sensor.energy_06_wattage
unit_prefix: k
round: 2
method: left
It seems to work properly (still have to validate the results).
But now when I want to use the Utility Meter , how it implement this? Would this be correct if I put this into configuration.yaml?
# Utility Meter
utility_meter:
daily_energy_06:
source: sensor.energy_06_spent
cycle: daily
monthly_energy_06:
cycle: monthly
PS: Is it possible to reset the values for sensors based on Integration - Riemann sum integral ?
You can try the configuration for Utility Meter integration. Make sure to Check Configuration to rule out the possibility of invalid syntax.
For Integration of Riemann Sum Integral , the default unit time is h (hour). Available options are s , min , h and d .
Red1
(Red)
August 11, 2021, 7:36pm
5
Finally it worked as written in my last post.
mapo
September 22, 2021, 7:46pm
6
Did you find any solution to reset your values ?
stewc
December 12, 2021, 7:10pm
7
Perfect solution, thanks!
Senbei
(Tristans Smartes Heim)
December 27, 2021, 7:30pm
8
why not simply use this:
name: energy_06_spent_day (I would prefer energy_06_kWd)
unit_prefix: k
round: 2
unit_time: d
Where the unit time “d” is for DAY?!
Senbei
December 28, 2021, 6:58pm
9
Ok, I got it - because the “platform: integration” doesn’t support the state_class: measurement, total or total_increasing - Therefore it doesn’t show up in the energy setup.
MWelchUK
(Martyn Welch)
June 21, 2022, 1:17pm
11
The work around I have for this is to setup a template that sets that parameter with the state just being the state of the integration:
- name: "Export Energy (template)"
unit_of_measurement: "kWh"
unique_id: export_energy_template
device_class: energy
state: >
{{ states('sensor.export_energy_calc') }}
For anybody coming to this thread by googling, like I did. In the meantime the Riemann integration is directly integrated into HA helpers. Works like a charme!
Hope this helps anybody that is searching…
Best, Frank
colyro
(Daniel Coli)
December 19, 2023, 2:36pm
13
hi all
after several hours spent, i need some guidance please.
I have a huawei solar inverter and 2 strings.
I would like to a daily/monthly/yearly statistics for each string.
I created below a sensor for String 2:
- sensor:
- name: "Solar Fotovoltaice String 1 Sud"
unit_of_measurement: "W"
unique_id: "solar_foto_string1_sud"
device_class: power
state: >
{{((states('sensor.inverter_pv_1_voltage')|float) * (states('sensor.inverter_pv_1_current')|float))|int(0)}}
This sensor multiplies String 2 Voltage with String 2 Current resulting power in Watts.
How to convert it in kWh?
I’ve tried using utility meter but it is in Watt expressed.
I was thinking in creating below sensor already in kWh and use it in utility meter for statistics:
#Productie string 2 in kWh
- sensor:
- name: "Productie Fotovoltaice String #2"
unique_id: productie_solar_string2_test2
unit_of_measurement: 'kWh'
# icon: mdi:transmission-tower
state: >
{{(((states('sensor.inverter_pv_2_voltage')|float) * (states('sensor.inverter_pv_2_current')|float))|int(0))/1000}}
state_class: total_increasing
How would you do it to store the statistics in kWh ?
Hi, I am late to this party but trying to see if I understand what is said here.
I have a Power Station that I want to keep track of in terms of discharged energy (kWh). I only have the power sensor (attached pic). So I use this power senor as the input to this Riemann Sum Integral integration ?
@ardysusilo
