Did this release get withdrawn?
I see this error in supervisor when I try and trigger update via ssh
21-09-19 12:29:41 ERROR (SyncWorker_0) [supervisor.docker.interface] Can't install ghcr.io/home-assistant/generic-x86-64-homeassistant:2021.9.7: 500 Server Error for http+docker://localhost/v1.41/images/create?tag=2021.9.7&fromImage=ghcr.io%2Fhome-assistant%2Fgeneric-x86-64-homeassistant: Internal Server Error ("manifest unknown")
21-09-19 12:29:41 WARNING (MainThread) [supervisor.homeassistant.core] Updating Home Assistant image failed
tom_l
September 19, 2021, 3:05am
2
I just reloaded the supervisor and donāt see an update to 2021.9.7
tom_l
September 19, 2021, 3:34am
4
Yeah, itās on the releases page too, https://github.com/home-assistant/core/releases
Strange.
Zehir
(Zehir)
September 19, 2021, 9:35am
5
Itās seems that the build failed
assistant/core/runs/3644082055
GitHub is where people build software. More than 65 million people use GitHub to discover, fork, and contribute to over 200 million projects.
Not if itās listed on docker hubā¦
ludeeus
(Ludeeus)
September 19, 2021, 10:40am
7
Wellā¦ docker hub does not matter at allā¦
so this release is not yet released?
How so? I shows all the releases and previously as soon as itās listed there I can install it via sshā¦ I would install updates that way 90% of the timeā¦
ludeeus
(Ludeeus)
September 19, 2021, 12:43pm
10
Look at the logs you posted.
Thatās not docker hub
BebeMischa
(Bebe Mischa)
September 19, 2021, 3:38pm
11
My HA server is also not seeing an update, running 2121.9.6. Confusingā¦
Can someone, please, clearly confirm, what is the current state of the release?
ludeeus
(Ludeeus)
September 19, 2021, 3:54pm
12
The build failed. Donāt expect anything until tomorrow earliest
francisp
(Francis)
13
Current status : 2021.9.7 is announced, nobody can download it.
Edit: see ludeeus answer just above mine.
Canedje
September 19, 2021, 4:29pm
15
That explaines a lot.
I was missing the update coming true also
poudenes
(Poudenes)
September 20, 2021, 1:40pm
16
Got today the option to update. But get same error.
GlennHA
(Glenn)
September 20, 2021, 2:03pm
18
As for the update = true; I have noticed that the image will get updated on docker hub then up to four hours later the built-in HA updater will state an update is available. I have also seen it the other way around where I get the updater saying an update is available hours before it is available on docker hub.
As for me 2021.9.7 is working but I also see that 2021.9.8 is available as of 3 hours ago but my built-in HA update sensor is still false. I set up my own sensors based on a new docker image being available.
BebeMischa
(Bebe Mischa)
September 20, 2021, 3:21pm
20
GitHub status is now green, so i did hit the update button ans succeededā¦
