2022.11: A heck of a release!
What kind of sensor is the new water integration looking for ? I have a sensor with the reading from my water meter in litres (total). How do I get that into the energy dashboard ? Thanks
I needs a sensor that:
  • Provides a total usage (e.g., forever, week, or per day something like that)
  • In cubic meters or gallons units
  • Has long-term statistics enabled (state class is set)
  • Has a device class of “water”
  • Is not excluded from the recorder
OK thanks, what state class does it need to be, I assume the reading is ‘forever’ as its the meter reading ?
EDIT: state_class: total ?
EDIT2: Yes that seems to work
I also want the old history display back. Made a github issue about it when I noticed this change in beta, but sadly this bad change made it to the release version.
surprised this was not closed, (and was added to the milestone even) as it not an issue (something is broken), but a design decision currently.
Not that I dont agree :wink:
BAD:
Showing statistics only - not precise, some sensors have no LTS.
GOOD:
Show statistics (if present) in one tab, show history graph in the MAIN tab.
BAD:
Show history graph OR statistics -controlled by some toggle (history by default).
Gigajoule support?! Great Scott!
Please revert (or give option) to old-style. Statistics display is missing important details I need
Hello
Same concern as some members
Capture
Despite the procedure indicated for corrected.
I also suggested @petro
https://community.home-assistant.io/t/2022-11-a-heck-of-a-release/483295/152
but nothing seems to work
Only gal/h or gal/d sensors showed up for me, which kinda makes sense I guess, but not at the same time. I think this is related to the energy dashboard needing kwh and not kw, but I don’t truly know.
I got the same after the latest update. Even the recorder starts complaining :disappointed:
Tried repairing everything but nothing works
Still no support for new bosch smart home hardware :frowning:
Is anyone else having any issues with state_image? All of mine stopped working after updating, I did not notice anything listed in breaking changes.
Map card shows the person at bottom of the card after update.
I have the same, but what i tested its only in a Grid card.
Its a pop up card in my case
I rebooted, started systemd-journal-service but I still have this in logs
22-11-03 19:49:02 WARNING (raven-sentry.BackgroundWorker) [urllib3.connectionpool] Retrying (Retry(total=0, connect=None, read=None, redirect=None, status=None)) after connection broken by 'NewConnectionError('<urllib3.connection.HTTPSConnection object at 0x7fc1b9797850>: Failed to establish a new connection: [Errno 111] Connection refused')': /api/5370612/envelope/
Yet you haven’t posted a github issue.
what does 2022.11.01 fix?
There are no information in the release notes for that version…
grafik
51 posts were split to a new topic: Journal issues with supervised install after updating to 2022.11
