oe3arc
(Andreas Kriechhammer)
November 6, 2022, 8:19am
380
same “Timeout fetching zamg data” problem here.
2022-11-05 17:55:31.003 ERROR (MainThread) [homeassistant.components.zamg] Timeout fetching zamg data
I started using the ZAMG integration a few days ago and notice connection loss every now and than.
Here one can see the missing datapoints for two stations:
As I wanted to add another station for testing purposes, I now ended up with a
2022-11-06 07:42:50.096 ERROR (MainThread) [homeassistant.components.zamg] Unexpected error fetching zamg data: ‘NoneType’ object has no attribute ‘get’.
Will try to remove and re-install my stations if I have time.
br
Andy
Murada99
(JoeM)
November 6, 2022, 11:09am
382
Since the update in my pictures elements, state_image no longer displays the image.
That’s true for all elements. Deleting the style does not solve this.
- type: picture-elements
elements:
- type: image
entity: binary_sensor.door_window_sensor
style:
top: 2%
left: 29%
transform: translate(-50%, -50%) scale(.6, .6)
state_image:
'on': /local/images/xopen.png
'off': /local/images/xclose.png
Michel
November 6, 2022, 11:10am
383
When using a view in panelmode on a dashboard there is no margin/padding. Was this always the case and I just never noticed it or did it change/break?
There is a margin/padding on the energy dashboard which is also “fullscreen” and it looks nicer
Murada99
(JoeM)
November 6, 2022, 11:23am
384
Well, I found that adding a width value it works again but this a lot of work to change all elements.
Hope that a fix will come soon.
Here is the link to the workaround solution:
opened 07:39AM - 03 Nov 22 UTC
### The problem
I have a few Picture Elements cards configured to control my … lights, but this is broken after upgrading to 2022.11.0 - images on top of the picture are now gone and nothing happens if I click on the spot where the dots (images) should be. Resources (images) are locally accessible.
Example:
![image](https://user-images.githubusercontent.com/24246157/199667804-a5b3c2c9-04bd-4000-8c77-697c86be07f7.png)
There should be clickable dots on places circled with red:
![image](https://user-images.githubusercontent.com/24246157/199667999-33839f88-7772-4058-afe5-6977b4fc669c.png)
Images are locally accessible:
![image](https://user-images.githubusercontent.com/24246157/199668132-c8885f74-ca43-4721-98e0-3f7b58270cd9.png)
![image](https://user-images.githubusercontent.com/24246157/199668166-b4e54792-0135-4f4f-b99a-7152b37e433b.png)
![image](https://user-images.githubusercontent.com/24246157/199668213-2482a101-fa62-4b60-ac9b-9a5a762c3492.png)
![image](https://user-images.githubusercontent.com/24246157/199668239-1156d1ca-d81c-4a0b-b8c4-83a5164a1406.png)
Nothing in the logs. Restarted HA instance a few time and it does not help.
The same issue is present on my desktop PC (Firefox, Chrome, Edge), on my tablet (via browser and Android app) and mobile (Android app).
Mentioned [here](https://community.home-assistant.io/t/2022-11-a-heck-of-a-release/483295/45?u=c1c3r0).
### What version of Home Assistant Core has the issue?
core-2022.11.0
### What was the last working version of Home Assistant Core?
core-2022.10.5
### What type of installation are you running?
Home Assistant OS
### Integration causing the issue
_No response_
### Link to integration documentation on our website
_No response_
### Diagnostics information
_No response_
### Example YAML snippet
```yaml
elements:
- entity: group.kuhinja
image: /local/lightbulb-group(1).png
state_image:
'on': /local/lightbulb-group-outline(1).png
style:
left: 5%
top: 8%
tap_action:
action: toggle
type: image
- entity: switch.kuhinja_pc
image: /local/red1.png
state_image:
'on': /local/green1.png
style:
left: 23.3%
top: 53.5%
tap_action:
action: toggle
type: image
- entity: switch.kuhinja_ikea
state_image:
style:
left: 39%
top: 18.3%
tap_action:
action: toggle
type: image
state_image:
style:
left: 80%
top: 10%
tap_action:
action: toggle
type: image
- entity: switch.kuhinja_glavna
state_image:
style:
left: 62.8%
top: 20.4%
tap_action:
action: toggle
type: image
- entity: switch.emillux2
state_image:
style:
left: 14%
top: 81.5%
tap_action:
action: toggle
type: image
image: /local/kuhinja1.jpg
### Anything in the logs that might be useful for us?
_No response_
### Additional information
_No response_
ornskov
(Claus Ørnskov)
November 6, 2022, 12:47pm
385
My Netatmo Automation is broken on 2022.11, now if I have two windows open and close one of them both are canceled, I have reverted back to 2022.10.3 where it is working
sebfas
(Seb)
November 6, 2022, 1:44pm
386
Can some one advice me how to resoleve problem with fat stripe in the middle of my picture-element card marked with red arrows, it looks like it’s connected with “custom:color-lite-card”, because when I remove all of them fat stripe dissapear.
Thanks for support.
–fixed adding ha-card-border-width: 0px to …theme…yaml –
schopi68
(Carsten)
November 6, 2022, 1:57pm
387
yesterday i got this “history”. I would say, this prooves its uselessness.
Is there any advantage in more that a percent of usecases to get this statistical view?
parautenbach
(Pieter Rautenbach)
November 6, 2022, 1:58pm
388
Frenck, Balloob and co, if I may make a suggestion to the team: I haven’t upgraded yet, but I’m taking note of all the chatter about the Material 3 look. At this stage I’m ambivalent. My dashboards might not even be affected, and I may even like the new look. With that out of the way: The product (project/software) is quickly maturing. Perhaps consider releasing (in future) a previous look as a theme. I know it may not always technically be possible (I’ve done my fair share of web development), but it could make the journey smoother.
HeyImAlex
(Alex)
November 6, 2022, 8:56pm
389
Wait what How is that even possible that the time axis goes backwards in time at some point, with multiple values on the y-axis for the same point in time in a time series ?! There are some serious rendering or math issues with the graphing backend they use.
Edit: looks like they’re using b-splines to render the graph and the spline is overshooting horizontally due to the large gradient at the end. Not very nice, but at least it’s just the rendering. They should allow the user to specify linear gradients as an option. This here looks really weird and anormal.
lcnittl
(Christian Knittl-Frank)
November 6, 2022, 10:13pm
390
ZAMG integration has stopped working today at 06:00 for all my instances.
Same log: [homeassistant.components.zamg] Unexpected error fetching zamg data: ‘NoneType’ object has no attribute ‘get’.
I see you opened an issue already, thanks @oe3arc ( ZAMG Integration says "500 Internal Server Error Server got itself in trouble" while trying to add an new station · Issue #81664 · home-assistant/core · GitHub )
nickrout
(Nick Rout)
November 6, 2022, 10:28pm
391
that would be by design yes, as the panel mode shows the 1 allowed card on the full screen estate. It’s not a single card effectively anymore, but it should fill the full available panel.
Suppose that is the whole idea of Panel mode?
stanol
(Stanol)
November 7, 2022, 10:58am
393
I have same problem. It looks like a bug. Scrape uses default interval (10 minutes) and ignores value specified in config.
Does anyone have an idea why an update would be released but it doesn’t show as an update available in my Home Assistant? I’m currently on 2022.11.0b7 and when I hit the “check for updates” and it say “no updates available” but 2022.11 update was released on 11/2/2022.
UPDATE This must have just been a bug of some sort because I started my Home Assistant and magically the update appeared.
Michel
November 7, 2022, 6:52pm
396
I guess that is true when only using 1 card, except I use several vertical/horizontal stacks to build a dashboard view that is always full width and there the missing padding on the left side look weird now.
I guess I only started noticing with the rounder corners which makes it more obvious. Unfortunately it can not be unseen
This is the full view
Michel
November 7, 2022, 7:22pm
398
Yes it is…
Like I said a collection of stacks to get a full width layout. If there is an other way I am all ears. Full yaml for the card below in case someone is curious.
yaml config
type: vertical-stack
cards:
- type: statistics-graph
entities:
- sensor.io_9361605_rssi_level
- sensor.oximo_40_solar_rssi_level_2
- sensor.io_112058_rssi_level
- sensor.oximo_40_solar_rssi_level_3
days_to_show: 7
stat_types:
- mean
- max
- min
- type: horizontal-stack
cards:
- type: entities
entities:
- sensor.io_9361605_discrete_rssi_level
- sensor.oximo_40_solar_discrete_rssi_level_2
- sensor.io_112058_discrete_rssi_level
- sensor.oximo_40_solar_discrete_rssi_level_3
- type: entities
entities:
- type: history-graph
entities:
- entity: sensor.io_9361605_discrete_rssi_level
- entity: cover.unknown_2
- entity: sensor.oximo_40_solar_discrete_rssi_level_2
- entity: cover.unknown_3
- entity: sensor.io_112058_discrete_rssi_level
- entity: cover.unknown_5
- entity: sensor.oximo_40_solar_discrete_rssi_level_3
- entity: cover.unknown_4
hours_to_show: 168
refresh_interval: 0
cards:
- type: entities
entities:
- entity: sensor.io_9361605_battery
- entity: sensor.oximo_40_solar_battery_2
- entity: sensor.io_112058_battery
- entity: sensor.oximo_40_solar_battery_3
entities:
hours_to_show: 168
refresh_interval: 0
nickrout
(Nick Rout)
November 7, 2022, 7:26pm
399
I didn’t realise you could put cards inside the main panel card. Thank you for the education.
pabelo76
(Paweł Łucak)
November 7, 2022, 8:42pm
400
There is some problem with animated gifs and fields in custom:button-card. When fields have transparency the border appears
oe3arc
November 7, 2022, 8:51pm
401
Yes, obviously ZAMG renewed the certificats - that cured this problem.
For the other observation - “Timeout fetching zamg data”, I raised a new issue:
opened 08:47PM - 07 Nov 22 UTC
integration: zamg
### The problem
I have 3 temperature-sensors from 3 different stations. Every n… ow an then a sensor becomes unavailable for a few minutes.
The log says:
2022-11-07 12:02:45.002 ERROR (MainThread) [homeassistant.components.zamg] Timeout fetching zamg data
2022-11-07 12:02:57.003 ERROR (MainThread) [homeassistant.components.zamg] Timeout fetching zamg data
2022-11-07 18:25:17.002 ERROR (MainThread) [homeassistant.components.zamg] Timeout fetching zamg data
2022-11-07 20:15:11.003 ERROR (MainThread) [homeassistant.components.zamg] Timeout fetching zamg data
2022-11-07 21:05:08.007 ERROR (MainThread) [homeassistant.components.zamg] Timeout fetching zamg data
This is also visible on the history-chart:
![2022 11 07 Timeout fetching zamg data - diagram](https://user-images.githubusercontent.com/68684859/200411729-87be2cda-8ddd-4859-bef2-0a1f17d6ee7b.jpg)
2022.11.1
_No response_
Home Assistant OS
ZAMG
https://www.home-assistant.io/integrations/zamg/
_No response_
_No response_
_No response_
_No response_
