This is by far the worst update yet, broke my Amazon Alexa integration, statistics, Govee, and so on… I am now reeling to get things operational again… Not sure if it is worth reverting or just rebuilding from scratch …
Nothing changed with any of those platforms in this update.
Please post your errors, unless you’re just venting…
Thank you Petro, not at all, let me grab them… love to get to the bottom of this… Maybe it was something else, but so many issues popped up…
My Overview dashboard has stopped showing anything at all, this is all I get:
Error loading the view strategy:
TypeError: Cannot read properties of undefined (reading ‘name’)
There is nothing else. My customized dashboards are all working fine.
there were major changes with the frontend, you’ll have to clear your cache and refresh your page this release.
CTRL + F5 if you’re not familiar with the hotkey.
No go, cleared the cache, used firefox in private mode, etc… Still the same. Exact smae error message with no data at all. Is there a log I can share?
The normal HA logs will contain information about the frontend not loading. As there were many changes, I would assume that this is the result of a broken custom card that you use.
Dam, do you know can I search by a tag, like error…? I know that I use the Alexa HACS integration, and something serious went wrong with that. I have uninstalled it, but still stuck with nothing in the Overview dashbaord.
I suggest just sharing all your logs. I can’t help otherwise.
I am also using the Alexa Media Player integration - but haven’t noticed any issues with this one in particular.
All Dashboards are working as expected…
Sharing the complete logs would really be helpful in your case.
Don’t care about buzzwords like “error” or “debug”…
Everything seems to be messed up. I have had this before and I jsut reisntalled from scratch, takes me about 24h to get back up again.
2022-12-08 17:33:46.040 WARNING (MainThread) [homeassistant.helpers.entity] Update of sensor.ecobeeupstairs_temperature is taking over 10 seconds
2022-12-08 17:33:59.798 WARNING (SyncWorker_5) [homeassistant.components.waze_travel_time.sensor] Error on retrieving data: empty response
2022-12-08 17:34:06.040 WARNING (MainThread) [homeassistant.components.sensor] Updating ecobee sensor took longer than the scheduled update interval 0:00:30
pls. share your whole log.
what you have shared here, doesn’t look like “everything has messed up”…
but yes, it seems that there are some issues with alexa media player integration…
I am not quite sure where they are comming from - but I do have the following errors in my logs atm:
Logger: custom_components.alexa_media
Source: custom_components/alexa_media/__init__.py:533
Integration: Alexa Media Player (documentation, issues)
First occurred: 02:08:02 (4 occurrences)
Last logged: 03:08:12
Unexpected error fetching alexa_media data: argument of type 'NoneType' is not iterable
File "/usr/src/homeassistant/homeassistant/helpers/update_coordinator.py", line 225, in _async_refresh
self.data = await self._async_update_data()
File "/usr/src/homeassistant/homeassistant/helpers/update_coordinator.py", line 181, in _async_update_data
return await self.update_method()
File "/config/custom_components/alexa_media/__init__.py", line 533, in async_update_data
if "bluetoothStates" in bluetooth:
TypeError: argument of type 'NoneType' is not iterable
Source: custom_components/alexa_media/__init__.py:552
First occurred: 01:37:58 (1 occurrences)
Last logged: 01:37:58
File "/config/custom_components/alexa_media/__init__.py", line 552, in async_update_data
if "doNotDisturbDeviceStatusList" in dnd:
Source: custom_components/alexa_media/__init__.py:539
First occurred: 01:27:57 (1 occurrences)
Last logged: 01:27:57
File "/config/custom_components/alexa_media/__init__.py", line 539, in async_update_data
if "devicePreferences" in preferences:
Another issue I can see several times in combination with Alexa is about throttling…
Don’t know, if this is comming from Amazons Cloud, or from the NabuCasa Cloud…
Logger: homeassistant.components.alexa.state_report
Source: components/alexa/state_report.py:104
Integration: Amazon Alexa (documentation, issues)
First occurred: 8. Dezember 2022 um 20:39:26 (14 occurrences)
Last logged: 08:00:21
Timeout sending report to Alexa for binary_sensor.turkontakt_terrassentur_state
Timeout sending report to Alexa for climate.heizkorperthermostat_kuche
Error when sending ChangeReport for climate.heizkorperthermostat_wohnzimmer to Alexa: THROTTLING_EXCEPTION: Request could not be processed due to throttling.
Error when sending ChangeReport for climate.heizkorperthermostat_schlafzimmer to Alexa: THROTTLING_EXCEPTION: Request could not be processed due to throttling.
Error when sending ChangeReport for climate.heizkorperthermostat_wc to Alexa: THROTTLING_EXCEPTION: Request could not be processed due to throttling.
But despite of these errors in the logs, everything seems to be working as expected - and I can’t see any evidence that the above errors are related to the update at all.
So… Share your COMPLETE Logs.
Don’t just complain that “nothing is working” without any clear information that does help us to help you.
Uploading my two - somewhat obfiscated logs… Seems that I cannot attach, and am limited to 32k … so breaking up…
2022-12-08 13:33:23.496 WARNING (SyncWorker_2) [homeassistant.loader] We found a custom integration alexa_media which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2022-12-08 13:33:23.502 WARNING (SyncWorker_2) [homeassistant.loader] We found a custom integration aarlo which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2022-12-08 13:33:23.507 WARNING (SyncWorker_2) [homeassistant.loader] We found a custom integration fullykiosk which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2022-12-08 13:33:23.513 WARNING (SyncWorker_2) [homeassistant.loader] We found a custom integration alarmo which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2022-12-08 13:33:23.518 WARNING (SyncWorker_2) [homeassistant.loader] We found a custom integration reolink_rest which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2022-12-08 13:33:23.522 WARNING (SyncWorker_2) [homeassistant.loader] We found a custom integration hacs which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2022-12-08 13:33:23.526 WARNING (SyncWorker_2) [homeassistant.loader] We found a custom integration truenas which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2022-12-08 13:33:23.530 WARNING (SyncWorker_2) [homeassistant.loader] We found a custom integration ui_lovelace_minimalist which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2022-12-08 13:33:23.533 WARNING (SyncWorker_2) [homeassistant.loader] We found a custom integration emporia_vue which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2022-12-08 13:33:23.537 WARNING (SyncWorker_2) [homeassistant.loader] We found a custom integration reolink_dev which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2022-12-08 13:33:23.541 WARNING (SyncWorker_2) [homeassistant.loader] We found a custom integration reolink_discovery which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2022-12-08 13:33:23.545 WARNING (SyncWorker_2) [homeassistant.loader] We found a custom integration sonoff which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2022-12-08 13:33:23.548 WARNING (SyncWorker_2) [homeassistant.loader] We found a custom integration shelly which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2022-12-08 13:33:23.553 WARNING (SyncWorker_2) [homeassistant.loader] We found a custom integration localtuya which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2022-12-08 13:33:23.556 WARNING (SyncWorker_2) [homeassistant.loader] We found a custom integration govee which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2022-12-08 13:33:55.927 WARNING (MainThread) [homeassistant.components.sensor] Setup of sensor platform scrape is taking over 10 seconds.
2022-12-08 13:33:55.954 WARNING (MainThread) [homeassistant.components.sensor] Setup of sensor platform scrape is taking over 10 seconds.
2022-12-08 13:33:55.956 WARNING (MainThread) [homeassistant.components.sensor] Setup of sensor platform scrape is taking over 10 seconds.
2022-12-08 13:33:55.958 WARNING (MainThread) [homeassistant.components.sensor] Setup of sensor platform scrape is taking over 10 seconds.
2022-12-08 13:33:57.176 WARNING (MainThread) [homeassistant.config_entries] Config entry 'Roku Premiere 1' for roku integration not ready yet: Invalid response from API: Timeout occurred while connecting to device; Retrying in background
2022-12-08 13:33:57.761 WARNING (SyncWorker_3) [homeassistant.components.local_file.camera] Could not read camera driveway_camera image from file: /config/www/images/driveway.jpg
2022-12-08 13:33:57.864 WARNING (MainThread) [homeassistant.components.media_player] Setup of media_player platform dlna_dmr is taking over 10 seconds.
2022-12-08 13:34:01.589 WARNING (SyncWorker_7) [custom_components.truenas.truenas_api] TrueNAS X.X.X.110 unable to fetch data "update/check_available" (500)
2022-12-08 13:34:04.396 WARNING (MainThread) [custom_components.govee] API is back online.
2022-12-08 13:34:12.750 WARNING (MainThread) [homeassistant.config_entries] Config entry 'HP Color LaserJet MFP M476nw (DC5506)' for ipp integration not ready yet: Invalid response from API: Timeout occurred while connecting to IPP server.; Retrying in background
2022-12-08 13:34:14.168 WARNING (MainThread) [reolink.camera_api] Host: camera-basement.domain.local: Failed to get results for Search, JSON data was was empty?
2022-12-08 13:34:41.235 WARNING (MainThread) [homeassistant.config_entries] Config entry 'Radio Browser' for radio_browser integration not ready yet: Could not connect to Radio Browser API; Retrying in background
2022-12-08 13:34:51.940 WARNING (MainThread) [homeassistant.bootstrap] Waiting on integrations to complete setup: emporia_vue, ecobee
2022-12-08 13:35:31.591 WARNING (SyncWorker_11) [custom_components.truenas.truenas_api] TrueNAS X.X.X.110 unable to fetch data "update/check_available" (500)
2022-12-08 13:35:43.211 ERROR (MainThread) [custom_components.reolink_dev] Timeout fetching reolink.Garage.motion_states data
2022-12-08 13:35:44.196 ERROR (MainThread) [custom_components.reolink_dev] Timeout fetching reolink.Basement1.motion_states data
2022-12-08 13:35:52.048 WARNING (MainThread) [homeassistant.bootstrap] Waiting on integrations to complete setup: emporia_vue, ecobee
2022-12-08 13:36:31.592 WARNING (SyncWorker_10) [custom_components.truenas.truenas_api] TrueNAS X.X.X.110 unable to fetch data "update/check_available" (500)
2022-12-08 13:36:52.162 WARNING (MainThread) [homeassistant.bootstrap] Waiting on integrations to complete setup: emporia_vue
2022-12-08 13:37:31.594 WARNING (SyncWorker_11) [custom_components.truenas.truenas_api] TrueNAS X.X.X.110 unable to fetch data "update/check_available" (500)
2022-12-08 13:37:52.282 WARNING (MainThread) [homeassistant.bootstrap] Waiting on integrations to complete setup: emporia_vue
2022-12-08 13:38:15.492 WARNING (MainThread) [homeassistant.helpers.entity] Update of climate.ecobeeupstairs is taking over 10 seconds
2022-12-08 13:38:31.592 WARNING (SyncWorker_5) [custom_components.truenas.truenas_api] TrueNAS X.X.X.110 unable to fetch data "update/check_available" (500)
2022-12-08 13:38:45.347 WARNING (MainThread) [homeassistant.bootstrap] Setup timed out for stage 2 - moving forward
2022-12-08 13:38:52.389 WARNING (MainThread) [homeassistant.bootstrap] Waiting on integrations to complete setup: emporia_vue
2022-12-08 13:39:05.491 WARNING (MainThread) [homeassistant.components.climate] Updating ecobee climate took longer than the scheduled update interval 0:01:00
2022-12-08 13:39:31.595 WARNING (SyncWorker_9) [custom_components.truenas.truenas_api] TrueNAS X.X.X.110 unable to fetch data "update/check_available" (500)
2022-12-08 13:39:52.501 WARNING (MainThread) [homeassistant.bootstrap] Waiting on integrations to complete setup: emporia_vue
2022-12-08 13:40:31.591 WARNING (SyncWorker_2) [custom_components.truenas.truenas_api] TrueNAS X.X.X.110 unable to fetch data "update/check_available" (500)
2022-12-08 13:40:52.612 WARNING (MainThread) [homeassistant.bootstrap] Waiting on integrations to complete setup: emporia_vue
2022-12-08 13:41:15.495 WARNING (MainThread) [homeassistant.helpers.entity] Update of climate.ecobeeupstairs is taking over 10 seconds
2022-12-08 13:41:31.591 WARNING (SyncWorker_7) [custom_components.truenas.truenas_api] TrueNAS X.X.X.110 unable to fetch data "update/check_available" (500)
2022-12-08 13:41:52.718 WARNING (MainThread) [homeassistant.bootstrap] Waiting on integrations to complete setup: emporia_vue
2022-12-08 13:42:05.494 WARNING (MainThread) [homeassistant.components.climate] Updating ecobee climate took longer than the scheduled update interval 0:01:00
2022-12-08 13:42:31.591 WARNING (SyncWorker_3) [custom_components.truenas.truenas_api] TrueNAS X.X.X.110 unable to fetch data "update/check_available" (500)
2022-12-08 13:42:52.826 WARNING (MainThread) [homeassistant.bootstrap] Waiting on integrations to complete setup: emporia_vue
2022-12-08 13:43:31.591 WARNING (SyncWorker_6) [custom_components.truenas.truenas_api] TrueNAS X.X.X.110 unable to fetch data "update/check_available" (500)
2022-12-08 13:43:45.352 WARNING (MainThread) [homeassistant.bootstrap] Setup timed out for bootstrap - moving forward
2022-12-08 13:43:45.849 WARNING (SyncWorker_2) [homeassistant.components.waze_travel_time.sensor] Error on retrieving data: empty response
2022-12-08 13:43:46.511 ERROR (MainThread) [homeassistant.components.automation.demo] Home Assistant startup / shutdown messages: Choose at step 1: choice 1: Error executing script. Service not found for call_service at pos 2: Unable to find service notify.alexa_media
2022-12-08 13:43:46.677 ERROR (MainThread) [homeassistant.components.automation.demo] Home Assistant startup / shutdown messages: Error executing script. Service not found for choose at pos 1: Unable to find service notify.alexa_media
2022-12-08 13:43:55.935 ERROR (MainThread) [homeassistant.components.homeassistant_alerts] Timeout fetching homeassistant_alerts data
2022-12-08 13:44:15.543 WARNING (MainThread) [homeassistant.helpers.entity] Update of climate.ecobeeupstairs is taking over 10 seconds
2022-12-08 13:44:31.597 WARNING (SyncWorker_7) [custom_components.truenas.truenas_api] TrueNAS X.X.X.110 unable to fetch data "update/check_available" (500)
2022-12-08 13:45:05.509 WARNING (MainThread) [homeassistant.components.climate] Updating ecobee climate took longer than the scheduled update interval 0:01:00
2022-12-08 13:45:31.594 WARNING (SyncWorker_4) [custom_components.truenas.truenas_api] TrueNAS X.X.X.110 unable to fetch data "update/check_available" (500)
2022-12-08 13:46:31.593 WARNING (SyncWorker_0) [custom_components.truenas.truenas_api] TrueNAS X.X.X.110 unable to fetch data "update/check_available" (500)
2022-12-08 13:47:31.592 WARNING (SyncWorker_0) [custom_components.truenas.truenas_api] TrueNAS X.X.X.110 unable to fetch data "update/check_available" (500)
2022-12-08 13:47:45.531 WARNING (MainThread) [homeassistant.helpers.entity] Update of sensor.ecobeeupstairs_temperature is taking over 10 seconds
2022-12-08 13:48:05.527 WARNING (MainThread) [homeassistant.components.sensor] Updating ecobee sensor took longer than the scheduled update interval 0:00:30
2022-12-08 13:48:31.592 WARNING (SyncWorker_5) [custom_components.truenas.truenas_api] TrueNAS X.X.X.110 unable to fetch data "update/check_available" (500)
2022-12-08 13:48:35.527 WARNING (MainThread) [homeassistant.components.sensor] Updating ecobee sensor took longer than the scheduled update interval 0:00:30
2022-12-08 13:49:31.594 WARNING (SyncWorker_11) [custom_components.truenas.truenas_api] TrueNAS X.X.X.110 unable to fetch data "update/check_available" (500)
2022-12-08 13:50:31.595 WARNING (SyncWorker_10) [custom_components.truenas.truenas_api] TrueNAS X.X.X.110 unable to fetch data "update/check_available" (500)
2022-12-08 13:50:45.533 WARNING (MainThread) [homeassistant.helpers.entity] Update of sensor.ecobeeupstairs_temperature is taking over 10 seconds
2022-12-08 13:51:05.532 WARNING (MainThread) [homeassistant.components.sensor] Updating ecobee sensor took longer than the scheduled update interval 0:00:30
2022-12-08 13:51:31.592 WARNING (SyncWorker_5) [custom_components.truenas.truenas_api] TrueNAS X.X.X.110 unable to fetch data "update/check_available" (500)
2022-12-08 13:52:31.590 WARNING (SyncWorker_2) [custom_components.truenas.truenas_api] TrueNAS X.X.X.110 unable to fetch data "update/check_available" (500)
2022-12-08 13:53:31.591 WARNING (SyncWorker_1) [custom_components.truenas.truenas_api] TrueNAS X.X.X.110 unable to fetch data "update/check_available" (500)
2022-12-08 13:53:45.539 WARNING (MainThread) [homeassistant.helpers.entity] Update of sensor.ecobeeupstairs_temperature is taking over 10 seconds
2022-12-08 13:54:05.538 WARNING (MainThread) [homeassistant.components.sensor] Updating ecobee sensor took longer than the scheduled update interval 0:00:30
2022-12-08 13:54:31.593 WARNING (SyncWorker_6) [custom_components.truenas.truenas_api] TrueNAS X.X.X.110 unable to fetch data "update/check_available" (500)
2022-12-08 13:54:35.539 WARNING (MainThread) [homeassistant.components.sensor] Updating ecobee sensor took longer than the scheduled update interval 0:00:30
2022-12-08 13:55:31.594 WARNING (SyncWorker_6) [custom_components.truenas.truenas_api] TrueNAS X.X.X.110 unable to fetch data "update/check_available" (500)
2022-12-08 13:56:32.593 WARNING (SyncWorker_5) [custom_components.truenas.truenas_api] TrueNAS X.X.X.110 unable to fetch data "update/check_available" (500)
2022-12-08 13:56:45.544 WARNING (MainThread) [homeassistant.helpers.entity] Update of sensor.ecobeeupstairs_temperature is taking over 10 seconds
2022-12-08 13:57:05.543 WARNING (MainThread) [homeassistant.components.sensor] Updating ecobee sensor took longer than the scheduled update interval 0:00:30
2022-12-08 13:57:32.595 WARNING (SyncWorker_7) [custom_components.truenas.truenas_api] TrueNAS X.X.X.110 unable to fetch data "update/check_available" (500)
2022-12-08 13:57:35.544 WARNING (MainThread) [homeassistant.components.sensor] Updating ecobee sensor took longer than the scheduled update interval 0:00:30
2022-12-08 13:58:32.593 WARNING (SyncWorker_11) [custom_components.truenas.truenas_api] TrueNAS X.X.X.110 unable to fetch data "update/check_available" (500)
2022-12-08 13:59:15.528 ERROR (MainThread) [homeassistant.components.analytics] Timeout sending analytics to https://analytics-api.home-assistant.io/v1
2022-12-08 13:59:32.594 WARNING (SyncWorker_11) [custom_components.truenas.truenas_api] TrueNAS X.X.X.110 unable to fetch data "update/check_available" (500)
2022-12-08 13:59:45.549 WARNING (MainThread) [homeassistant.helpers.entity] Update of sensor.ecobeeupstairs_temperature is taking over 10 seconds
2022-12-08 14:00:05.549 WARNING (MainThread) [homeassistant.components.sensor] Updating ecobee sensor took longer than the scheduled update interval 0:00:30
2022-12-08 14:00:32.593 WARNING (SyncWorker_8) [custom_components.truenas.truenas_api] TrueNAS X.X.X.110 unable to fetch data "update/check_available" (500)
2022-12-08 14:00:35.550 WARNING (MainThread) [homeassistant.components.sensor] Updating ecobee sensor took longer than the scheduled update interval 0:00:30
2022-12-08 14:01:32.593 WARNING (SyncWorker_4) [custom_components.truenas.truenas_api] TrueNAS X.X.X.110 unable to fetch data "update/check_available" (500)
2022-12-08 14:02:32.593 WARNING (SyncWorker_10) [custom_components.truenas.truenas_api] TrueNAS X.X.X.110 unable to fetch data "update/check_available" (500)
2022-12-08 14:02:45.557 WARNING (MainThread) [homeassistant.helpers.entity] Update of sensor.ecobeeupstairs_temperature is taking over 10 seconds
2022-12-08 14:03:05.556 WARNING (MainThread) [homeassistant.components.sensor] Updating ecobee sensor took longer than the scheduled update interval 0:00:30
2022-12-08 14:03:32.594 WARNING (SyncWorker_10) [custom_components.truenas.truenas_api] TrueNAS X.X.X.110 unable to fetch data "update/check_available" (500)
2022-12-08 14:03:35.557 WARNING (MainThread) [homeassistant.components.sensor] Updating ecobee sensor took longer than the scheduled update interval 0:00:30
2022-12-08 14:04:09.566 WARNING (MainThread) [homeassistant.helpers.entity] Update of sensor.torsten_travel_time_to_home is taking over 10 seconds
2022-12-08 14:04:32.595 WARNING (SyncWorker_0) [custom_components.truenas.truenas_api] TrueNAS X.X.X.110 unable to fetch data "update/check_available" (500)
2022-12-08 14:05:32.595 WARNING (SyncWorker_5) [custom_components.truenas.truenas_api] TrueNAS X.X.X.110 unable to fetch data "update/check_available" (500)
2022-12-08 14:05:45.570 WARNING (MainThread) [homeassistant.helpers.entity] Update of sensor.ecobeeupstairs_temperature is taking over 10 seconds
2022-12-08 14:06:05.562 WARNING (MainThread) [homeassistant.components.sensor] Updating ecobee sensor took longer than the scheduled update interval 0:00:30
2022-12-08 14:06:32.594 WARNING (SyncWorker_0) [custom_components.truenas.truenas_api] TrueNAS X.X.X.110 unable to fetch data "update/check_available" (500)
2022-12-08 14:06:35.563 WARNING (MainThread) [homeassistant.components.sensor] Updating ecobee sensor took longer than the scheduled update interval 0:00:30
2022-12-08 14:07:32.597 WARNING (SyncWorker_12) [custom_components.truenas.truenas_api] TrueNAS X.X.X.110 unable to fetch data "update/check_available" (500)
2022-12-08 14:08:32.593 WARNING (SyncWorker_10) [custom_components.truenas.truenas_api] TrueNAS X.X.X.110 unable to fetch data "update/check_available" (500)
2022-12-08 14:08:45.568 WARNING (MainThread) [homeassistant.helpers.entity] Update of sensor.ecobeeupstairs_humidity is taking over 10 seconds
2022-12-08 14:09:05.567 WARNING (MainThread) [homeassistant.components.sensor] Updating ecobee sensor took longer than the scheduled update interval 0:00:30
2022-12-08 14:09:32.593 WARNING (SyncWorker_8) [custom_components.truenas.truenas_api] TrueNAS X.X.X.110 unable to fetch data "update/check_available" (500)
2022-12-08 14:09:35.568 WARNING (MainThread) [homeassistant.components.sensor] Updating ecobee sensor took longer than the scheduled update interval 0:00:30
2022-12-08 14:10:32.595 WARNING (SyncWorker_0) [custom_components.truenas.truenas_api] TrueNAS X.X.X.110 unable to fetch data "update/check_available" (500)
2022-12-08 14:11:32.598 WARNING (SyncWorker_10) [custom_components.truenas.truenas_api] TrueNAS X.X.X.110 unable to fetch data "update/check_available" (500)
2022-12-08 14:11:45.574 WARNING (MainThread) [homeassistant.helpers.entity] Update of sensor.ecobeeupstairs_temperature is taking over 10 seconds
2022-12-08 14:12:05.573 WARNING (MainThread) [homeassistant.components.sensor] Updating ecobee sensor took longer than the scheduled update interval 0:00:30
2022-12-08 14:12:32.597 WARNING (SyncWorker_6) [custom_components.truenas.truenas_api] TrueNAS X.X.X.110 unable to fetch data "update/check_available" (500)
2022-12-08 14:12:35.574 WARNING (MainThread) [homeassistant.components.sensor] Updating ecobee sensor took longer than the scheduled update interval 0:00:30
2022-12-08 14:13:32.591 WARNING (SyncWorker_8) [custom_components.truenas.truenas_api] TrueNAS X.X.X.110 unable to fetch data "update/check_available" (500)
2022-12-08 14:13:59.791 WARNING (SyncWorker_6) [homeassistant.components.waze_travel_time.sensor] Error on retrieving data: empty response
2022-12-08 14:14:32.596 WARNING (SyncWorker_11) [custom_components.truenas.truenas_api] TrueNAS X.X.X.110 unable to fetch data "update/check_available" (500)
2022-12-08 14:14:45.580 WARNING (MainThread) [homeassistant.helpers.entity] Update of sensor.ecobeeupstairs_temperature is taking over 10 seconds
2022-12-08 14:15:05.578 WARNING (MainThread) [homeassistant.components.sensor] Updating ecobee sensor took longer than the scheduled update interval 0:00:30
2022-12-08 14:15:32.592 WARNING (SyncWorker_2) [custom_components.truenas.truenas_api] TrueNAS X.X.X.110 unable to fetch data "update/check_available" (500)
2022-12-08 14:15:35.579 WARNING (MainThread) [homeassistant.components.sensor] Updating ecobee sensor took longer than the scheduled update interval 0:00:30
2022-12-08 14:16:32.595 WARNING (SyncWorker_4) [custom_components.truenas.truenas_api] TrueNAS X.X.X.110 unable to fetch data "update/check_available" (500)
2022-12-08 14:17:32.591 WARNING (SyncWorker_2) [custom_components.truenas.truenas_api] TrueNAS X.X.X.110 unable to fetch data "update/check_available" (500)
2022-12-08 14:17:45.586 WARNING (MainThread) [homeassistant.helpers.entity] Update of sensor.ecobeeupstairs_temperature is taking over 10 seconds
2022-12-08 14:18:05.585 WARNING (MainThread) [homeassistant.components.sensor] Updating ecobee sensor took longer than the scheduled update interval 0:00:30
2022-12-08 14:18:32.593 WARNING (SyncWorker_11) [custom_components.truenas.truenas_api] TrueNAS X.X.X.110 unable to fetch data "update/check_available" (500)
2022-12-08 14:18:35.587 WARNING (MainThread) [homeassistant.components.sensor] Updating ecobee sensor took longer than the scheduled update interval 0:00:30
2022-12-08 14:18:59.795 WARNING (SyncWorker_5) [homeassistant.components.waze_travel_time.sensor] Error on retrieving data: empty response
2022-12-08 14:19:32.597 WARNING (SyncWorker_11) [custom_components.truenas.truenas_api] TrueNAS X.X.X.110 unable to fetch data "update/check_available" (500)
2022-12-08 14:20:32.592 WARNING (SyncWorker_13) [custom_components.truenas.truenas_api] TrueNAS X.X.X.110 unable to fetch data "update/check_available" (500)
2022-12-08 14:20:45.592 WARNING (MainThread) [homeassistant.helpers.entity] Update of sensor.ecobeeupstairs_temperature is taking over 10 seconds
2022-12-08 14:21:05.591 WARNING (MainThread) [homeassistant.components.sensor] Updating ecobee sensor took longer than the scheduled update interval 0:00:30
2022-12-08 14:21:32.595 WARNING (SyncWorker_1) [custom_components.truenas.truenas_api] TrueNAS X.X.X.110 unable to fetch data "update/check_available" (500)
2022-12-08 14:21:35.593 WARNING (MainThread) [homeassistant.components.sensor] Updating ecobee sensor took longer than the scheduled update interval 0:00:30
2022-12-08 14:22:32.592 WARNING (SyncWorker_1) [custom_components.truenas.truenas_api] TrueNAS X.X.X.110 unable to fetch data "update/check_available" (500)
2022-12-08 14:23:32.593 WARNING (SyncWorker_0) [custom_components.truenas.truenas_api] TrueNAS X.X.X.110 unable to fetch data "update/check_available" (500)
2022-12-08 14:23:45.604 WARNING (MainThread) [homeassistant.helpers.entity] Update of sensor.ecobeeupstairs_temperature is taking over 10 seconds
2022-12-08 14:24:05.600 WARNING (MainThread) [homeassistant.components.sensor] Updating ecobee sensor took longer than the scheduled update interval 0:00:30
2022-12-08 14:24:13.213 ERROR (MainThread) [custom_components.reolink_dev] Timeout fetching reolink.Garage.motion_states data
2022-12-08 14:24:32.596 WARNING (SyncWorker_1) [custom_components.truenas.truenas_api] TrueNAS X.X.X.110 unable to fetch data "update/check_available" (500)
2022-12-08 14:24:35.600 WARNING (MainThread) [homeassistant.components.sensor] Updating ecobee sensor took longer than the scheduled update interval 0:00:30
2022-12-08 14:25:32.593 WARNING (SyncWorker_9) [custom_components.truenas.truenas_api] TrueNAS X.X.X.110 unable to fetch data "update/check_available" (500)
2022-12-08 14:26:32.607 WARNING (SyncWorker_6) [custom_components.truenas.truenas_api] TrueNAS X.X.X.110 unable to fetch data "update/check_available" (500)
2022-12-08 14:26:45.605 WARNING (MainThread) [homeassistant.helpers.entity] Update of sensor.ecobeeupstairs_temperature is taking over 10 seconds
2022-12-08 14:27:05.604 WARNING (MainThread) [homeassistant.components.sensor] Updating ecobee sensor took longer than the scheduled update interval 0:00:30
2022-12-08 14:27:32.592 WARNING (SyncWorker_12) [custom_components.truenas.truenas_api] TrueNAS X.X.X.110 unable to fetch data "update/check_available" (500)
2022-12-08 14:27:35.605 WARNING (MainThread) [homeassistant.components.sensor] Updating ecobee sensor took longer than the scheduled update interval 0:00:30
2022-12-08 14:28:32.601 WARNING (SyncWorker_12) [custom_components.truenas.truenas_api] TrueNAS X.X.X.110 unable to fetch data "update/check_available" (500)
2022-12-08 14:29:26.496 ERROR (MainThread) [homeassistant.components.automation.front_door_automation] Front Door Automation: Choose at step 1: choice 1: Error executing script. Service not found for call_service at pos 2: Unable to find service notify.alexa_media
2022-12-08 14:29:26.509 ERROR (MainThread) [homeassistant.components.automation.front_door_automation] Front Door Automation: Error executing script. Service not found for choose at pos 1: Unable to find service notify.alexa_media
2022-12-08 14:29:32.594 WARNING (SyncWorker_2) [custom_components.truenas.truenas_api] TrueNAS X.X.X.110 unable to fetch data "update/check_available" (500)
2022-12-08 14:29:37.763 ERROR (MainThread) [homeassistant.components.automation.front_door_automation] Front Door Automation: Choose at step 1: choice 2: Error executing script. Service not found for call_service at pos 2: Unable to find service notify.alexa_media
2022-12-08 14:29:37.769 ERROR (MainThread) [homeassistant.components.automation.front_door_automation] Front Door Automation: Error executing script. Service not found for choose at pos 1: Unable to find service notify.alexa_media
2022-12-08 14:29:45.610 WARNING (MainThread) [homeassistant.helpers.entity] Update of sensor.ecobeeupstairs_temperature is taking over 10 seconds
2022-12-08 14:30:02.852 ERROR (MainThread) [homeassistant.components.automation.driveway_motion] Driveway Motion: Choose at step 1: choice 1: Error executing script. Service not found for call_service at pos 3: Unable to find service notify.alexa_media
2022-12-08 14:30:02.855 ERROR (MainThread) [homeassistant.components.automation.driveway_motion] Driveway Motion: Error executing script. Service not found for choose at pos 1: Unable to find service notify.alexa_media
2022-12-08 14:30:05.609 WARNING (MainThread) [homeassistant.components.sensor] Updating ecobee sensor took longer than the scheduled update interval 0:00:30
2022-12-08 14:30:32.596 WARNING (SyncWorker_11) [custom_components.truenas.truenas_api] TrueNAS X.X.X.110 unable to fetch data "update/check_available" (500)
2022-12-08 14:30:35.610 WARNING (MainThread) [homeassistant.components.sensor] Updating ecobee sensor took longer than the scheduled update interval 0:00:30
2022-12-08 14:31:32.596 WARNING (SyncWorker_1) [custom_components.truenas.truenas_api] TrueNAS X.X.X.110 unable to fetch data "update/check_available" (500)
2022-12-08 14:31:42.295 ERROR (MainThread) [homeassistant.components.automation.lisa_coming_and_going] Lisa Coming and Going: Choose at step 1: choice 2: Error executing script. Service not found for call_service at pos 1: Unable to find service notify.alexa_media
2022-12-08 14:31:42.304 ERROR (MainThread) [homeassistant.components.automation.lisa_coming_and_going] Lisa Coming and Going: Error executing script. Service not found for choose at pos 1: Unable to find service notify.alexa_media
2022-12-08 14:31:54.886 ERROR (MainThread) [homeassistant.components.automation.simone_coming_and_going] Simone Coming and Going: Choose at step 1: choice 2: Error executing script. Service not found for call_service at pos 2: Unable to find service notify.alexa_media
2022-12-08 14:31:54.896 ERROR (MainThread) [homeassistant.components.automation.simone_coming_and_going] Simone Coming and Going: Error executing script. Service not found for choose at pos 1: Unable to find service notify.alexa_media
2022-12-08 14:32:32.598 WARNING (SyncWorker_3) [custom_components.truenas.truenas_api] TrueNAS X.X.X.110 unable to fetch data "update/check_available" (500)
2022-12-08 14:32:45.615 WARNING (MainThread) [homeassistant.helpers.entity] Update of sensor.ecobeeupstairs_temperature is taking over 10 seconds
2022-12-08 14:33:05.614 WARNING (MainThread) [homeassistant.components.sensor] Updating ecobee sensor took longer than the scheduled update interval 0:00:30
2022-12-08 14:33:32.603 WARNING (SyncWorker_2) [custom_components.truenas.truenas_api] TrueNAS X.X.X.110 unable to fetch data "update/check_available" (500)
2022-12-08 14:33:35.615 WARNING (MainThread) [homeassistant.components.sensor] Updating ecobee sensor took longer than the scheduled update interval 0:00:30
2022-12-08 14:34:32.596 WARNING (SyncWorker_4) [custom_components.truenas.truenas_api] TrueNAS X.X.X.110 unable to fetch data "update/check_available" (500)
2022-12-08 14:35:32.597 WARNING (SyncWorker_7) [custom_components.truenas.truenas_api] TrueNAS X.X.X.110 unable to fetch data "update/check_available" (500)
2022-12-08 14:35:45.622 WARNING (MainThread) [homeassistant.helpers.entity] Update of sensor.ecobeeupstairs_temperature is taking over 10 seconds
2022-12-08 14:36:05.621 WARNING (MainThread) [homeassistant.components.sensor] Updating ecobee sensor took longer than the scheduled update interval 0:00:30
2022-12-08 14:36:32.600 WARNING (SyncWorker_3) [custom_components.truenas.truenas_api] TrueNAS X.X.X.110 unable to fetch data "update/check_available" (500)
2022-12-08 14:36:35.622 WARNING (MainThread) [homeassistant.components.sensor] Updating ecobee sensor took longer than the scheduled update interval 0:00:30
2022-12-08 14:37:05.623 WARNING (MainThread) [homeassistant.components.sensor] Updating ecobee sensor took longer than the scheduled update interval 0:00:30
2022-12-08 14:37:32.596 WARNING (SyncWorker_6) [custom_components.truenas.truenas_api] TrueNAS X.X.X.110 unable to fetch data "update/check_available" (500)
2022-12-08 14:37:35.624 WARNING (MainThread) [homeassistant.components.sensor] Updating ecobee sensor took longer than the scheduled update interval 0:00:30
2022-12-08 14:38:05.625 WARNING (MainThread) [homeassistant.components.sensor] Updating ecobee sensor took longer than the scheduled update interval 0:00:30
2022-12-08 14:38:32.597 WARNING (SyncWorker_10) [custom_components.truenas.truenas_api] TrueNAS X.X.X.110 unable to fetch data "update/check_available" (500)
2022-12-08 14:38:35.626 WARNING (MainThread) [homeassistant.components.sensor] Updating ecobee sensor took longer than the scheduled update interval 0:00:30
2022-12-08 14:38:43.215 ERROR (MainThread) [custom_components.reolink_dev] Timeout fetching reolink.Garage.motion_states data
2022-12-08 14:38:46.450 WARNING (MainThread) [homeassistant.helpers.entity] Update of weather.ecobeeupstairs is taking over 10 seconds
2022-12-08 14:38:59.770 WARNING (SyncWorker_3) [homeassistant.components.waze_travel_time.sensor] Error on retrieving data: empty response
More…
2022-12-08 14:39:06.445 WARNING (MainThread) [homeassistant.components.weather] Updating ecobee weather took longer than the scheduled update interval 0:00:30
2022-12-08 14:39:32.598 WARNING (SyncWorker_9) [custom_components.truenas.truenas_api] TrueNAS X.X.X.110 unable to fetch data "update/check_available" (500)
2022-12-08 14:39:36.447 WARNING (MainThread) [homeassistant.components.weather] Updating ecobee weather took longer than the scheduled update interval 0:00:30
2022-12-08 14:40:32.599 WARNING (SyncWorker_6) [custom_components.truenas.truenas_api] TrueNAS X.X.X.110 unable to fetch data "update/check_available" (500)
2022-12-08 14:41:32.601 WARNING (SyncWorker_8) [custom_components.truenas.truenas_api] TrueNAS X.X.X.110 unable to fetch data "update/check_available" (500)
2022-12-08 14:41:46.452 WARNING (MainThread) [homeassistant.helpers.entity] Update of weather.ecobeeupstairs is taking over 10 seconds
2022-12-08 14:42:06.452 WARNING (MainThread) [homeassistant.components.weather] Updating ecobee weather took longer than the scheduled update interval 0:00:30
2022-12-08 14:42:32.597 WARNING (SyncWorker_10) [custom_components.truenas.truenas_api] TrueNAS X.X.X.110 unable to fetch data "update/check_available" (500)
2022-12-08 14:42:36.454 WARNING (MainThread) [homeassistant.components.weather] Updating ecobee weather took longer than the scheduled update interval 0:00:30
2022-12-08 14:43:32.600 WARNING (SyncWorker_4) [custom_components.truenas.truenas_api] TrueNAS X.X.X.110 unable to fetch data "update/check_available" (500)
2022-12-08 14:44:32.601 WARNING (SyncWorker_12) [custom_components.truenas.truenas_api] TrueNAS X.X.X.110 unable to fetch data "update/check_available" (500)
2022-12-08 14:44:46.462 WARNING (MainThread) [homeassistant.helpers.entity] Update of weather.ecobeeupstairs is taking over 10 seconds
2022-12-08 14:45:06.460 WARNING (MainThread) [homeassistant.components.weather] Updating ecobee weather took longer than the scheduled update interval 0:00:30
2022-12-08 14:45:32.598 WARNING (SyncWorker_11) [custom_components.truenas.truenas_api] TrueNAS X.X.X.110 unable to fetch data "update/check_available" (500)
2022-12-08 14:45:36.461 WARNING (MainThread) [homeassistant.components.weather] Updating ecobee weather took longer than the scheduled update interval 0:00:30
2022-12-08 14:46:32.600 WARNING (SyncWorker_5) [custom_components.truenas.truenas_api] TrueNAS X.X.X.110 unable to fetch data "update/check_available" (500)
2022-12-08 14:47:32.603 WARNING (SyncWorker_4) [custom_components.truenas.truenas_api] TrueNAS X.X.X.110 unable to fetch data "update/check_available" (500)
2022-12-08 14:47:46.474 WARNING (MainThread) [homeassistant.helpers.entity] Update of weather.ecobeeupstairs is taking over 10 seconds
2022-12-08 14:48:06.475 WARNING (MainThread) [homeassistant.components.weather] Updating ecobee weather took longer than the scheduled update interval 0:00:30
2022-12-08 14:48:32.603 WARNING (SyncWorker_3) [custom_components.truenas.truenas_api] TrueNAS X.X.X.110 unable to fetch data "update/check_available" (500)
2022-12-08 14:48:36.476 WARNING (MainThread) [homeassistant.components.weather] Updating ecobee weather took longer than the scheduled update interval 0:00:30
2022-12-08 14:48:59.757 WARNING (SyncWorker_8) [homeassistant.components.waze_travel_time.sensor] Error on retrieving data: empty response
2022-12-08 14:49:09.577 WARNING (MainThread) [homeassistant.helpers.entity] Update of sensor.lisa_travel_time_to_home is taking over 10 seconds
2022-12-08 14:49:32.600 WARNING (SyncWorker_5) [custom_components.truenas.truenas_api] TrueNAS X.X.X.110 unable to fetch data "update/check_available" (500)
2022-12-08 14:50:32.601 WARNING (SyncWorker_3) [custom_components.truenas.truenas_api] TrueNAS X.X.X.110 unable to fetch data "update/check_available" (500)
2022-12-08 14:50:46.483 WARNING (MainThread) [homeassistant.helpers.entity] Update of weather.ecobeeupstairs is taking over 10 seconds
2022-12-08 14:51:06.482 WARNING (MainThread) [homeassistant.components.weather] Updating ecobee weather took longer than the scheduled update interval 0:00:30
2022-12-08 14:51:32.605 WARNING (SyncWorker_13) [custom_components.truenas.truenas_api] TrueNAS X.X.X.110 unable to fetch data "update/check_available" (500)
2022-12-08 14:51:36.483 WARNING (MainThread) [homeassistant.components.weather] Updating ecobee weather took longer than the scheduled update interval 0:00:30
2022-12-08 14:52:32.604 WARNING (SyncWorker_4) [custom_components.truenas.truenas_api] TrueNAS X.X.X.110 unable to fetch data "update/check_available" (500)
2022-12-08 14:53:32.607 WARNING (SyncWorker_11) [custom_components.truenas.truenas_api] TrueNAS X.X.X.110 unable to fetch data "update/check_available" (500)
2022-12-08 14:53:46.489 WARNING (MainThread) [homeassistant.helpers.entity] Update of weather.ecobeeupstairs is taking over 10 seconds
2022-12-08 14:54:06.487 WARNING (MainThread) [homeassistant.components.weather] Updating ecobee weather took longer than the scheduled update interval 0:00:30
2022-12-08 14:54:32.603 WARNING (SyncWorker_2) [custom_components.truenas.truenas_api] TrueNAS X.X.X.110 unable to fetch data "update/check_available" (500)
2022-12-08 14:54:36.488 WARNING (MainThread) [homeassistant.components.weather] Updating ecobee weather took longer than the scheduled update interval 0:00:30
2022-12-08 14:55:32.604 WARNING (SyncWorker_1) [custom_components.truenas.truenas_api] TrueNAS X.X.X.110 unable to fetch data "update/check_available" (500)
2022-12-08 14:56:32.604 WARNING (SyncWorker_4) [custom_components.truenas.truenas_api] TrueNAS X.X.X.110 unable to fetch data "update/check_available" (500)
2022-12-08 14:56:46.493 WARNING (MainThread) [homeassistant.helpers.entity] Update of weather.ecobeeupstairs is taking over 10 seconds
2022-12-08 14:57:06.493 WARNING (MainThread) [homeassistant.components.weather] Updating ecobee weather took longer than the scheduled update interval 0:00:30
2022-12-08 14:57:32.607 WARNING (SyncWorker_7) [custom_components.truenas.truenas_api] TrueNAS X.X.X.110 unable to fetch data "update/check_available" (500)
2022-12-08 14:57:36.494 WARNING (MainThread) [homeassistant.components.weather] Updating ecobee weather took longer than the scheduled update interval 0:00:30
2022-12-08 14:58:32.606 WARNING (SyncWorker_11) [custom_components.truenas.truenas_api] TrueNAS X.X.X.110 unable to fetch data "update/check_available" (500)
2022-12-08 14:59:32.603 WARNING (SyncWorker_12) [custom_components.truenas.truenas_api] TrueNAS X.X.X.110 unable to fetch data "update/check_available" (500)
2022-12-08 14:59:46.516 WARNING (MainThread) [homeassistant.helpers.entity] Update of weather.ecobeeupstairs is taking over 10 seconds
2022-12-08 15:00:06.499 WARNING (MainThread) [homeassistant.components.weather] Updating ecobee weather took longer than the scheduled update interval 0:00:30
2022-12-08 15:00:32.608 WARNING (SyncWorker_2) [custom_components.truenas.truenas_api] TrueNAS X.X.X.110 unable to fetch data "update/check_available" (500)
2022-12-08 15:00:36.501 WARNING (MainThread) [homeassistant.components.weather] Updating ecobee weather took longer than the scheduled update interval 0:00:30
2022-12-08 15:01:32.610 WARNING (SyncWorker_8) [custom_components.truenas.truenas_api] TrueNAS X.X.X.110 unable to fetch data "update/check_available" (500)
2022-12-08 15:02:32.608 WARNING (SyncWorker_6) [custom_components.truenas.truenas_api] TrueNAS X.X.X.110 unable to fetch data "update/check_available" (500)
2022-12-08 15:02:46.507 WARNING (MainThread) [homeassistant.helpers.entity] Update of weather.ecobeeupstairs is taking over 10 seconds
2022-12-08 15:03:06.507 WARNING (MainThread) [homeassistant.components.weather] Updating ecobee weather took longer than the scheduled update interval 0:00:30
2022-12-08 15:03:32.606 WARNING (SyncWorker_3) [custom_components.truenas.truenas_api] TrueNAS X.X.X.110 unable to fetch data "update/check_available" (500)
2022-12-08 15:03:36.508 WARNING (MainThread) [homeassistant.components.weather] Updating ecobee weather took longer than the scheduled update interval 0:00:30
2022-12-08 15:04:32.609 WARNING (SyncWorker_4) [custom_components.truenas.truenas_api] TrueNAS X.X.X.110 unable to fetch data "update/check_available" (500)
2022-12-08 15:05:32.609 WARNING (SyncWorker_9) [custom_components.truenas.truenas_api] TrueNAS X.X.X.110 unable to fetch data "update/check_available" (500)
2022-12-08 15:05:46.515 WARNING (MainThread) [homeassistant.helpers.entity] Update of weather.ecobeeupstairs is taking over 10 seconds
2022-12-08 15:06:06.513 WARNING (MainThread) [homeassistant.components.weather] Updating ecobee weather took longer than the scheduled update interval 0:00:30
2022-12-08 15:06:32.605 WARNING (SyncWorker_9) [custom_components.truenas.truenas_api] TrueNAS X.X.X.110 unable to fetch data "update/check_available" (500)
2022-12-08 15:06:36.516 WARNING (MainThread) [homeassistant.components.weather] Updating ecobee weather took longer than the scheduled update interval 0:00:30
2022-12-08 15:06:39.458 ERROR (MainThread) [frontend.js.latest.202212070] http://hass.domain.local:8123/diesel-1/0:0:0 Uncaught
2022-12-08 15:07:32.609 WARNING (SyncWorker_9) [custom_components.truenas.truenas_api] TrueNAS X.X.X.110 unable to fetch data "update/check_available" (500)
2022-12-08 15:08:32.610 WARNING (SyncWorker_7) [custom_components.truenas.truenas_api] TrueNAS X.X.X.110 unable to fetch data "update/check_available" (500)
2022-12-08 15:08:46.523 WARNING (MainThread) [homeassistant.helpers.entity] Update of weather.ecobeeupstairs is taking over 10 seconds
2022-12-08 15:09:06.523 WARNING (MainThread) [homeassistant.components.weather] Updating ecobee weather took longer than the scheduled update interval 0:00:30
2022-12-08 15:09:32.606 WARNING (SyncWorker_4) [custom_components.truenas.truenas_api] TrueNAS X.X.X.110 unable to fetch data "update/check_available" (500)
2022-12-08 15:09:36.525 WARNING (MainThread) [homeassistant.components.weather] Updating ecobee weather took longer than the scheduled update interval 0:00:30
2022-12-08 15:10:32.611 WARNING (SyncWorker_1) [custom_components.truenas.truenas_api] TrueNAS X.X.X.110 unable to fetch data "update/check_available" (500)
2022-12-08 15:11:32.610 WARNING (SyncWorker_3) [custom_components.truenas.truenas_api] TrueNAS X.X.X.110 unable to fetch data "update/check_available" (500)
2022-12-08 15:11:46.530 WARNING (MainThread) [homeassistant.helpers.entity] Update of weather.ecobeeupstairs is taking over 10 seconds
2022-12-08 15:12:06.530 WARNING (MainThread) [homeassistant.components.weather] Updating ecobee weather took longer than the scheduled update interval 0:00:30
2022-12-08 15:12:32.608 WARNING (SyncWorker_5) [custom_components.truenas.truenas_api] TrueNAS X.X.X.110 unable to fetch data "update/check_available" (500)
2022-12-08 15:12:36.530 WARNING (MainThread) [homeassistant.components.weather] Updating ecobee weather took longer than the scheduled update interval 0:00:30
2022-12-08 15:13:32.610 WARNING (SyncWorker_10) [custom_components.truenas.truenas_api] TrueNAS X.X.X.110 unable to fetch data "update/check_available" (500)
2022-12-08 15:14:32.609 WARNING (SyncWorker_12) [custom_components.truenas.truenas_api] TrueNAS X.X.X.110 unable to fetch data "update/check_available" (500)
2022-12-08 15:14:46.536 WARNING (MainThread) [homeassistant.helpers.entity] Update of weather.ecobeeupstairs is taking over 10 seconds
2022-12-08 15:15:06.535 WARNING (MainThread) [homeassistant.components.weather] Updating ecobee weather took longer than the scheduled update interval 0:00:30
2022-12-08 15:15:32.608 WARNING (SyncWorker_13) [custom_components.truenas.truenas_api] TrueNAS X.X.X.110 unable to fetch data "update/check_available" (500)
2022-12-08 15:15:36.537 WARNING (MainThread) [homeassistant.components.weather] Updating ecobee weather took longer than the scheduled update interval 0:00:30
2022-12-08 15:16:32.604 WARNING (SyncWorker_4) [custom_components.truenas.truenas_api] TrueNAS X.X.X.110 unable to fetch data "update/check_available" (500)
2022-12-08 15:17:32.599 WARNING (SyncWorker_12) [custom_components.truenas.truenas_api] TrueNAS X.X.X.110 unable to fetch data "update/check_available" (500)
2022-12-08 15:17:46.543 WARNING (MainThread) [homeassistant.helpers.entity] Update of weather.ecobeeupstairs is taking over 10 seconds
2022-12-08 15:18:06.542 WARNING (MainThread) [homeassistant.components.weather] Updating ecobee weather took longer than the scheduled update interval 0:00:30
2022-12-08 15:18:32.601 WARNING (SyncWorker_9) [custom_components.truenas.truenas_api] TrueNAS X.X.X.110 unable to fetch data "update/check_available" (500)
2022-12-08 15:18:36.543 WARNING (MainThread) [homeassistant.components.weather] Updating ecobee weather took longer than the scheduled update interval 0:00:30
2022-12-08 15:19:32.599 WARNING (SyncWorker_11) [custom_components.truenas.truenas_api] TrueNAS X.X.X.110 unable to fetch data "update/check_available" (500)
2022-12-08 15:20:32.596 WARNING (SyncWorker_10) [custom_components.truenas.truenas_api] TrueNAS X.X.X.110 unable to fetch data "update/check_available" (500)
2022-12-08 15:20:46.548 WARNING (MainThread) [homeassistant.helpers.entity] Update of weather.ecobeeupstairs is taking over 10 seconds
2022-12-08 15:21:06.548 WARNING (MainThread) [homeassistant.components.weather] Updating ecobee weather took longer than the scheduled update interval 0:00:30
2022-12-08 15:21:32.598 WARNING (SyncWorker_6) [custom_components.truenas.truenas_api] TrueNAS X.X.X.110 unable to fetch data "update/check_available" (500)
2022-12-08 15:21:36.549 WARNING (MainThread) [homeassistant.components.weather] Updating ecobee weather took longer than the scheduled update interval 0:00:30
2022-12-08 15:22:32.597 WARNING (SyncWorker_5) [custom_components.truenas.truenas_api] TrueNAS X.X.X.110 unable to fetch data "update/check_available" (500)
2022-12-08 15:23:32.597 WARNING (SyncWorker_10) [custom_components.truenas.truenas_api] TrueNAS X.X.X.110 unable to fetch data "update/check_available" (500)
2022-12-08 15:23:46.556 WARNING (MainThread) [homeassistant.helpers.entity] Update of weather.ecobeeupstairs is taking over 10 seconds
2022-12-08 15:23:59.744 WARNING (SyncWorker_8) [homeassistant.components.waze_travel_time.sensor] Error on retrieving data: empty response
2022-12-08 15:23:59.752 WARNING (SyncWorker_1) [homeassistant.components.waze_travel_time.sensor] Error on retrieving data: empty response
2022-12-08 15:24:06.556 WARNING (MainThread) [homeassistant.components.weather] Updating ecobee weather took longer than the scheduled update interval 0:00:30
2022-12-08 15:24:32.594 WARNING (SyncWorker_5) [custom_components.truenas.truenas_api] TrueNAS X.X.X.110 unable to fetch data "update/check_available" (500)
2022-12-08 15:24:36.557 WARNING (MainThread) [homeassistant.components.weather] Updating ecobee weather took longer than the scheduled update interval 0:00:30
2022-12-08 15:25:32.591 WARNING (SyncWorker_11) [custom_components.truenas.truenas_api] TrueNAS X.X.X.110 unable to fetch data "update/check_available" (500)
2022-12-08 15:26:32.593 WARNING (SyncWorker_4) [custom_components.truenas.truenas_api] TrueNAS X.X.X.110 unable to fetch data "update/check_available" (500)
2022-12-08 15:26:46.563 WARNING (MainThread) [homeassistant.helpers.entity] Update of weather.ecobeeupstairs is taking over 10 seconds
2022-12-08 15:27:06.562 WARNING (MainThread) [homeassistant.components.weather] Updating ecobee weather took longer than the scheduled update interval 0:00:30
2022-12-08 15:27:32.591 WARNING (SyncWorker_10) [custom_components.truenas.truenas_api] TrueNAS X.X.X.110 unable to fetch data "update/check_available" (500)
2022-12-08 15:27:36.564 WARNING (MainThread) [homeassistant.components.weather] Updating ecobee weather took longer than the scheduled update interval 0:00:30
2022-12-08 15:28:32.595 WARNING (SyncWorker_0) [custom_components.truenas.truenas_api] TrueNAS X.X.X.110 unable to fetch data "update/check_available" (500)
2022-12-08 15:29:32.593 WARNING (SyncWorker_9) [custom_components.truenas.truenas_api] TrueNAS X.X.X.110 unable to fetch data "update/check_available" (500)
2022-12-08 15:29:46.570 WARNING (MainThread) [homeassistant.helpers.entity] Update of weather.ecobeeupstairs is taking over 10 seconds
2022-12-08 15:30:06.569 WARNING (MainThread) [homeassistant.components.weather] Updating ecobee weather took longer than the scheduled update interval 0:00:30
2022-12-08 15:30:32.592 WARNING (SyncWorker_11) [custom_components.truenas.truenas_api] TrueNAS X.X.X.110 unable to fetch data "update/check_available" (500)
2022-12-08 15:30:36.570 WARNING (MainThread) [homeassistant.components.weather] Updating ecobee weather took longer than the scheduled update interval 0:00:30
2022-12-08 15:31:32.590 WARNING (SyncWorker_3) [custom_components.truenas.truenas_api] TrueNAS X.X.X.110 unable to fetch data "update/check_available" (500)
2022-12-08 15:32:32.588 WARNING (SyncWorker_6) [custom_components.truenas.truenas_api] TrueNAS X.X.X.110 unable to fetch data "update/check_available" (500)
2022-12-08 15:32:46.576 WARNING (MainThread) [homeassistant.helpers.entity] Update of weather.ecobeeupstairs is taking over 10 seconds
2022-12-08 15:33:06.575 WARNING (MainThread) [homeassistant.components.weather] Updating ecobee weather took longer than the scheduled update interval 0:00:30
2022-12-08 15:33:32.589 WARNING (SyncWorker_6) [custom_components.truenas.truenas_api] TrueNAS X.X.X.110 unable to fetch data "update/check_available" (500)
2022-12-08 15:33:36.576 WARNING (MainThread) [homeassistant.components.weather] Updating ecobee weather took longer than the scheduled update interval 0:00:30
2022-12-08 15:34:09.610 WARNING (MainThread) [homeassistant.helpers.entity] Update of sensor.torsten_travel_time_to_home is taking over 10 seconds
2022-12-08 15:34:32.590 WARNING (SyncWorker_11) [custom_components.truenas.truenas_api] TrueNAS X.X.X.110 unable to fetch data "update/check_available" (500)
2022-12-08 15:35:32.584 WARNING (SyncWorker_1) [custom_components.truenas.truenas_api] TrueNAS X.X.X.110 unable to fetch data "update/check_available" (500)
2022-12-08 15:35:46.584 WARNING (MainThread) [homeassistant.helpers.entity] Update of weather.ecobeeupstairs is taking over 10 seconds
2022-12-08 15:36:06.582 WARNING (MainThread) [homeassistant.components.weather] Updating ecobee weather took longer than the scheduled update interval 0:00:30
2022-12-08 15:36:32.587 WARNING (SyncWorker_8) [custom_components.truenas.truenas_api] TrueNAS X.X.X.110 unable to fetch data "update/check_available" (500)
2022-12-08 15:36:36.583 WARNING (MainThread) [homeassistant.components.weather] Updating ecobee weather took longer than the scheduled update interval 0:00:30
2022-12-08 15:37:32.588 WARNING (SyncWorker_5) [custom_components.truenas.truenas_api] TrueNAS X.X.X.110 unable to fetch data "update/check_available" (500)
2022-12-08 15:38:32.586 WARNING (SyncWorker_3) [custom_components.truenas.truenas_api] TrueNAS X.X.X.110 unable to fetch data "update/check_available" (500)
2022-12-08 15:38:46.589 WARNING (MainThread) [homeassistant.helpers.entity] Update of weather.ecobeeupstairs is taking over 10 seconds
2022-12-08 15:39:06.588 WARNING (MainThread) [homeassistant.components.weather] Updating ecobee weather took longer than the scheduled update interval 0:00:30
2022-12-08 15:39:32.588 WARNING (SyncWorker_0) [custom_components.truenas.truenas_api] TrueNAS X.X.X.110 unable to fetch data "update/check_available" (500)
2022-12-08 15:39:36.589 WARNING (MainThread) [homeassistant.components.weather] Updating ecobee weather took longer than the scheduled update interval 0:00:30
2022-12-08 15:40:06.590 WARNING (MainThread) [homeassistant.components.weather] Updating ecobee weather took longer than the scheduled update interval 0:00:30
2022-12-08 15:40:32.588 WARNING (SyncWorker_7) [custom_components.truenas.truenas_api] TrueNAS X.X.X.110 unable to fetch data "update/check_available" (500)
2022-12-08 15:40:36.591 WARNING (MainThread) [homeassistant.components.weather] Updating ecobee weather took longer than the scheduled update interval 0:00:30
2022-12-08 15:40:53.658 ERROR (MainThread) [homeassistant.components.automation.driveway_motion] Driveway Motion: Choose at step 1: choice 1: Error executing script. Service not found for call_service at pos 3: Unable to find service notify.alexa_media
2022-12-08 15:40:53.661 ERROR (MainThread) [homeassistant.components.automation.driveway_motion] Driveway Motion: Error executing script. Service not found for choose at pos 1: Unable to find service notify.alexa_media
2022-12-08 15:41:06.592 WARNING (MainThread) [homeassistant.components.weather] Updating ecobee weather took longer than the scheduled update interval 0:00:30
2022-12-08 15:41:32.588 WARNING (SyncWorker_7) [custom_components.truenas.truenas_api] TrueNAS X.X.X.110 unable to fetch data "update/check_available" (500)
2022-12-08 15:41:36.593 WARNING (MainThread) [homeassistant.components.weather] Updating ecobee weather took longer than the scheduled update interval 0:00:30
2022-12-08 15:42:15.640 WARNING (MainThread) [homeassistant.helpers.entity] Update of climate.ecobeeupstairs is taking over 10 seconds
2022-12-08 15:42:32.590 WARNING (SyncWorker_3) [custom_components.truenas.truenas_api] TrueNAS X.X.X.110 unable to fetch data "update/check_available" (500)
2022-12-08 15:43:05.640 WARNING (MainThread) [homeassistant.components.climate] Updating ecobee climate took longer than the scheduled update interval 0:01:00
2022-12-08 15:43:32.588 WARNING (SyncWorker_3) [custom_components.truenas.truenas_api] TrueNAS X.X.X.110 unable to fetch data "update/check_available" (500)
2022-12-08 15:44:32.588 WARNING (SyncWorker_1) [custom_components.truenas.truenas_api] TrueNAS X.X.X.110 unable to fetch data "update/check_available" (500)
2022-12-08 15:45:15.643 WARNING (MainThread) [homeassistant.helpers.entity] Update of climate.ecobeeupstairs is taking over 10 seconds
2022-12-08 15:45:32.589 WARNING (SyncWorker_12) [custom_components.truenas.truenas_api] TrueNAS X.X.X.110 unable to fetch data "update/check_available" (500)
2022-12-08 15:46:05.643 WARNING (MainThread) [homeassistant.components.climate] Updating ecobee climate took longer than the scheduled update interval 0:01:00
2022-12-08 15:46:32.583 WARNING (SyncWorker_2) [custom_components.truenas.truenas_api] TrueNAS X.X.X.110 unable to fetch data "update/check_available" (500)
2022-12-08 15:47:32.588 WARNING (SyncWorker_4) [custom_components.truenas.truenas_api] TrueNAS X.X.X.110 unable to fetch data "update/check_available" (500)
2022-12-08 15:48:15.648 WARNING (MainThread) [homeassistant.helpers.entity] Update of climate.ecobeeupstairs is taking over 10 seconds
2022-12-08 15:48:32.584 WARNING (SyncWorker_2) [custom_components.truenas.truenas_api] TrueNAS X.X.X.110 unable to fetch data "update/check_available" (500)
2022-12-08 15:49:05.646 WARNING (MainThread) [homeassistant.components.climate] Updating ecobee climate took longer than the scheduled update interval 0:01:00
2022-12-08 15:49:32.587 WARNING (SyncWorker_7) [custom_components.truenas.truenas_api] TrueNAS X.X.X.110 unable to fetch data "update/check_available" (500)
2022-12-08 15:50:32.589 WARNING (SyncWorker_12) [custom_components.truenas.truenas_api] TrueNAS X.X.X.110 unable to fetch data "update/check_available" (500)
2022-12-08 15:51:15.648 WARNING (MainThread) [homeassistant.helpers.entity] Update of climate.ecobeeupstairs is taking over 10 seconds
2022-12-08 15:51:32.587 WARNING (SyncWorker_12) [custom_components.truenas.truenas_api] TrueNAS X.X.X.110 unable to fetch data "update/check_available" (500)
2022-12-08 15:52:05.648 WARNING (MainThread) [homeassistant.components.climate] Updating ecobee climate took longer than the scheduled update interval 0:01:00
2022-12-08 15:52:32.586 WARNING (SyncWorker_1) [custom_components.truenas.truenas_api] TrueNAS X.X.X.110 unable to fetch data "update/check_available" (500)
2022-12-08 15:53:32.589 WARNING (SyncWorker_5) [custom_components.truenas.truenas_api] TrueNAS X.X.X.110 unable to fetch data "update/check_available" (500)
2022-12-08 15:54:09.595 WARNING (MainThread) [homeassistant.helpers.entity] Update of sensor.jason_travel_time_to_home is taking over 10 seconds
2022-12-08 15:54:15.656 WARNING (MainThread) [homeassistant.helpers.entity] Update of climate.ecobeeupstairs is taking over 10 seconds
2022-12-08 15:54:32.583 WARNING (SyncWorker_1) [custom_components.truenas.truenas_api] TrueNAS X.X.X.110 unable to fetch data "update/check_available" (500)
2022-12-08 15:55:05.651 WARNING (MainThread) [homeassistant.components.climate] Updating ecobee climate took longer than the scheduled update interval 0:01:00
2022-12-08 15:55:32.589 WARNING (SyncWorker_5) [custom_components.truenas.truenas_api] TrueNAS X.X.X.110 unable to fetch data "update/check_available" (500)
2022-12-08 15:56:32.586 WARNING (SyncWorker_13) [custom_components.truenas.truenas_api] TrueNAS X.X.X.110 unable to fetch data "update/check_available" (500)
2022-12-08 15:57:15.655 WARNING (MainThread) [homeassistant.helpers.entity] Update of climate.ecobeeupstairs is taking over 10 seconds
2022-12-08 15:57:32.588 WARNING (SyncWorker_4) [custom_components.truenas.truenas_api] TrueNAS X.X.X.110 unable to fetch data "update/check_available" (500)
2022-12-08 15:58:05.654 WARNING (MainThread) [homeassistant.components.climate] Updating ecobee climate took longer than the scheduled update interval 0:01:00
2022-12-08 15:58:32.584 WARNING (SyncWorker_11) [custom_components.truenas.truenas_api] TrueNAS X.X.X.110 unable to fetch data "update/check_available" (500)
2022-12-08 15:58:59.785 WARNING (SyncWorker_0) [homeassistant.components.waze_travel_time.sensor] Error on retrieving data: empty response
2022-12-08 15:59:09.632 WARNING (MainThread) [homeassistant.helpers.entity] Update of sensor.simone_travel_time_to_home is taking over 10 seconds
2022-12-08 15:59:32.584 WARNING (SyncWorker_1) [custom_components.truenas.truenas_api] TrueNAS X.X.X.110 unable to fetch data "update/check_available" (500)
2022-12-08 16:00:15.663 WARNING (MainThread) [homeassistant.helpers.entity] Update of climate.ecobeeupstairs is taking over 10 seconds
2022-12-08 16:00:32.584 WARNING (SyncWorker_2) [custom_components.truenas.truenas_api] TrueNAS X.X.X.110 unable to fetch data "update/check_available" (500)
2022-12-08 16:01:05.657 WARNING (MainThread) [homeassistant.components.climate] Updating ecobee climate took longer than the scheduled update interval 0:01:00
2022-12-08 16:01:33.588 WARNING (SyncWorker_10) [custom_components.truenas.truenas_api] TrueNAS X.X.X.110 unable to fetch data "update/check_available" (500)
2022-12-08 16:02:32.585 WARNING (SyncWorker_11) [custom_components.truenas.truenas_api] TrueNAS X.X.X.110 unable to fetch data "update/check_available" (500)
2022-12-08 16:03:15.660 WARNING (MainThread) [homeassistant.helpers.entity] Update of climate.ecobeeupstairs is taking over 10 seconds
2022-12-08 16:03:32.582 WARNING (SyncWorker_5) [custom_components.truenas.truenas_api] TrueNAS X.X.X.110 unable to fetch data "update/check_available" (500)
2022-12-08 16:03:59.765 WARNING (SyncWorker_7) [homeassistant.components.waze_travel_time.sensor] Error on retrieving data: empty response
2022-12-08 16:04:05.658 WARNING (MainThread) [homeassistant.components.climate] Updating ecobee climate took longer than the scheduled update interval 0:01:00
2022-12-08 16:04:32.589 WARNING (SyncWorker_2) [custom_components.truenas.truenas_api] TrueNAS X.X.X.110 unable to fetch data "update/check_available" (500)
2022-12-08 16:05:32.582 WARNING (SyncWorker_8) [custom_components.truenas.truenas_api] TrueNAS X.X.X.110 unable to fetch data "update/check_available" (500)
2022-12-08 16:06:15.663 WARNING (MainThread) [homeassistant.helpers.entity] Update of climate.ecobeeupstairs is taking over 10 seconds
2022-12-08 16:06:32.583 WARNING (SyncWorker_12) [custom_components.truenas.truenas_api] TrueNAS X.X.X.110 unable to fetch data "update/check_available" (500)
2022-12-08 16:07:05.661 WARNING (MainThread) [homeassistant.components.climate] Updating ecobee climate took longer than the scheduled update interval 0:01:00
2022-12-08 16:07:32.584 WARNING (SyncWorker_12) [custom_components.truenas.truenas_api] TrueNAS X.X.X.110 unable to fetch data "update/check_available" (500)
2022-12-08 16:08:32.588 WARNING (SyncWorker_0) [custom_components.truenas.truenas_api] TrueNAS X.X.X.110 unable to fetch data "update/check_available" (500)
2022-12-08 16:09:15.680 WARNING (MainThread) [homeassistant.helpers.entity] Update of climate.ecobeeupstairs is taking over 10 seconds
2022-12-08 16:09:32.583 WARNING (SyncWorker_2) [custom_components.truenas.truenas_api] TrueNAS X.X.X.110 unable to fetch data "update/check_available" (500)
2022-12-08 16:10:05.664 WARNING (MainThread) [homeassistant.components.climate] Updating ecobee climate took longer than the scheduled update interval 0:01:00
2022-12-08 16:10:32.583 WARNING (SyncWorker_7) [custom_components.truenas.truenas_api] TrueNAS X.X.X.110 unable to fetch data "update/check_available" (500)
2022-12-08 16:11:32.586 WARNING (SyncWorker_2) [custom_components.truenas.truenas_api] TrueNAS X.X.X.110 unable to fetch data "update/check_available" (500)
2022-12-08 16:12:15.667 WARNING (MainThread) [homeassistant.helpers.entity] Update of climate.ecobeeupstairs is taking over 10 seconds
2022-12-08 16:12:32.582 WARNING (SyncWorker_7) [custom_components.truenas.truenas_api] TrueNAS X.X.X.110 unable to fetch data "update/check_available" (500)
2022-12-08 16:13:02.584 ERROR (MainThread) [homeassistant.components.automation.lisa_coming_and_going] Lisa Coming and Going: Choose at step 1: choice 3: Error executing script. Service not found for call_service at pos 1: Unable to find service notify.alexa_media
2022-12-08 16:13:02.590 ERROR (MainThread) [homeassistant.components.automation.lisa_coming_and_going] Lisa Coming and Going: Error executing script. Service not found for choose at pos 1: Unable to find service notify.alexa_media
2022-12-08 16:13:05.667 WARNING (MainThread) [homeassistant.components.climate] Updating ecobee climate took longer than the scheduled update interval 0:01:00
2022-12-08 16:13:13.997 ERROR (MainThread) [homeassistant.components.automation.simone_coming_and_going] Simone Coming and Going: Choose at step 1: choice 3: Error executing script. Service not found for call_service at pos 2: Unable to find service notify.alexa_media
2022-12-08 16:13:14.009 ERROR (MainThread) [homeassistant.components.automation.simone_coming_and_going] Simone Coming and Going: Error executing script. Service not found for choose at pos 1: Unable to find service notify.alexa_media
2022-12-08 16:13:32.581 WARNING (SyncWorker_0) [custom_components.truenas.truenas_api] TrueNAS X.X.X.110 unable to fetch data "update/check_available" (500)
2022-12-08 16:13:59.763 WARNING (SyncWorker_11) [homeassistant.components.waze_travel_time.sensor] Error on retrieving data: empty response
2022-12-08 16:14:32.583 WARNING (SyncWorker_2) [custom_components.truenas.truenas_api] TrueNAS X.X.X.110 unable to fetch data "update/check_available" (500)
2022-12-08 16:15:15.681 WARNING (MainThread) [homeassistant.helpers.entity] Update of climate.ecobeeupstairs is taking over 10 seconds
2022-12-08 16:15:32.581 WARNING (SyncWorker_7) [custom_components.truenas.truenas_api] TrueNAS X.X.X.110 unable to fetch data "update/check_available" (500)
2022-12-08 16:16:05.669 WARNING (MainThread) [homeassistant.components.climate] Updating ecobee climate took longer than the scheduled update interval 0:01:00
More
2022-12-08 16:17:32.587 WARNING (SyncWorker_0) [custom_components.truenas.truenas_api] TrueNAS X.X.X.110 unable to fetch data "update/check_available" (500)
2022-12-08 16:18:15.672 WARNING (MainThread) [homeassistant.helpers.entity] Update of climate.ecobeeupstairs is taking over 10 seconds
2022-12-08 16:18:32.584 WARNING (SyncWorker_11) [custom_components.truenas.truenas_api] TrueNAS X.X.X.110 unable to fetch data "update/check_available" (500)
2022-12-08 16:19:05.671 WARNING (MainThread) [homeassistant.components.climate] Updating ecobee climate took longer than the scheduled update interval 0:01:00
2022-12-08 16:19:32.585 WARNING (SyncWorker_6) [custom_components.truenas.truenas_api] TrueNAS X.X.X.110 unable to fetch data "update/check_available" (500)
2022-12-08 16:20:32.582 WARNING (SyncWorker_10) [custom_components.truenas.truenas_api] TrueNAS X.X.X.110 unable to fetch data "update/check_available" (500)
2022-12-08 16:21:15.674 WARNING (MainThread) [homeassistant.helpers.entity] Update of climate.ecobeeupstairs is taking over 10 seconds
2022-12-08 16:21:32.580 WARNING (SyncWorker_12) [custom_components.truenas.truenas_api] TrueNAS X.X.X.110 unable to fetch data "update/check_available" (500)
2022-12-08 16:22:05.673 WARNING (MainThread) [homeassistant.components.climate] Updating ecobee climate took longer than the scheduled update interval 0:01:00
2022-12-08 16:22:32.586 WARNING (SyncWorker_2) [custom_components.truenas.truenas_api] TrueNAS X.X.X.110 unable to fetch data "update/check_available" (500)
2022-12-08 16:23:32.582 WARNING (SyncWorker_6) [custom_components.truenas.truenas_api] TrueNAS X.X.X.110 unable to fetch data "update/check_available" (500)
2022-12-08 16:24:09.625 WARNING (MainThread) [homeassistant.helpers.entity] Update of sensor.torsten_travel_time_to_home is taking over 10 seconds
2022-12-08 16:24:15.676 WARNING (MainThread) [homeassistant.helpers.entity] Update of climate.ecobeeupstairs is taking over 10 seconds
2022-12-08 16:24:32.585 WARNING (SyncWorker_12) [custom_components.truenas.truenas_api] TrueNAS X.X.X.110 unable to fetch data "update/check_available" (500)
2022-12-08 16:25:05.677 WARNING (MainThread) [homeassistant.components.climate] Updating ecobee climate took longer than the scheduled update interval 0:01:00
2022-12-08 16:25:32.591 WARNING (SyncWorker_2) [custom_components.truenas.truenas_api] TrueNAS X.X.X.110 unable to fetch data "update/check_available" (500)
2022-12-08 16:26:32.585 WARNING (SyncWorker_6) [custom_components.truenas.truenas_api] TrueNAS X.X.X.110 unable to fetch data "update/check_available" (500)
2022-12-08 16:26:53.631 ERROR (MainThread) [homeassistant.components.automation.lisa_coming_and_going] Lisa Coming and Going: Choose at step 1: choice 4: Error executing script. Service not found for call_service at pos 1: Unable to find service notify.alexa_media
2022-12-08 16:26:53.634 ERROR (MainThread) [homeassistant.components.automation.lisa_coming_and_going] Lisa Coming and Going: Error executing script. Service not found for choose at pos 1: Unable to find service notify.alexa_media
2022-12-08 16:26:57.885 ERROR (MainThread) [homeassistant.components.automation.simone_coming_and_going] Simone Coming and Going: Choose at step 1: choice 4: Error executing script. Service not found for call_service at pos 2: Unable to find service notify.alexa_media
2022-12-08 16:26:57.891 ERROR (MainThread) [homeassistant.components.automation.simone_coming_and_going] Simone Coming and Going: Error executing script. Service not found for choose at pos 1: Unable to find service notify.alexa_media
2022-12-08 16:27:15.682 WARNING (MainThread) [homeassistant.helpers.entity] Update of climate.ecobeeupstairs is taking over 10 seconds
2022-12-08 16:27:32.588 WARNING (SyncWorker_13) [custom_components.truenas.truenas_api] TrueNAS X.X.X.110 unable to fetch data "update/check_available" (500)
2022-12-08 16:28:05.681 WARNING (MainThread) [homeassistant.components.climate] Updating ecobee climate took longer than the scheduled update interval 0:01:00
2022-12-08 16:28:32.587 WARNING (SyncWorker_9) [custom_components.truenas.truenas_api] TrueNAS X.X.X.110 unable to fetch data "update/check_available" (500)
2022-12-08 16:29:09.642 WARNING (MainThread) [homeassistant.helpers.entity] Update of sensor.simone_travel_time_to_home is taking over 10 seconds
2022-12-08 16:29:32.589 WARNING (SyncWorker_9) [custom_components.truenas.truenas_api] TrueNAS X.X.X.110 unable to fetch data "update/check_available" (500)
2022-12-08 16:30:15.686 WARNING (MainThread) [homeassistant.helpers.entity] Update of climate.ecobeeupstairs is taking over 10 seconds
2022-12-08 16:30:32.590 WARNING (SyncWorker_13) [custom_components.truenas.truenas_api] TrueNAS X.X.X.110 unable to fetch data "update/check_available" (500)
2022-12-08 16:31:05.684 WARNING (MainThread) [homeassistant.components.climate] Updating ecobee climate took longer than the scheduled update interval 0:01:00
2022-12-08 16:31:32.589 WARNING (SyncWorker_11) [custom_components.truenas.truenas_api] TrueNAS X.X.X.110 unable to fetch data "update/check_available" (500)
2022-12-08 16:32:32.593 WARNING (SyncWorker_5) [custom_components.truenas.truenas_api] TrueNAS X.X.X.110 unable to fetch data "update/check_available" (500)
2022-12-08 16:33:15.687 WARNING (MainThread) [homeassistant.helpers.entity] Update of climate.ecobeeupstairs is taking over 10 seconds
2022-12-08 16:33:32.591 WARNING (SyncWorker_11) [custom_components.truenas.truenas_api] TrueNAS X.X.X.110 unable to fetch data "update/check_available" (500)
2022-12-08 16:33:59.823 WARNING (SyncWorker_0) [homeassistant.components.waze_travel_time.sensor] Error on retrieving data: empty response
2022-12-08 16:34:05.686 WARNING (MainThread) [homeassistant.components.climate] Updating ecobee climate took longer than the scheduled update interval 0:01:00
2022-12-08 16:34:09.642 WARNING (MainThread) [homeassistant.helpers.entity] Update of sensor.simone_travel_time_to_home is taking over 10 seconds
2022-12-08 16:34:32.591 WARNING (SyncWorker_2) [custom_components.truenas.truenas_api] TrueNAS X.X.X.110 unable to fetch data "update/check_available" (500)
2022-12-08 16:34:54.518 ERROR (MainThread) [homeassistant.components.automation.lisa_coming_and_going] Lisa Coming and Going: Choose at step 1: choice 1: Error executing script. Service not found for call_service at pos 1: Unable to find service notify.alexa_media
2022-12-08 16:34:54.525 ERROR (MainThread) [homeassistant.components.automation.lisa_coming_and_going] Lisa Coming and Going: Error executing script. Service not found for choose at pos 1: Unable to find service notify.alexa_media
2022-12-08 16:34:56.649 ERROR (MainThread) [homeassistant.components.automation.simone_coming_and_going] Simone Coming and Going: Choose at step 1: choice 1: Error executing script. Service not found for call_service at pos 2: Unable to find service notify.alexa_media
2022-12-08 16:34:56.657 ERROR (MainThread) [homeassistant.components.automation.simone_coming_and_going] Simone Coming and Going: Error executing script. Service not found for choose at pos 1: Unable to find service notify.alexa_media
2022-12-08 16:35:32.590 WARNING (SyncWorker_7) [custom_components.truenas.truenas_api] TrueNAS X.X.X.110 unable to fetch data "update/check_available" (500)
2022-12-08 16:35:37.024 ERROR (MainThread) [homeassistant.components.automation.garage_door_notifications] Garage Door Notifications: Choose at step 1: choice 3: Error executing script. Service not found for call_service at pos 2: Unable to find service notify.alexa_media
2022-12-08 16:35:37.035 ERROR (MainThread) [homeassistant.components.automation.garage_door_notifications] Garage Door Notifications: Error executing script. Service not found for choose at pos 1: Unable to find service notify.alexa_media
2022-12-08 16:35:45.262 ERROR (MainThread) [homeassistant.components.automation.driveway_motion] Driveway Motion: Choose at step 1: choice 1: Error executing script. Service not found for call_service at pos 3: Unable to find service notify.alexa_media
2022-12-08 16:35:45.267 ERROR (MainThread) [homeassistant.components.automation.driveway_motion] Driveway Motion: Error executing script. Service not found for choose at pos 1: Unable to find service notify.alexa_media
2022-12-08 16:36:15.691 WARNING (MainThread) [homeassistant.helpers.entity] Update of climate.ecobeeupstairs is taking over 10 seconds
2022-12-08 16:36:32.591 WARNING (SyncWorker_1) [custom_components.truenas.truenas_api] TrueNAS X.X.X.110 unable to fetch data "update/check_available" (500)
2022-12-08 16:37:05.559 ERROR (MainThread) [homeassistant.components.automation.garage_door_notifications] Garage Door Notifications: Choose at step 1: choice 4: Error executing script. Service not found for call_service at pos 2: Unable to find service notify.alexa_media
2022-12-08 16:37:05.566 ERROR (MainThread) [homeassistant.components.automation.garage_door_notifications] Garage Door Notifications: Error executing script. Service not found for choose at pos 1: Unable to find service notify.alexa_media
2022-12-08 16:37:05.690 WARNING (MainThread) [homeassistant.components.climate] Updating ecobee climate took longer than the scheduled update interval 0:01:00
2022-12-08 16:37:14.603 ERROR (MainThread) [homeassistant.components.automation.front_door_automation] Front Door Automation: Choose at step 1: choice 1: Error executing script. Service not found for call_service at pos 2: Unable to find service notify.alexa_media
2022-12-08 16:37:14.609 ERROR (MainThread) [homeassistant.components.automation.front_door_automation] Front Door Automation: Error executing script. Service not found for choose at pos 1: Unable to find service notify.alexa_media
2022-12-08 16:37:27.773 ERROR (MainThread) [homeassistant.components.automation.front_door_automation] Front Door Automation: Choose at step 1: choice 2: Error executing script. Service not found for call_service at pos 2: Unable to find service notify.alexa_media
2022-12-08 16:37:27.779 ERROR (MainThread) [homeassistant.components.automation.front_door_automation] Front Door Automation: Error executing script. Service not found for choose at pos 1: Unable to find service notify.alexa_media
2022-12-08 16:37:32.587 WARNING (SyncWorker_8) [custom_components.truenas.truenas_api] TrueNAS X.X.X.110 unable to fetch data "update/check_available" (500)
2022-12-08 16:38:13.211 ERROR (MainThread) [custom_components.reolink_dev] Timeout fetching reolink.Garage.motion_states data
2022-12-08 16:38:32.591 WARNING (SyncWorker_5) [custom_components.truenas.truenas_api] TrueNAS X.X.X.110 unable to fetch data "update/check_available" (500)
2022-12-08 16:39:15.692 WARNING (MainThread) [homeassistant.helpers.entity] Update of climate.ecobeeupstairs is taking over 10 seconds
2022-12-08 16:39:21.091 ERROR (MainThread) [homeassistant.components.automation.front_door_automation] Front Door Automation: Choose at step 1: choice 1: Error executing script. Service not found for call_service at pos 2: Unable to find service notify.alexa_media
2022-12-08 16:39:21.094 ERROR (MainThread) [homeassistant.components.automation.front_door_automation] Front Door Automation: Error executing script. Service not found for choose at pos 1: Unable to find service notify.alexa_media
2022-12-08 16:39:24.240 ERROR (MainThread) [homeassistant.components.automation.front_door_automation] Front Door Automation: Choose at step 1: choice 2: Error executing script. Service not found for call_service at pos 2: Unable to find service notify.alexa_media
2022-12-08 16:39:24.247 ERROR (MainThread) [homeassistant.components.automation.front_door_automation] Front Door Automation: Error executing script. Service not found for choose at pos 1: Unable to find service notify.alexa_media
2022-12-08 16:39:32.591 WARNING (SyncWorker_3) [custom_components.truenas.truenas_api] TrueNAS X.X.X.110 unable to fetch data "update/check_available" (500)
2022-12-08 16:39:45.371 ERROR (MainThread) [homeassistant.components.automation.driveway_motion] Driveway Motion: Choose at step 1: choice 1: Error executing script. Service not found for call_service at pos 3: Unable to find service notify.alexa_media
2022-12-08 16:39:45.374 ERROR (MainThread) [homeassistant.components.automation.driveway_motion] Driveway Motion: Error executing script. Service not found for choose at pos 1: Unable to find service notify.alexa_media
2022-12-08 16:40:05.692 WARNING (MainThread) [homeassistant.components.climate] Updating ecobee climate took longer than the scheduled update interval 0:01:00
2022-12-08 16:40:32.591 WARNING (SyncWorker_9) [custom_components.truenas.truenas_api] TrueNAS X.X.X.110 unable to fetch data "update/check_available" (500)
2022-12-08 16:40:50.297 ERROR (MainThread) [homeassistant.components.automation.driveway_motion] Driveway Motion: Choose at step 1: choice 1: Error executing script. Service not found for call_service at pos 3: Unable to find service notify.alexa_media
2022-12-08 16:40:50.300 ERROR (MainThread) [homeassistant.components.automation.driveway_motion] Driveway Motion: Error executing script. Service not found for choose at pos 1: Unable to find service notify.alexa_media
2022-12-08 16:41:02.237 ERROR (MainThread) [homeassistant.components.automation.front_door_automation] Front Door Automation: Choose at step 1: choice 1: Error executing script. Service not found for call_service at pos 2: Unable to find service notify.alexa_media
2022-12-08 16:41:02.241 ERROR (MainThread) [homeassistant.components.automation.front_door_automation] Front Door Automation: Error executing script. Service not found for choose at pos 1: Unable to find service notify.alexa_media
2022-12-08 16:41:06.019 ERROR (MainThread) [homeassistant.components.automation.front_door_automation] Front Door Automation: Choose at step 1: choice 2: Error executing script. Service not found for call_service at pos 2: Unable to find service notify.alexa_media
2022-12-08 16:41:06.025 ERROR (MainThread) [homeassistant.components.automation.front_door_automation] Front Door Automation: Error executing script. Service not found for choose at pos 1: Unable to find service notify.alexa_media
2022-12-08 16:41:32.591 WARNING (SyncWorker_0) [custom_components.truenas.truenas_api] TrueNAS X.X.X.110 unable to fetch data "update/check_available" (500)
2022-12-08 16:42:15.696 WARNING (MainThread) [homeassistant.helpers.entity] Update of climate.ecobeeupstairs is taking over 10 seconds
2022-12-08 16:42:32.593 WARNING (SyncWorker_8) [custom_components.truenas.truenas_api] TrueNAS X.X.X.110 unable to fetch data "update/check_available" (500)
2022-12-08 16:42:43.211 ERROR (MainThread) [custom_components.reolink_dev] Timeout fetching reolink.Garage.motion_states data
2022-12-08 16:43:05.696 WARNING (MainThread) [homeassistant.components.climate] Updating ecobee climate took longer than the scheduled update interval 0:01:00
2022-12-08 16:43:32.592 WARNING (SyncWorker_3) [custom_components.truenas.truenas_api] TrueNAS X.X.X.110 unable to fetch data "update/check_available" (500)
2022-12-08 16:44:05.697 WARNING (MainThread) [homeassistant.components.climate] Updating ecobee climate took longer than the scheduled update interval 0:01:00
2022-12-08 16:44:32.592 WARNING (SyncWorker_4) [custom_components.truenas.truenas_api] TrueNAS X.X.X.110 unable to fetch data "update/check_available" (500)
2022-12-08 16:45:05.698 WARNING (MainThread) [homeassistant.components.climate] Updating ecobee climate took longer than the scheduled update interval 0:01:00
2022-12-08 16:45:15.923 WARNING (MainThread) [homeassistant.helpers.entity] Update of sensor.ecobeeupstairs_temperature is taking over 10 seconds
2022-12-08 16:45:32.589 WARNING (SyncWorker_12) [custom_components.truenas.truenas_api] TrueNAS X.X.X.110 unable to fetch data "update/check_available" (500)
2022-12-08 16:45:35.923 WARNING (MainThread) [homeassistant.components.sensor] Updating ecobee sensor took longer than the scheduled update interval 0:00:30
2022-12-08 16:46:05.924 WARNING (MainThread) [homeassistant.components.sensor] Updating ecobee sensor took longer than the scheduled update interval 0:00:30
2022-12-08 16:46:32.593 WARNING (SyncWorker_9) [custom_components.truenas.truenas_api] TrueNAS X.X.X.110 unable to fetch data "update/check_available" (500)
2022-12-08 16:47:32.590 WARNING (SyncWorker_2) [custom_components.truenas.truenas_api] TrueNAS X.X.X.110 unable to fetch data "update/check_available" (500)
2022-12-08 16:48:15.931 WARNING (MainThread) [homeassistant.helpers.entity] Update of sensor.ecobeeupstairs_temperature is taking over 10 seconds
2022-12-08 16:48:32.590 WARNING (SyncWorker_9) [custom_components.truenas.truenas_api] TrueNAS X.X.X.110 unable to fetch data "update/check_available" (500)
2022-12-08 16:48:35.930 WARNING (MainThread) [homeassistant.components.sensor] Updating ecobee sensor took longer than the scheduled update interval 0:00:30
2022-12-08 16:49:05.931 WARNING (MainThread) [homeassistant.components.sensor] Updating ecobee sensor took longer than the scheduled update interval 0:00:30
2022-12-08 16:49:32.592 WARNING (SyncWorker_10) [custom_components.truenas.truenas_api] TrueNAS X.X.X.110 unable to fetch data "update/check_available" (500)
2022-12-08 16:50:32.593 WARNING (SyncWorker_5) [custom_components.truenas.truenas_api] TrueNAS X.X.X.110 unable to fetch data "update/check_available" (500)
2022-12-08 16:51:15.937 WARNING (MainThread) [homeassistant.helpers.entity] Update of sensor.ecobeeupstairs_temperature is taking over 10 seconds
2022-12-08 16:51:32.589 WARNING (SyncWorker_9) [custom_components.truenas.truenas_api] TrueNAS X.X.X.110 unable to fetch data "update/check_available" (500)
2022-12-08 16:51:35.945 WARNING (MainThread) [homeassistant.components.sensor] Updating ecobee sensor took longer than the scheduled update interval 0:00:30
2022-12-08 16:52:05.945 WARNING (MainThread) [homeassistant.components.sensor] Updating ecobee sensor took longer than the scheduled update interval 0:00:30
2022-12-08 16:52:32.594 WARNING (SyncWorker_9) [custom_components.truenas.truenas_api] TrueNAS X.X.X.110 unable to fetch data "update/check_available" (500)
2022-12-08 16:53:32.596 WARNING (SyncWorker_4) [custom_components.truenas.truenas_api] TrueNAS X.X.X.110 unable to fetch data "update/check_available" (500)
2022-12-08 16:53:59.808 WARNING (SyncWorker_6) [homeassistant.components.waze_travel_time.sensor] Error on retrieving data: empty response
2022-12-08 16:54:15.951 WARNING (MainThread) [homeassistant.helpers.entity] Update of sensor.ecobeeupstairs_temperature is taking over 10 seconds
2022-12-08 16:54:32.593 WARNING (SyncWorker_6) [custom_components.truenas.truenas_api] TrueNAS X.X.X.110 unable to fetch data "update/check_available" (500)
2022-12-08 16:54:35.950 WARNING (MainThread) [homeassistant.components.sensor] Updating ecobee sensor took longer than the scheduled update interval 0:00:30
2022-12-08 16:55:05.952 WARNING (MainThread) [homeassistant.components.sensor] Updating ecobee sensor took longer than the scheduled update interval 0:00:30
2022-12-08 16:55:32.592 WARNING (SyncWorker_7) [custom_components.truenas.truenas_api] TrueNAS X.X.X.110 unable to fetch data "update/check_available" (500)
2022-12-08 16:56:32.593 WARNING (SyncWorker_7) [custom_components.truenas.truenas_api] TrueNAS X.X.X.110 unable to fetch data "update/check_available" (500)
2022-12-08 16:57:15.962 WARNING (MainThread) [homeassistant.helpers.entity] Update of sensor.ecobeeupstairs_temperature is taking over 10 seconds
2022-12-08 16:57:32.590 WARNING (SyncWorker_2) [custom_components.truenas.truenas_api] TrueNAS X.X.X.110 unable to fetch data "update/check_available" (500)
2022-12-08 16:57:35.961 WARNING (MainThread) [homeassistant.components.sensor] Updating ecobee sensor took longer than the scheduled update interval 0:00:30
2022-12-08 16:58:05.962 WARNING (MainThread) [homeassistant.components.sensor] Updating ecobee sensor took longer than the scheduled update interval 0:00:30
2022-12-08 16:58:32.590 WARNING (SyncWorker_1) [custom_components.truenas.truenas_api] TrueNAS X.X.X.110 unable to fetch data "update/check_available" (500)
2022-12-08 16:59:32.596 WARNING (SyncWorker_10) [custom_components.truenas.truenas_api] TrueNAS X.X.X.110 unable to fetch data "update/check_available" (500)
2022-12-08 17:00:15.967 WARNING (MainThread) [homeassistant.helpers.entity] Update of sensor.ecobeeupstairs_temperature is taking over 10 seconds
2022-12-08 17:00:32.593 WARNING (SyncWorker_6) [custom_components.truenas.truenas_api] TrueNAS X.X.X.110 unable to fetch data "update/check_available" (500)
2022-12-08 17:00:35.966 WARNING (MainThread) [homeassistant.components.sensor] Updating ecobee sensor took longer than the scheduled update interval 0:00:30
2022-12-08 17:01:05.967 WARNING (MainThread) [homeassistant.components.sensor] Updating ecobee sensor took longer than the scheduled update interval 0:00:30
2022-12-08 17:01:32.590 WARNING (SyncWorker_9) [custom_components.truenas.truenas_api] TrueNAS X.X.X.110 unable to fetch data "update/check_available" (500)
2022-12-08 17:02:32.591 WARNING (SyncWorker_0) [custom_components.truenas.truenas_api] TrueNAS X.X.X.110 unable to fetch data "update/check_available" (500)
2022-12-08 17:03:15.972 WARNING (MainThread) [homeassistant.helpers.entity] Update of sensor.ecobeeupstairs_temperature is taking over 10 seconds
2022-12-08 17:03:32.590 WARNING (SyncWorker_0) [custom_components.truenas.truenas_api] TrueNAS X.X.X.110 unable to fetch data "update/check_available" (500)
2022-12-08 17:03:35.971 WARNING (MainThread) [homeassistant.components.sensor] Updating ecobee sensor took longer than the scheduled update interval 0:00:30
2022-12-08 17:04:05.971 WARNING (MainThread) [homeassistant.components.sensor] Updating ecobee sensor took longer than the scheduled update interval 0:00:30
2022-12-08 17:04:32.592 WARNING (SyncWorker_11) [custom_components.truenas.truenas_api] TrueNAS X.X.X.110 unable to fetch data "update/check_available" (500)
2022-12-08 17:05:32.589 WARNING (SyncWorker_8) [custom_components.truenas.truenas_api] TrueNAS X.X.X.110 unable to fetch data "update/check_available" (500)
2022-12-08 17:06:15.980 WARNING (MainThread) [homeassistant.helpers.entity] Update of sensor.ecobeeupstairs_temperature is taking over 10 seconds
2022-12-08 17:06:32.590 WARNING (SyncWorker_5) [custom_components.truenas.truenas_api] TrueNAS X.X.X.110 unable to fetch data "update/check_available" (500)
2022-12-08 17:06:35.981 WARNING (MainThread) [homeassistant.components.sensor] Updating ecobee sensor took longer than the scheduled update interval 0:00:30
2022-12-08 17:07:05.983 WARNING (MainThread) [homeassistant.components.sensor] Updating ecobee sensor took longer than the scheduled update interval 0:00:30
2022-12-08 17:07:32.593 WARNING (SyncWorker_10) [custom_components.truenas.truenas_api] TrueNAS X.X.X.110 unable to fetch data "update/check_available" (500)
2022-12-08 17:08:32.591 WARNING (SyncWorker_5) [custom_components.truenas.truenas_api] TrueNAS X.X.X.110 unable to fetch data "update/check_available" (500)
2022-12-08 17:08:59.821 WARNING (SyncWorker_13) [homeassistant.components.waze_travel_time.sensor] Error on retrieving data: empty response
2022-12-08 17:09:15.991 WARNING (MainThread) [homeassistant.helpers.entity] Update of sensor.ecobeeupstairs_temperature is taking over 10 seconds
2022-12-08 17:09:32.590 WARNING (SyncWorker_0) [custom_components.truenas.truenas_api] TrueNAS X.X.X.110 unable to fetch data "update/check_available" (500)
2022-12-08 17:09:35.993 WARNING (MainThread) [homeassistant.components.sensor] Updating ecobee sensor took longer than the scheduled update interval 0:00:30
2022-12-08 17:10:05.993 WARNING (MainThread) [homeassistant.components.sensor] Updating ecobee sensor took longer than the scheduled update interval 0:00:30
2022-12-08 17:10:32.592 WARNING (SyncWorker_13) [custom_components.truenas.truenas_api] TrueNAS X.X.X.110 unable to fetch data "update/check_available" (500)
2022-12-08 17:11:32.589 WARNING (SyncWorker_3) [custom_components.truenas.truenas_api] TrueNAS X.X.X.110 unable to fetch data "update/check_available" (500)
2022-12-08 17:12:15.998 WARNING (MainThread) [homeassistant.helpers.entity] Update of sensor.ecobeeupstairs_temperature is taking over 10 seconds
2022-12-08 17:12:32.592 WARNING (SyncWorker_1) [custom_components.truenas.truenas_api] TrueNAS X.X.X.110 unable to fetch data "update/check_available" (500)
2022-12-08 17:12:35.997 WARNING (MainThread) [homeassistant.components.sensor] Updating ecobee sensor took longer than the scheduled update interval 0:00:30
2022-12-08 17:13:05.997 WARNING (MainThread) [homeassistant.components.sensor] Updating ecobee sensor took longer than the scheduled update interval 0:00:30
2022-12-08 17:13:32.589 WARNING (SyncWorker_4) [custom_components.truenas.truenas_api] TrueNAS X.X.X.110 unable to fetch data "update/check_available" (500)
2022-12-08 17:13:59.789 WARNING (SyncWorker_5) [homeassistant.components.waze_travel_time.sensor] Error on retrieving data: empty response
2022-12-08 17:13:59.809 WARNING (SyncWorker_7) [homeassistant.components.waze_travel_time.sensor] Error on retrieving data: empty response
2022-12-08 17:14:32.587 WARNING (SyncWorker_0) [custom_components.truenas.truenas_api] TrueNAS X.X.X.110 unable to fetch data "update/check_available" (500)
2022-12-08 17:15:16.003 WARNING (MainThread) [homeassistant.helpers.entity] Update of sensor.ecobeeupstairs_temperature is taking over 10 seconds
2022-12-08 17:15:32.590 WARNING (SyncWorker_11) [custom_components.truenas.truenas_api] TrueNAS X.X.X.110 unable to fetch data "update/check_available" (500)
2022-12-08 17:15:36.001 WARNING (MainThread) [homeassistant.components.sensor] Updating ecobee sensor took longer than the scheduled update interval 0:00:30
2022-12-08 17:16:06.003 WARNING (MainThread) [homeassistant.components.sensor] Updating ecobee sensor took longer than the scheduled update interval 0:00:30
2022-12-08 17:16:32.596 WARNING (SyncWorker_5) [custom_components.truenas.truenas_api] TrueNAS X.X.X.110 unable to fetch data "update/check_available" (500)
2022-12-08 17:17:32.590 WARNING (SyncWorker_4) [custom_components.truenas.truenas_api] TrueNAS X.X.X.110 unable to fetch data "update/check_available" (500)
2022-12-08 17:18:16.008 WARNING (MainThread) [homeassistant.helpers.entity] Update of sensor.ecobeeupstairs_temperature is taking over 10 seconds
2022-12-08 17:18:32.589 WARNING (SyncWorker_6) [custom_components.truenas.truenas_api] TrueNAS X.X.X.110 unable to fetch data "update/check_available" (500)
2022-12-08 17:18:36.007 WARNING (MainThread) [homeassistant.components.sensor] Updating ecobee sensor took longer than the scheduled update interval 0:00:30
2022-12-08 17:18:59.817 WARNING (SyncWorker_8) [homeassistant.components.waze_travel_time.sensor] Error on retrieving data: empty response
2022-12-08 17:19:06.008 WARNING (MainThread) [homeassistant.components.sensor] Updating ecobee sensor took longer than the scheduled update interval 0:00:30
2022-12-08 17:19:32.589 WARNING (SyncWorker_2) [custom_components.truenas.truenas_api] TrueNAS X.X.X.110 unable to fetch data "update/check_available" (500)
2022-12-08 17:20:32.591 WARNING (SyncWorker_7) [custom_components.truenas.truenas_api] TrueNAS X.X.X.110 unable to fetch data "update/check_available" (500)
2022-12-08 17:21:16.017 WARNING (MainThread) [homeassistant.helpers.entity] Update of sensor.ecobeeupstairs_temperature is taking over 10 seconds
2022-12-08 17:21:32.594 WARNING (SyncWorker_6) [custom_components.truenas.truenas_api] TrueNAS X.X.X.110 unable to fetch data "update/check_available" (500)
2022-12-08 17:21:36.016 WARNING (MainThread) [homeassistant.components.sensor] Updating ecobee sensor took longer than the scheduled update interval 0:00:30
2022-12-08 17:22:06.017 WARNING (MainThread) [homeassistant.components.sensor] Updating ecobee sensor took longer than the scheduled update interval 0:00:30
2022-12-08 17:22:32.590 WARNING (SyncWorker_9) [custom_components.truenas.truenas_api] TrueNAS X.X.X.110 unable to fetch data "update/check_available" (500)
2022-12-08 17:23:32.592 WARNING (SyncWorker_2) [custom_components.truenas.truenas_api] TrueNAS X.X.X.110 unable to fetch data "update/check_available" (500)
2022-12-08 17:23:59.883 WARNING (SyncWorker_7) [homeassistant.components.waze_travel_time.sensor] Error on retrieving data: empty response
2022-12-08 17:24:16.022 WARNING (MainThread) [homeassistant.helpers.entity] Update of sensor.ecobeeupstairs_temperature is taking over 10 seconds
2022-12-08 17:24:33.590 WARNING (SyncWorker_13) [custom_components.truenas.truenas_api] TrueNAS X.X.X.110 unable to fetch data "update/check_available" (500)
2022-12-08 17:24:36.020 WARNING (MainThread) [homeassistant.components.sensor] Updating ecobee sensor took longer than the scheduled update interval 0:00:30
2022-12-08 17:25:06.021 WARNING (MainThread) [homeassistant.components.sensor] Updating ecobee sensor took longer than the scheduled update interval 0:00:30
2022-12-08 17:25:32.590 WARNING (SyncWorker_4) [custom_components.truenas.truenas_api] TrueNAS X.X.X.110 unable to fetch data "update/check_available" (500)
2022-12-08 17:26:32.590 WARNING (SyncWorker_4) [custom_components.truenas.truenas_api] TrueNAS X.X.X.110 unable to fetch data "update/check_available" (500)
2022-12-08 17:27:16.026 WARNING (MainThread) [homeassistant.helpers.entity] Update of sensor.ecobeeupstairs_temperature is taking over 10 seconds
2022-12-08 17:27:32.589 WARNING (SyncWorker_1) [custom_components.truenas.truenas_api] TrueNAS X.X.X.110 unable to fetch data "update/check_available" (500)
2022-12-08 17:27:36.026 WARNING (MainThread) [homeassistant.components.sensor] Updating ecobee sensor took longer than the scheduled update interval 0:00:30
2022-12-08 17:28:06.027 WARNING (MainThread) [homeassistant.components.sensor] Updating ecobee sensor took longer than the scheduled update interval 0:00:30
2022-12-08 17:28:32.590 WARNING (SyncWorker_0) [custom_components.truenas.truenas_api] TrueNAS X.X.X.110 unable to fetch data "update/check_available" (500)
2022-12-08 17:29:15.751 WARNING (MainThread) [homeassistant.helpers.entity] Update of climate.main_floor is taking over 10 seconds
2022-12-08 17:29:32.588 WARNING (SyncWorker_10) [custom_components.truenas.truenas_api] TrueNAS X.X.X.110 unable to fetch data "update/check_available" (500)
2022-12-08 17:30:05.749 WARNING (MainThread) [homeassistant.components.climate] Updating ecobee climate took longer than the scheduled update interval 0:01:00
2022-12-08 17:30:21.502 WARNING (MainThread) [homeassistant.helpers.entity] Update of climate.main_floor is taking over 10 seconds
2022-12-08 17:30:32.590 WARNING (SyncWorker_2) [custom_components.truenas.truenas_api] TrueNAS X.X.X.110 unable to fetch data "update/check_available" (500)
2022-12-08 17:31:32.590 WARNING (SyncWorker_11) [custom_components.truenas.truenas_api] TrueNAS X.X.X.110 unable to fetch data "update/check_available" (500)
2022-12-08 17:32:32.588 WARNING (SyncWorker_8) [custom_components.truenas.truenas_api] TrueNAS X.X.X.110 unable to fetch data "update/check_available" (500)
2022-12-08 17:33:32.594 WARNING (SyncWorker_10) [custom_components.truenas.truenas_api] TrueNAS X.X.X.110 unable to fetch data "update/check_available" (500)
2022-12-08 17:33:46.040 WARNING (MainThread) [homeassistant.helpers.entity] Update of sensor.ecobeeupstairs_temperature is taking over 10 seconds
And more
2022-12-08 17:33:59.798 WARNING (SyncWorker_5) [homeassistant.components.waze_travel_time.sensor] Error on retrieving data: empty response
2022-12-08 17:34:06.040 WARNING (MainThread) [homeassistant.components.sensor] Updating ecobee sensor took longer than the scheduled update interval 0:00:30
2022-12-08 17:34:32.589 WARNING (SyncWorker_12) [custom_components.truenas.truenas_api] TrueNAS X.X.X.110 unable to fetch data "update/check_available" (500)
2022-12-08 17:34:36.041 WARNING (MainThread) [homeassistant.components.sensor] Updating ecobee sensor took longer than the scheduled update interval 0:00:30
2022-12-08 17:35:32.592 WARNING (SyncWorker_5) [custom_components.truenas.truenas_api] TrueNAS X.X.X.110 unable to fetch data "update/check_available" (500)
2022-12-08 17:36:32.589 WARNING (SyncWorker_7) [custom_components.truenas.truenas_api] TrueNAS X.X.X.110 unable to fetch data "update/check_available" (500)
2022-12-08 17:36:46.047 WARNING (MainThread) [homeassistant.helpers.entity] Update of sensor.ecobeeupstairs_temperature is taking over 10 seconds
2022-12-08 17:37:06.046 WARNING (MainThread) [homeassistant.components.sensor] Updating ecobee sensor took longer than the scheduled update interval 0:00:30
2022-12-08 17:37:32.587 WARNING (SyncWorker_0) [custom_components.truenas.truenas_api] TrueNAS X.X.X.110 unable to fetch data "update/check_available" (500)
2022-12-08 17:37:36.048 WARNING (MainThread) [homeassistant.components.sensor] Updating ecobee sensor took longer than the scheduled update interval 0:00:30
2022-12-08 17:38:32.590 WARNING (SyncWorker_12) [custom_components.truenas.truenas_api] TrueNAS X.X.X.110 unable to fetch data "update/check_available" (500)
2022-12-08 17:38:59.816 WARNING (SyncWorker_5) [homeassistant.components.waze_travel_time.sensor] Error on retrieving data: empty response
2022-12-08 17:39:32.589 WARNING (SyncWorker_12) [custom_components.truenas.truenas_api] TrueNAS X.X.X.110 unable to fetch data "update/check_available" (500)
2022-12-08 17:39:46.055 WARNING (MainThread) [homeassistant.helpers.entity] Update of sensor.ecobeeupstairs_temperature is taking over 10 seconds
2022-12-08 17:40:06.054 WARNING (MainThread) [homeassistant.components.sensor] Updating ecobee sensor took longer than the scheduled update interval 0:00:30
2022-12-08 17:40:32.589 WARNING (SyncWorker_2) [custom_components.truenas.truenas_api] TrueNAS X.X.X.110 unable to fetch data "update/check_available" (500)
2022-12-08 17:40:36.055 WARNING (MainThread) [homeassistant.components.sensor] Updating ecobee sensor took longer than the scheduled update interval 0:00:30
2022-12-08 17:41:32.594 WARNING (SyncWorker_5) [custom_components.truenas.truenas_api] TrueNAS X.X.X.110 unable to fetch data "update/check_available" (500)
2022-12-08 17:42:32.590 WARNING (SyncWorker_9) [custom_components.truenas.truenas_api] TrueNAS X.X.X.110 unable to fetch data "update/check_available" (500)
2022-12-08 17:42:46.061 WARNING (MainThread) [homeassistant.helpers.entity] Update of sensor.ecobeeupstairs_temperature is taking over 10 seconds
2022-12-08 17:43:06.059 WARNING (MainThread) [homeassistant.components.sensor] Updating ecobee sensor took longer than the scheduled update interval 0:00:30
2022-12-08 17:43:32.589 WARNING (SyncWorker_14) [custom_components.truenas.truenas_api] TrueNAS X.X.X.110 unable to fetch data "update/check_available" (500)
2022-12-08 17:43:36.060 WARNING (MainThread) [homeassistant.components.sensor] Updating ecobee sensor took longer than the scheduled update interval 0:00:30
2022-12-08 17:44:32.590 WARNING (SyncWorker_4) [custom_components.truenas.truenas_api] TrueNAS X.X.X.110 unable to fetch data "update/check_available" (500)
2022-12-08 17:45:32.593 WARNING (SyncWorker_12) [custom_components.truenas.truenas_api] TrueNAS X.X.X.110 unable to fetch data "update/check_available" (500)
2022-12-08 17:45:46.069 WARNING (MainThread) [homeassistant.helpers.entity] Update of sensor.ecobeeupstairs_temperature is taking over 10 seconds
2022-12-08 17:46:06.067 WARNING (MainThread) [homeassistant.components.sensor] Updating ecobee sensor took longer than the scheduled update interval 0:00:30
2022-12-08 17:46:32.589 WARNING (SyncWorker_2) [custom_components.truenas.truenas_api] TrueNAS X.X.X.110 unable to fetch data "update/check_available" (500)
2022-12-08 17:46:36.068 WARNING (MainThread) [homeassistant.components.sensor] Updating ecobee sensor took longer than the scheduled update interval 0:00:30
2022-12-08 17:47:06.069 WARNING (MainThread) [homeassistant.components.sensor] Updating ecobee sensor took longer than the scheduled update interval 0:00:30
2022-12-08 17:47:32.588 WARNING (SyncWorker_5) [custom_components.truenas.truenas_api] TrueNAS X.X.X.110 unable to fetch data "update/check_available" (500)
2022-12-08 17:47:36.069 WARNING (MainThread) [homeassistant.components.sensor] Updating ecobee sensor took longer than the scheduled update interval 0:00:30
2022-12-08 17:48:06.069 WARNING (MainThread) [homeassistant.components.sensor] Updating ecobee sensor took longer than the scheduled update interval 0:00:30
2022-12-08 17:48:32.589 WARNING (SyncWorker_5) [custom_components.truenas.truenas_api] TrueNAS X.X.X.110 unable to fetch data "update/check_available" (500)
2022-12-08 17:48:36.070 WARNING (MainThread) [homeassistant.components.sensor] Updating ecobee sensor took longer than the scheduled update interval 0:00:30
2022-12-08 17:48:46.870 WARNING (MainThread) [homeassistant.helpers.entity] Update of weather.ecobeeupstairs is taking over 10 seconds
2022-12-08 17:49:06.869 WARNING (MainThread) [homeassistant.components.weather] Updating ecobee weather took longer than the scheduled update interval 0:00:30
2022-12-08 17:49:32.594 WARNING (SyncWorker_4) [custom_components.truenas.truenas_api] TrueNAS X.X.X.110 unable to fetch data "update/check_available" (500)
2022-12-08 17:49:36.870 WARNING (MainThread) [homeassistant.components.weather] Updating ecobee weather took longer than the scheduled update interval 0:00:30
2022-12-08 17:50:32.594 WARNING (SyncWorker_13) [custom_components.truenas.truenas_api] TrueNAS X.X.X.110 unable to fetch data "update/check_available" (500)
2022-12-08 17:50:43.569 ERROR (MainThread) [custom_components.emporia_vue] Error communicating with Emporia API: 500 Server Error: Internal Server Error for url: https://api.emporiaenergy.com/AppAPI?apiMethod=getDeviceListUsages&deviceGids=125950&instant=2022-12-08T22:50:43.359040Z&scale=1MIN&energyUnit=KilowattHours
2022-12-08 17:50:43.584 ERROR (MainThread) [custom_components.emporia_vue] Error fetching sensor data: Error communicating with Emporia API: 500 Server Error: Internal Server Error for url: https://api.emporiaenergy.com/AppAPI?apiMethod=getDeviceListUsages&deviceGids=125950&instant=2022-12-08T22:50:43.359040Z&scale=1MIN&energyUnit=KilowattHours
2022-12-08 17:51:32.589 WARNING (SyncWorker_13) [custom_components.truenas.truenas_api] TrueNAS X.X.X.110 unable to fetch data "update/check_available" (500)
2022-12-08 17:51:46.879 WARNING (MainThread) [homeassistant.helpers.entity] Update of weather.ecobeeupstairs is taking over 10 seconds
2022-12-08 17:52:06.878 WARNING (MainThread) [homeassistant.components.weather] Updating ecobee weather took longer than the scheduled update interval 0:00:30
2022-12-08 17:52:32.592 WARNING (SyncWorker_14) [custom_components.truenas.truenas_api] TrueNAS X.X.X.110 unable to fetch data "update/check_available" (500)
2022-12-08 17:52:36.879 WARNING (MainThread) [homeassistant.components.weather] Updating ecobee weather took longer than the scheduled update interval 0:00:30
2022-12-08 17:53:32.590 WARNING (SyncWorker_5) [custom_components.truenas.truenas_api] TrueNAS X.X.X.110 unable to fetch data "update/check_available" (500)
2022-12-08 17:53:59.817 WARNING (SyncWorker_13) [homeassistant.components.waze_travel_time.sensor] Error on retrieving data: empty response
2022-12-08 17:54:32.590 WARNING (SyncWorker_10) [custom_components.truenas.truenas_api] TrueNAS X.X.X.110 unable to fetch data "update/check_available" (500)
2022-12-08 17:54:46.888 WARNING (MainThread) [homeassistant.helpers.entity] Update of weather.ecobeeupstairs is taking over 10 seconds
2022-12-08 17:55:06.885 WARNING (MainThread) [homeassistant.components.weather] Updating ecobee weather took longer than the scheduled update interval 0:00:30
2022-12-08 17:55:32.593 WARNING (SyncWorker_2) [custom_components.truenas.truenas_api] TrueNAS X.X.X.110 unable to fetch data "update/check_available" (500)
2022-12-08 17:55:36.887 WARNING (MainThread) [homeassistant.components.weather] Updating ecobee weather took longer than the scheduled update interval 0:00:30
2022-12-08 17:56:32.592 WARNING (SyncWorker_14) [custom_components.truenas.truenas_api] TrueNAS X.X.X.110 unable to fetch data "update/check_available" (500)
2022-12-08 17:57:32.589 WARNING (SyncWorker_13) [custom_components.truenas.truenas_api] TrueNAS X.X.X.110 unable to fetch data "update/check_available" (500)
2022-12-08 17:57:46.895 WARNING (MainThread) [homeassistant.helpers.entity] Update of weather.ecobeeupstairs is taking over 10 seconds
2022-12-08 17:58:06.895 WARNING (MainThread) [homeassistant.components.weather] Updating ecobee weather took longer than the scheduled update interval 0:00:30
2022-12-08 17:58:32.589 WARNING (SyncWorker_9) [custom_components.truenas.truenas_api] TrueNAS X.X.X.110 unable to fetch data "update/check_available" (500)
2022-12-08 17:58:36.896 WARNING (MainThread) [homeassistant.components.weather] Updating ecobee weather took longer than the scheduled update interval 0:00:30
2022-12-08 17:58:59.800 WARNING (SyncWorker_12) [homeassistant.components.waze_travel_time.sensor] Error on retrieving data: empty response
2022-12-08 17:59:32.591 WARNING (SyncWorker_13) [custom_components.truenas.truenas_api] TrueNAS X.X.X.110 unable to fetch data "update/check_available" (500)
2022-12-08 18:00:32.592 WARNING (SyncWorker_12) [custom_components.truenas.truenas_api] TrueNAS X.X.X.110 unable to fetch data "update/check_available" (500)
2022-12-08 18:00:46.901 WARNING (MainThread) [homeassistant.helpers.entity] Update of weather.ecobeeupstairs is taking over 10 seconds
2022-12-08 18:01:06.900 WARNING (MainThread) [homeassistant.components.weather] Updating ecobee weather took longer than the scheduled update interval 0:00:30
2022-12-08 18:01:32.590 WARNING (SyncWorker_6) [custom_components.truenas.truenas_api] TrueNAS X.X.X.110 unable to fetch data "update/check_available" (500)
2022-12-08 18:01:36.902 WARNING (MainThread) [homeassistant.components.weather] Updating ecobee weather took longer than the scheduled update interval 0:00:30
2022-12-08 18:02:19.472 WARNING (MainThread) [homeassistant.helpers.entity] Update of climate.main_floor is taking over 10 seconds
2022-12-08 18:02:32.589 WARNING (SyncWorker_7) [custom_components.truenas.truenas_api] TrueNAS X.X.X.110 unable to fetch data "update/check_available" (500)
2022-12-08 18:03:32.593 WARNING (SyncWorker_9) [custom_components.truenas.truenas_api] TrueNAS X.X.X.110 unable to fetch data "update/check_available" (500)
2022-12-08 18:04:32.590 WARNING (SyncWorker_1) [custom_components.truenas.truenas_api] TrueNAS X.X.X.110 unable to fetch data "update/check_available" (500)
2022-12-08 18:05:32.593 WARNING (SyncWorker_4) [custom_components.truenas.truenas_api] TrueNAS X.X.X.110 unable to fetch data "update/check_available" (500)
2022-12-08 18:05:46.113 WARNING (MainThread) [homeassistant.helpers.entity] Update of sensor.ecobeeupstairs_temperature is taking over 10 seconds
2022-12-08 18:06:06.113 WARNING (MainThread) [homeassistant.components.sensor] Updating ecobee sensor took longer than the scheduled update interval 0:00:30
2022-12-08 18:06:32.588 WARNING (SyncWorker_5) [custom_components.truenas.truenas_api] TrueNAS X.X.X.110 unable to fetch data "update/check_available" (500)
2022-12-08 18:06:36.115 WARNING (MainThread) [homeassistant.components.sensor] Updating ecobee sensor took longer than the scheduled update interval 0:00:30
2022-12-08 18:07:32.594 WARNING (SyncWorker_12) [custom_components.truenas.truenas_api] TrueNAS X.X.X.110 unable to fetch data "update/check_available" (500)
2022-12-08 18:08:32.594 WARNING (SyncWorker_10) [custom_components.truenas.truenas_api] TrueNAS X.X.X.110 unable to fetch data "update/check_available" (500)
2022-12-08 18:08:46.119 WARNING (MainThread) [homeassistant.helpers.entity] Update of sensor.ecobeeupstairs_temperature is taking over 10 seconds
2022-12-08 18:08:59.834 WARNING (SyncWorker_5) [homeassistant.components.waze_travel_time.sensor] Error on retrieving data: empty response
2022-12-08 18:09:06.120 WARNING (MainThread) [homeassistant.components.sensor] Updating ecobee sensor took longer than the scheduled update interval 0:00:30
2022-12-08 18:09:32.590 WARNING (SyncWorker_10) [custom_components.truenas.truenas_api] TrueNAS X.X.X.110 unable to fetch data "update/check_available" (500)
2022-12-08 18:09:36.121 WARNING (MainThread) [homeassistant.components.sensor] Updating ecobee sensor took longer than the scheduled update interval 0:00:30
2022-12-08 18:10:32.594 WARNING (SyncWorker_11) [custom_components.truenas.truenas_api] TrueNAS X.X.X.110 unable to fetch data "update/check_available" (500)
2022-12-08 18:11:32.593 WARNING (SyncWorker_0) [custom_components.truenas.truenas_api] TrueNAS X.X.X.110 unable to fetch data "update/check_available" (500)
2022-12-08 18:11:46.126 WARNING (MainThread) [homeassistant.helpers.entity] Update of sensor.ecobeeupstairs_temperature is taking over 10 seconds
2022-12-08 18:12:06.125 WARNING (MainThread) [homeassistant.components.sensor] Updating ecobee sensor took longer than the scheduled update interval 0:00:30
2022-12-08 18:12:32.591 WARNING (SyncWorker_8) [custom_components.truenas.truenas_api] TrueNAS X.X.X.110 unable to fetch data "update/check_available" (500)
2022-12-08 18:12:36.125 WARNING (MainThread) [homeassistant.components.sensor] Updating ecobee sensor took longer than the scheduled update interval 0:00:30
2022-12-08 18:13:32.591 WARNING (SyncWorker_10) [custom_components.truenas.truenas_api] TrueNAS X.X.X.110 unable to fetch data "update/check_available" (500)
2022-12-08 18:13:59.804 WARNING (SyncWorker_1) [homeassistant.components.waze_travel_time.sensor] Error on retrieving data: empty response
2022-12-08 18:14:32.591 WARNING (SyncWorker_13) [custom_components.truenas.truenas_api] TrueNAS X.X.X.110 unable to fetch data "update/check_available" (500)
2022-12-08 18:14:46.130 WARNING (MainThread) [homeassistant.helpers.entity] Update of sensor.ecobeeupstairs_temperature is taking over 10 seconds
2022-12-08 18:15:06.129 WARNING (MainThread) [homeassistant.components.sensor] Updating ecobee sensor took longer than the scheduled update interval 0:00:30
2022-12-08 18:15:32.589 WARNING (SyncWorker_14) [custom_components.truenas.truenas_api] TrueNAS X.X.X.110 unable to fetch data "update/check_available" (500)
2022-12-08 18:15:36.130 WARNING (MainThread) [homeassistant.components.sensor] Updating ecobee sensor took longer than the scheduled update interval 0:00:30
2022-12-08 18:16:32.592 WARNING (SyncWorker_14) [custom_components.truenas.truenas_api] TrueNAS X.X.X.110 unable to fetch data "update/check_available" (500)
2022-12-08 18:17:32.596 WARNING (SyncWorker_8) [custom_components.truenas.truenas_api] TrueNAS X.X.X.110 unable to fetch data "update/check_available" (500)
2022-12-08 18:17:46.136 WARNING (MainThread) [homeassistant.helpers.entity] Update of sensor.ecobeeupstairs_temperature is taking over 10 seconds
2022-12-08 18:18:06.135 WARNING (MainThread) [homeassistant.components.sensor] Updating ecobee sensor took longer than the scheduled update interval 0:00:30
2022-12-08 18:18:32.597 WARNING (SyncWorker_4) [custom_components.truenas.truenas_api] TrueNAS X.X.X.110 unable to fetch data "update/check_available" (500)
2022-12-08 18:18:36.136 WARNING (MainThread) [homeassistant.components.sensor] Updating ecobee sensor took longer than the scheduled update interval 0:00:30
2022-12-08 18:19:32.590 WARNING (SyncWorker_9) [custom_components.truenas.truenas_api] TrueNAS X.X.X.110 unable to fetch data "update/check_available" (500)
2022-12-08 18:20:32.592 WARNING (SyncWorker_6) [custom_components.truenas.truenas_api] TrueNAS X.X.X.110 unable to fetch data "update/check_available" (500)
2022-12-08 18:20:46.141 WARNING (MainThread) [homeassistant.helpers.entity] Update of sensor.ecobeeupstairs_temperature is taking over 10 seconds
2022-12-08 18:21:06.140 WARNING (MainThread) [homeassistant.components.sensor] Updating ecobee sensor took longer than the scheduled update interval 0:00:30
2022-12-08 18:21:32.591 WARNING (SyncWorker_13) [custom_components.truenas.truenas_api] TrueNAS X.X.X.110 unable to fetch data "update/check_available" (500)
2022-12-08 18:21:36.141 WARNING (MainThread) [homeassistant.components.sensor] Updating ecobee sensor took longer than the scheduled update interval 0:00:30
2022-12-08 18:22:32.595 WARNING (SyncWorker_7) [custom_components.truenas.truenas_api] TrueNAS X.X.X.110 unable to fetch data "update/check_available" (500)
2022-12-08 18:23:32.592 WARNING (SyncWorker_0) [custom_components.truenas.truenas_api] TrueNAS X.X.X.110 unable to fetch data "update/check_available" (500)
2022-12-08 18:23:46.147 WARNING (MainThread) [homeassistant.helpers.entity] Update of sensor.ecobeeupstairs_temperature is taking over 10 seconds
2022-12-08 18:24:06.146 WARNING (MainThread) [homeassistant.components.sensor] Updating ecobee sensor took longer than the scheduled update interval 0:00:30
2022-12-08 18:24:09.676 WARNING (MainThread) [homeassistant.helpers.entity] Update of sensor.simone_travel_time_to_home is taking over 10 seconds
2022-12-08 18:24:32.596 WARNING (SyncWorker_4) [custom_components.truenas.truenas_api] TrueNAS X.X.X.110 unable to fetch data "update/check_available" (500)
2022-12-08 18:24:36.146 WARNING (MainThread) [homeassistant.components.sensor] Updating ecobee sensor took longer than the scheduled update interval 0:00:30
2022-12-08 18:25:32.592 WARNING (SyncWorker_10) [custom_components.truenas.truenas_api] TrueNAS X.X.X.110 unable to fetch data "update/check_available" (500)
2022-12-08 18:26:32.595 WARNING (SyncWorker_11) [custom_components.truenas.truenas_api] TrueNAS X.X.X.110 unable to fetch data "update/check_available" (500)
2022-12-08 18:26:46.152 WARNING (MainThread) [homeassistant.helpers.entity] Update of sensor.ecobeeupstairs_temperature is taking over 10 seconds
2022-12-08 18:27:06.151 WARNING (MainThread) [homeassistant.components.sensor] Updating ecobee sensor took longer than the scheduled update interval 0:00:30
2022-12-08 18:27:32.591 WARNING (SyncWorker_11) [custom_components.truenas.truenas_api] TrueNAS X.X.X.110 unable to fetch data "update/check_available" (500)
2022-12-08 18:27:36.151 WARNING (MainThread) [homeassistant.components.sensor] Updating ecobee sensor took longer than the scheduled update interval 0:00:30
2022-12-08 18:28:32.596 WARNING (SyncWorker_5) [custom_components.truenas.truenas_api] TrueNAS X.X.X.110 unable to fetch data "update/check_available" (500)
2022-12-08 18:28:59.830 WARNING (SyncWorker_4) [homeassistant.components.waze_travel_time.sensor] Error on retrieving data: empty response
2022-12-08 18:29:32.596 WARNING (SyncWorker_11) [custom_components.truenas.truenas_api] TrueNAS X.X.X.110 unable to fetch data "update/check_available" (500)
2022-12-08 18:29:46.156 WARNING (MainThread) [homeassistant.helpers.entity] Update of sensor.ecobeeupstairs_temperature is taking over 10 seconds
2022-12-08 18:30:06.156 WARNING (MainThread) [homeassistant.components.sensor] Updating ecobee sensor took longer than the scheduled update interval 0:00:30
2022-12-08 18:30:32.595 WARNING (SyncWorker_14) [custom_components.truenas.truenas_api] TrueNAS X.X.X.110 unable to fetch data "update/check_available" (500)
2022-12-08 18:30:36.157 WARNING (MainThread) [homeassistant.components.sensor] Updating ecobee sensor took longer than the scheduled update interval 0:00:30
2022-12-08 18:31:32.593 WARNING (SyncWorker_0) [custom_components.truenas.truenas_api] TrueNAS X.X.X.110 unable to fetch data "update/check_available" (500)
2022-12-08 18:32:32.592 WARNING (SyncWorker_0) [custom_components.truenas.truenas_api] TrueNAS X.X.X.110 unable to fetch data "update/check_available" (500)
2022-12-08 18:32:46.164 WARNING (MainThread) [homeassistant.helpers.entity] Update of sensor.ecobeeupstairs_temperature is taking over 10 seconds
2022-12-08 18:33:06.162 WARNING (MainThread) [homeassistant.components.sensor] Updating ecobee sensor took longer than the scheduled update interval 0:00:30
2022-12-08 18:33:32.596 WARNING (SyncWorker_13) [custom_components.truenas.truenas_api] TrueNAS X.X.X.110 unable to fetch data "update/check_available" (500)
2022-12-08 18:33:36.163 WARNING (MainThread) [homeassistant.components.sensor] Updating ecobee sensor took longer than the scheduled update interval 0:00:30
2022-12-08 18:34:32.592 WARNING (SyncWorker_14) [custom_components.truenas.truenas_api] TrueNAS X.X.X.110 unable to fetch data "update/check_available" (500)
2022-12-08 18:35:32.597 WARNING (SyncWorker_1) [custom_components.truenas.truenas_api] TrueNAS X.X.X.110 unable to fetch data "update/check_available" (500)
2022-12-08 18:35:46.169 WARNING (MainThread) [homeassistant.helpers.entity] Update of sensor.ecobeeupstairs_temperature is taking over 10 seconds
2022-12-08 18:36:06.168 WARNING (MainThread) [homeassistant.components.sensor] Updating ecobee sensor took longer than the scheduled update interval 0:00:30
2022-12-08 18:36:32.600 WARNING (SyncWorker_0) [custom_components.truenas.truenas_api] TrueNAS X.X.X.110 unable to fetch data "update/check_available" (500)
2022-12-08 18:36:36.169 WARNING (MainThread) [homeassistant.components.sensor] Updating ecobee sensor took longer than the scheduled update interval 0:00:30
2022-12-08 18:37:32.597 WARNING (SyncWorker_14) [custom_components.truenas.truenas_api] TrueNAS X.X.X.110 unable to fetch data "update/check_available" (500)
2022-12-08 18:38:32.596 WARNING (SyncWorker_0) [custom_components.truenas.truenas_api] TrueNAS X.X.X.110 unable to fetch data "update/check_available" (500)
2022-12-08 18:38:46.176 WARNING (MainThread) [homeassistant.helpers.entity] Update of sensor.ecobeeupstairs_temperature is taking over 10 seconds
2022-12-08 18:39:06.175 WARNING (MainThread) [homeassistant.components.sensor] Updating ecobee sensor took longer than the scheduled update interval 0:00:30
2022-12-08 18:39:09.656 WARNING (MainThread) [homeassistant.helpers.entity] Update of sensor.torsten_travel_time_to_home is taking over 10 seconds
2022-12-08 18:39:16.730 ERROR (MainThread) [homeassistant.components.automation.test_kitchen_echo_device] govee plug 1 status: Error executing script. Service not found for call_service at pos 1: Unable to find service notify.alexa_media
2022-12-08 18:39:32.596 WARNING (SyncWorker_5) [custom_components.truenas.truenas_api] TrueNAS X.X.X.110 unable to fetch data "update/check_available" (500)
2022-12-08 18:39:36.175 WARNING (MainThread) [homeassistant.components.sensor] Updating ecobee sensor took longer than the scheduled update interval 0:00:30
2022-12-08 18:40:16.813 ERROR (MainThread) [homeassistant.components.automation.test_kitchen_echo_device] govee plug 1 status: Error executing script. Service not found for call_service at pos 1: Unable to find service notify.alexa_media
2022-12-08 18:40:32.594 WARNING (SyncWorker_11) [custom_components.truenas.truenas_api] TrueNAS X.X.X.110 unable to fetch data "update/check_available" (500)
2022-12-08 18:41:32.596 WARNING (SyncWorker_10) [custom_components.truenas.truenas_api] TrueNAS X.X.X.110 unable to fetch data "update/check_available" (500)
2022-12-08 18:41:46.178 WARNING (MainThread) [homeassistant.helpers.entity] Update of sensor.ecobeeupstairs_temperature is taking over 10 seconds
2022-12-08 18:42:06.178 WARNING (MainThread) [homeassistant.components.sensor] Updating ecobee sensor took longer than the scheduled update interval 0:00:30
2022-12-08 18:42:32.593 WARNING (SyncWorker_3) [custom_components.truenas.truenas_api] TrueNAS X.X.X.110 unable to fetch data "update/check_available" (500)
2022-12-08 18:42:36.178 WARNING (MainThread) [homeassistant.components.sensor] Updating ecobee sensor took longer than the scheduled update interval 0:00:30
2022-12-08 18:43:32.590 WARNING (SyncWorker_13) [custom_components.truenas.truenas_api] TrueNAS X.X.X.110 unable to fetch data "update/check_available" (500)
2022-12-08 18:44:32.594 WARNING (SyncWorker_10) [custom_components.truenas.truenas_api] TrueNAS X.X.X.110 unable to fetch data "update/check_available" (500)
2022-12-08 18:44:46.185 WARNING (MainThread) [homeassistant.helpers.entity] Update of sensor.ecobeeupstairs_temperature is taking over 10 seconds
2022-12-08 18:45:06.184 WARNING (MainThread) [homeassistant.components.sensor] Updating ecobee sensor took longer than the scheduled update interval 0:00:30
2022-12-08 18:45:32.590 WARNING (SyncWorker_7) [custom_components.truenas.truenas_api] TrueNAS X.X.X.110 unable to fetch data "update/check_available" (500)
2022-12-08 18:45:36.185 WARNING (MainThread) [homeassistant.components.sensor] Updating ecobee sensor took longer than the scheduled update interval 0:00:30
2022-12-08 18:46:32.593 WARNING (SyncWorker_14) [custom_components.truenas.truenas_api] TrueNAS X.X.X.110 unable to fetch data "update/check_available" (500)
2022-12-08 18:47:32.589 WARNING (SyncWorker_6) [custom_components.truenas.truenas_api] TrueNAS X.X.X.110 unable to fetch data "update/check_available" (500)
2022-12-08 18:47:46.190 WARNING (MainThread) [homeassistant.helpers.entity] Update of sensor.ecobeeupstairs_temperature is taking over 10 seconds
2022-12-08 18:48:06.190 WARNING (MainThread) [homeassistant.components.sensor] Updating ecobee sensor took longer than the scheduled update interval 0:00:30
2022-12-08 18:48:32.589 WARNING (SyncWorker_5) [custom_components.truenas.truenas_api] TrueNAS X.X.X.110 unable to fetch data "update/check_available" (500)
2022-12-08 18:48:36.191 WARNING (MainThread) [homeassistant.components.sensor] Updating ecobee sensor took longer than the scheduled update interval 0:00:30
2022-12-08 18:49:06.192 WARNING (MainThread) [homeassistant.components.sensor] Updating ecobee sensor took longer than the scheduled update interval 0:00:30
2022-12-08 18:49:32.592 WARNING (SyncWorker_12) [custom_components.truenas.truenas_api] TrueNAS X.X.X.110 unable to fetch data "update/check_available" (500)
2022-12-08 18:49:36.193 WARNING (MainThread) [homeassistant.components.sensor] Updating ecobee sensor took longer than the scheduled update interval 0:00:30
2022-12-08 18:50:06.193 WARNING (MainThread) [homeassistant.components.sensor] Updating ecobee sensor took longer than the scheduled update interval 0:00:30
2022-12-08 18:50:32.592 WARNING (SyncWorker_12) [custom_components.truenas.truenas_api] TrueNAS X.X.X.110 unable to fetch data "update/check_available" (500)
2022-12-08 18:50:36.195 WARNING (MainThread) [homeassistant.components.sensor] Updating ecobee sensor took longer than the scheduled update interval 0:00:30
2022-12-08 18:50:47.005 WARNING (MainThread) [homeassistant.helpers.entity] Update of weather.ecobeeupstairs is taking over 10 seconds
2022-12-08 18:51:07.006 WARNING (MainThread) [homeassistant.components.weather] Updating ecobee weather took longer than the scheduled update interval 0:00:30
2022-12-08 18:51:32.590 WARNING (SyncWorker_7) [custom_components.truenas.truenas_api] TrueNAS X.X.X.110 unable to fetch data "update/check_available" (500)
2022-12-08 18:51:37.008 WARNING (MainThread) [homeassistant.components.weather] Updating ecobee weather took longer than the scheduled update interval 0:00:30
2022-12-08 18:52:32.589 WARNING (SyncWorker_6) [custom_components.truenas.truenas_api] TrueNAS X.X.X.110 unable to fetch data "update/check_available" (500)
2022-12-08 18:53:32.591 WARNING (SyncWorker_9) [custom_components.truenas.truenas_api] TrueNAS X.X.X.110 unable to fetch data "update/check_available" (500)
2022-12-08 18:53:47.014 WARNING (MainThread) [homeassistant.helpers.entity] Update of weather.ecobeeupstairs is taking over 10 seconds
2022-12-08 18:54:07.015 WARNING (MainThread) [homeassistant.components.weather] Updating ecobee weather took longer than the scheduled update interval 0:00:30
2022-12-08 18:54:32.588 WARNING (SyncWorker_12) [custom_components.truenas.truenas_api] TrueNAS X.X.X.110 unable to fetch data "update/check_available" (500)
2022-12-08 18:54:37.016 WARNING (MainThread) [homeassistant.components.weather] Updating ecobee weather took longer than the scheduled update interval 0:00:30
2022-12-08 18:55:32.592 WARNING (SyncWorker_2) [custom_components.truenas.truenas_api] TrueNAS X.X.X.110 unable to fetch data "update/check_available" (500)
2022-12-08 18:56:32.588 WARNING (SyncWorker_0) [custom_components.truenas.truenas_api] TrueNAS X.X.X.110 unable to fetch data "update/check_available" (500)
2022-12-08 18:56:47.024 WARNING (MainThread) [homeassistant.helpers.entity] Update of weather.ecobeeupstairs is taking over 10 seconds
2022-12-08 18:57:07.020 WARNING (MainThread) [homeassistant.components.weather] Updating ecobee weather took longer than the scheduled update interval 0:00:30
2022-12-08 18:57:32.591 WARNING (SyncWorker_2) [custom_components.truenas.truenas_api] TrueNAS X.X.X.110 unable to fetch data "update/check_available" (500)
2022-12-08 18:57:37.024 WARNING (MainThread) [homeassistant.components.weather] Updating ecobee weather took longer than the scheduled update interval 0:00:30
2022-12-08 18:58:32.591 WARNING (SyncWorker_9) [custom_components.truenas.truenas_api] TrueNAS X.X.X.110 unable to fetch data "update/check_available" (500)
2022-12-08 18:59:32.589 WARNING (SyncWorker_1) [custom_components.truenas.truenas_api] TrueNAS X.X.X.110 unable to fetch data "update/check_available" (500)
2022-12-08 18:59:47.028 WARNING (MainThread) [homeassistant.helpers.entity] Update of weather.ecobeeupstairs is taking over 10 seconds
2022-12-08 19:00:07.028 WARNING (MainThread) [homeassistant.components.weather] Updating ecobee weather took longer than the scheduled update interval 0:00:30
2022-12-08 19:00:32.591 WARNING (SyncWorker_7) [custom_components.truenas.truenas_api] TrueNAS X.X.X.110 unable to fetch data "update/check_available" (500)
2022-12-08 19:00:37.029 WARNING (MainThread) [homeassistant.components.weather] Updating ecobee weather took longer than the scheduled update interval 0:00:30
2022-12-08 19:01:32.587 WARNING (SyncWorker_0) [custom_components.truenas.truenas_api] TrueNAS X.X.X.110 unable to fetch data "update/check_available" (500)
2022-12-08 19:02:32.591 WARNING (SyncWorker_1) [custom_components.truenas.truenas_api] TrueNAS X.X.X.110 unable to fetch data "update/check_available" (500)
2022-12-08 19:02:40.633 WARNING (MainThread) [homeassistant.helpers.entity] Update of climate.main_floor is taking over 10 seconds
2022-12-08 19:03:32.587 WARNING (SyncWorker_5) [custom_components.truenas.truenas_api] TrueNAS X.X.X.110 unable to fetch data "update/check_available" (500)
2022-12-08 19:04:32.591 WARNING (SyncWorker_8) [custom_components.truenas.truenas_api] TrueNAS X.X.X.110 unable to fetch data "update/check_available" (500)
2022-12-08 19:05:32.591 WARNING (SyncWorker_13) [custom_components.truenas.truenas_api] TrueNAS X.X.X.110 unable to fetch data "update/check_available" (500)
Next log…
2
ms, be sure to disable it if you experience issues with Home Assistant
2022-12-08 13:18:45.634 WARNING (SyncWorker_4) [homeassistant.loader] We found a custom integration govee which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2022-12-08 13:18:59.306 WARNING (SyncWorker_0) [homeassistant.components.local_file.camera] Could not read camera driveway_camera image from file: /config/www/images/driveway.jpg
2022-12-08 13:19:09.751 WARNING (MainThread) [homeassistant.components.media_player] Setup of media_player platform dlna_dmr is taking over 10 seconds.
2022-12-08 13:19:10.653 ERROR (MainThread) [homeassistant.components.roku.coordinator] Error fetching roku data: Invalid response from API: Error occurred while communicating with device
2022-12-08 13:19:10.682 ERROR (MainThread) [homeassistant.components.roku.coordinator] Error fetching roku data: Invalid response from API: Error occurred while communicating with device
2022-12-08 13:19:11.318 WARNING (MainThread) [custom_components.govee] API is back online.
2022-12-08 13:19:13.595 WARNING (SyncWorker_6) [custom_components.truenas.truenas_api] TrueNAS X.X.X.110 unable to fetch data "update/check_available" (500)
2022-12-08 13:19:16.088 WARNING (MainThread) [homeassistant.components.sensor] Setup of sensor platform ipp is taking over 10 seconds.
2022-12-08 13:19:21.108 WARNING (MainThread) [reolink.camera_api] Host: camera-basement.domain.local: Failed to get results for Search, JSON data was was empty?
2022-12-08 13:20:00.238 WARNING (MainThread) [homeassistant.bootstrap] Waiting on integrations to complete setup: ecobee, emporia_vue
2022-12-08 13:20:39.586 WARNING (SyncWorker_6) [custom_components.truenas.truenas_api] TrueNAS X.X.X.110 unable to fetch data "update/check_available" (500)
2022-12-08 13:20:50.100 ERROR (MainThread) [custom_components.reolink_dev] Timeout fetching reolink.Garage.motion_states data
2022-12-08 13:20:51.241 ERROR (MainThread) [custom_components.reolink_dev] Timeout fetching reolink.Basement1.motion_states data
2022-12-08 13:21:00.361 WARNING (MainThread) [homeassistant.bootstrap] Waiting on integrations to complete setup: emporia_vue
2022-12-08 13:21:13.669 ERROR (MainThread) [frontend.js.latest.202212070] http://hass.domain.local:8123/lovelace/0:0:0 Uncaught
2022-12-08 13:21:39.585 WARNING (SyncWorker_2) [custom_components.truenas.truenas_api] TrueNAS X.X.X.110 unable to fetch data "update/check_available" (500)
2022-12-08 13:22:00.454 WARNING (MainThread) [homeassistant.bootstrap] Waiting on integrations to complete setup: emporia_vue
2022-12-08 13:22:39.585 WARNING (SyncWorker_1) [custom_components.truenas.truenas_api] TrueNAS X.X.X.110 unable to fetch data "update/check_available" (500)
2022-12-08 13:23:00.552 WARNING (MainThread) [homeassistant.bootstrap] Waiting on integrations to complete setup: emporia_vue
2022-12-08 13:23:09.567 WARNING (MainThread) [homeassistant.helpers.entity] Update of climate.ecobeeupstairs is taking over 10 seconds
2022-12-08 13:23:39.588 WARNING (SyncWorker_10) [custom_components.truenas.truenas_api] TrueNAS X.X.X.110 unable to fetch data "update/check_available" (500)
2022-12-08 13:23:57.118 WARNING (MainThread) [homeassistant.bootstrap] Setup timed out for stage 2 - moving forward
2022-12-08 13:23:59.565 WARNING (MainThread) [homeassistant.components.climate] Updating ecobee climate took longer than the scheduled update interval 0:01:00
2022-12-08 13:24:00.659 WARNING (MainThread) [homeassistant.bootstrap] Waiting on integrations to complete setup: emporia_vue
2022-12-08 13:24:27.772 WARNING (MainThread) [homeassistant.helpers.entity] Update of sensor.jason_travel_time_to_home is taking over 10 seconds
2022-12-08 13:24:27.794 WARNING (MainThread) [homeassistant.helpers.entity] Update of sensor.simone_travel_time_to_home is taking over 10 seconds
2022-12-08 13:24:39.588 WARNING (SyncWorker_0) [custom_components.truenas.truenas_api] TrueNAS X.X.X.110 unable to fetch data "update/check_available" (500)
2022-12-08 13:25:00.768 WARNING (MainThread) [homeassistant.bootstrap] Waiting on integrations to complete setup: emporia_vue
2022-12-08 13:25:39.588 WARNING (SyncWorker_1) [custom_components.truenas.truenas_api] TrueNAS X.X.X.110 unable to fetch data "update/check_available" (500)
2022-12-08 13:26:00.884 WARNING (MainThread) [homeassistant.bootstrap] Waiting on integrations to complete setup: emporia_vue
2022-12-08 13:26:09.569 WARNING (MainThread) [homeassistant.helpers.entity] Update of climate.ecobeeupstairs is taking over 10 seconds
2022-12-08 13:26:39.589 WARNING (SyncWorker_3) [custom_components.truenas.truenas_api] TrueNAS X.X.X.110 unable to fetch data "update/check_available" (500)
2022-12-08 13:26:59.570 WARNING (MainThread) [homeassistant.components.climate] Updating ecobee climate took longer than the scheduled update interval 0:01:00
2022-12-08 13:27:00.993 WARNING (MainThread) [homeassistant.bootstrap] Waiting on integrations to complete setup: emporia_vue
2022-12-08 13:27:39.588 WARNING (SyncWorker_9) [custom_components.truenas.truenas_api] TrueNAS X.X.X.110 unable to fetch data "update/check_available" (500)
2022-12-08 13:27:57.893 ERROR (MainThread) [frontend.js.latest.202212070] http://hass.domain.local:8123/lovelace/0:0:0 Uncaught
2022-12-08 13:28:01.101 WARNING (MainThread) [homeassistant.bootstrap] Waiting on integrations to complete setup: emporia_vue
2022-12-08 13:28:39.590 WARNING (SyncWorker_7) [custom_components.truenas.truenas_api] TrueNAS X.X.X.110 unable to fetch data "update/check_available" (500)
2022-12-08 13:28:57.124 WARNING (MainThread) [homeassistant.bootstrap] Setup timed out for bootstrap - moving forward
2022-12-08 13:28:57.293 ERROR (MainThread) [homeassistant.components.hassio.discovery] Can't read discover info: System is not ready with state: shutdown
2022-12-08 13:28:57.642 WARNING (SyncWorker_13) [homeassistant.components.waze_travel_time.sensor] Error on retrieving data: empty response
2022-12-08 13:28:58.469 ERROR (MainThread) [homeassistant.components.automation.demo] Home Assistant startup / shutdown messages: Choose at step 1: choice 1: Error executing script. Service not found for call_service at pos 2: Unable to find service notify.alexa_media
2022-12-08 13:28:58.809 ERROR (MainThread) [homeassistant.components.automation.demo] Home Assistant startup / shutdown messages: Error executing script. Service not found for choose at pos 1: Unable to find service notify.alexa_media
2022-12-08 13:29:00.162 ERROR (MainThread) [homeassistant.components.hassio] Error fetching hassio data: Error on Supervisor API: System is not ready with state: shutdown
2022-12-08 13:29:08.086 ERROR (MainThread) [homeassistant.components.homeassistant_alerts] Timeout fetching homeassistant_alerts data
2022-12-08 13:29:10.053 WARNING (MainThread) [homeassistant.helpers.entity] Update of climate.ecobeeupstairs is taking over 10 seconds
2022-12-08 13:29:39.587 WARNING (SyncWorker_4) [custom_components.truenas.truenas_api] TrueNAS X.X.X.110 unable to fetch data "update/check_available" (500)
2022-12-08 13:29:47.220 WARNING (Thread-103 (_do_shutdown)) [homeassistant.util.executor] Thread[SyncWorker_13] is still running at shutdown: File "/usr/local/lib/python3.10/threading.py", line 973, in _bootstrap
self._bootstrap_inner()
File "/usr/local/lib/python3.10/threading.py", line 1016, in _bootstrap_inner
self.run()
File "/usr/local/lib/python3.10/threading.py", line 953, in run
self._target(*self._args, **self._kwargs)
File "/usr/local/lib/python3.10/concurrent/futures/thread.py", line 83, in _worker
work_item.run()
File "/usr/local/lib/python3.10/concurrent/futures/thread.py", line 58, in run
File "/usr/local/lib/python3.10/site-packages/pyecobee/__init__.py", line 221, in update
return self.get_thermostats()
File "/usr/local/lib/python3.10/site-packages/pyecobee/__init__.py", line 197, in get_thermostats
response = self._request_with_refresh(
File "/usr/local/lib/python3.10/site-packages/pyecobee/__init__.py", line 696, in _request_with_refresh
response = self._request(
File "/usr/local/lib/python3.10/site-packages/pyecobee/__init__.py", line 742, in _request
response = requests.request(
File "/usr/local/lib/python3.10/site-packages/requests/api.py", line 59, in request
return session.request(method=method, url=url, **kwargs)
File "/usr/local/lib/python3.10/site-packages/requests/sessions.py", line 587, in request
resp = self.send(prep, **send_kwargs)
File "/usr/local/lib/python3.10/site-packages/requests/sessions.py", line 701, in send
r = adapter.send(request, **kwargs)
File "/usr/local/lib/python3.10/site-packages/requests/adapters.py", line 489, in send
resp = conn.urlopen(
File "/usr/local/lib/python3.10/site-packages/urllib3/connectionpool.py", line 703, in urlopen
httplib_response = self._make_request(
File "/usr/local/lib/python3.10/site-packages/urllib3/connectionpool.py", line 386, in _make_request
self._validate_conn(conn)
File "/usr/local/lib/python3.10/site-packages/urllib3/connectionpool.py", line 1042, in _validate_conn
conn.connect()
File "/usr/local/lib/python3.10/site-packages/urllib3/connection.py", line 358, in connect
self.sock = conn = self._new_conn()
File "/usr/local/lib/python3.10/site-packages/urllib3/connection.py", line 174, in _new_conn
conn = connection.create_connection(
File "/usr/local/lib/python3.10/site-packages/urllib3/util/connection.py", line 85, in create_connection
sock.connect(sa)
2022-12-08 13:29:47.310 WARNING (Thread-103 (_do_shutdown)) [homeassistant.util.executor] Thread[SyncWorker_5] is still running at shutdown: File "/usr/local/lib/python3.10/threading.py", line 973, in _bootstrap
self.run()
work_item.run()
File "/usr/local/lib/python3.10/site-packages/pyemvue/pyemvue.py", line 207, in login
self.auth = Auth(
File "/usr/local/lib/python3.10/site-packages/pyemvue/auth.py", line 51, in __init__
self.tokens = self.refresh_tokens()
File "/usr/local/lib/python3.10/site-packages/pyemvue/auth.py", line 55, in refresh_tokens
self.cognito.renew_access_token()
File "/usr/local/lib/python3.10/site-packages/pycognito/__init__.py", line 660, in renew_access_token
refresh_response = self.client.initiate_auth(
File "/usr/local/lib/python3.10/site-packages/botocore/client.py", line 391, in _api_call
return self._make_api_call(operation_name, kwargs)
File "/usr/local/lib/python3.10/site-packages/botocore/client.py", line 705, in _make_api_call
http, parsed_response = self._make_request(
File "/usr/local/lib/python3.10/site-packages/botocore/client.py", line 725, in _make_request
return self._endpoint.make_request(operation_model, request_dict)
File "/usr/local/lib/python3.10/site-packages/botocore/endpoint.py", line 104, in make_request
return self._send_request(request_dict, operation_model)
File "/usr/local/lib/python3.10/site-packages/botocore/endpoint.py", line 136, in _send_request
success_response, exception = self._get_response(
File "/usr/local/lib/python3.10/site-packages/botocore/endpoint.py", line 167, in _get_response
success_response, exception = self._do_get_response(
File "/usr/local/lib/python3.10/site-packages/botocore/endpoint.py", line 201, in _do_get_response
http_response = self._send(request)
File "/usr/local/lib/python3.10/site-packages/botocore/endpoint.py", line 270, in _send
return self.http_session.send(request)
File "/usr/local/lib/python3.10/site-packages/botocore/httpsession.py", line 385, in send
urllib_response = conn.urlopen(
conn.connect()
sock.connect(sa)
2022-12-08 13:29:47.805 WARNING (Thread-103 (_do_shutdown)) [homeassistant.util.executor] Thread[SyncWorker_5] is still running at shutdown: File "/usr/local/lib/python3.10/threading.py", line 973, in _bootstrap
self.run()
work_item.run()
self.auth = Auth(
conn.connect()
sock.connect(sa)
2022-12-08 13:29:48.300 WARNING (Thread-103 (_do_shutdown)) [homeassistant.util.executor] Thread[SyncWorker_13] is still running at shutdown: File "/usr/local/lib/python3.10/threading.py", line 973, in _bootstrap
self.run()
work_item.run()
conn.connect()
sock.connect(sa)
2022-12-08 13:29:57.201 WARNING (MainThread) [homeassistant.util.executor] Thread[SyncWorker_13] is still running at shutdown: File "/usr/local/lib/python3.10/threading.py", line 973, in _bootstrap
self.run()
work_item.run()
conn.connect()
sock.connect(sa)
2022-12-08 13:29:57.277 WARNING (MainThread) [homeassistant.util.executor] Thread[SyncWorker_5] is still running at shutdown: File "/usr/local/lib/python3.10/threading.py", line 973, in _bootstrap
self.run()
work_item.run()
self.auth = Auth(
conn.connect()
sock.connect(sa)
2022-12-08 13:29:57.774 WARNING (MainThread) [homeassistant.util.executor] Thread[SyncWorker_5] is still running at shutdown: File "/usr/local/lib/python3.10/threading.py", line 973, in _bootstrap
self.run()
work_item.run()
self.auth = Auth(
conn.connect()
sock.connect(sa)
2022-12-08 13:29:58.270 WARNING (MainThread) [homeassistant.util.executor] Thread[SyncWorker_13] is still running at shutdown: File "/usr/local/lib/python3.10/threading.py", line 973, in _bootstrap
self.run()
work_item.run()
conn.connect()
sock.connect(sa)
Your system is not starting up fully. It seems like your custom integrations are blocking everything.
I’d start by removing TrueNas and go from there.
That is interesting Petro, I thought it was the Alexa one, I removed that one. I am building a new HASS system right now, I still have the original SD card, but I seem to be able to go about 4 core updates, then my entire system stops working and I just rebuild from scratch, usually faster that way - but as you know, these systems are super configured after a period of time, so you lose a lot. This time, I logged a post on the community… I will give that a shot a little later on…
Would you recommend removing each customization untitl it starts to work again…?
