Yes they all do
If we have the functionality in the UI to set the colour on entity.state level we are set I am sure.
I have a relative simple colour configuration based on the original defaults settings:
Entities on off unavailable unknown:yellow, white, transparent.
History graphs, gauges: green, red. Where possible yellow in between. Unavailable and unknown Transparent.
Heating and cooling: orange and blue
A very limited set of colours with a clear meaning to avoid any confusion.
Examples:
it requires unique_id set for all entities. Do all integrations support it already?
Anyway I would prefer setting it in a theme (for each class). It would be more efficient than setting each entity separately. But yes, there might be cases requiring special color, which overrides default.
As far as I know every entity can have an unique id.
Perhaps per entity itās very granular but it gives maximum flexibility.
Not yet the case.
Iāve been scrolling and searching but I couldnāt find a solution for the colors of the zones? Now they all have the same color besides home. is there a way to set up their own color at this point? maybe in config.yaml since I donāt see an option in the UI for zones
Find my issue regarding zones in History.
So far no neither a solution nor a feedback from Dev.
Paul, could you answer these questions:
Is there a theme variable for āunknown stateā - icon, history? Cannot find it here.
Update: is it"--state-unknown-color: #606060"
? Is it used for icons & history? -
What is a current progress for transparent history for āunavailableā - are there any plans to rectify observations from āHistory-graph: do not make a graph for āunavailableā sensor transparentā issue?
It was mentioned in the issue:
ā absence of a graph treated by many people as a bug;
ā even if a label āunavailableā will be added on the transparent graph - it will not be noticeable;
ā will not be possible to distinguish āunavailableā case & ādoes not existā case;
ā since icon color = history color for all states, it is inconsistent to use different colors for āunavailableā - it is better to use a themeable variable for āunavailableā for icon & history. -
Are there any plans to refactor the freshly added variables from ā255,255,255ā format to conventional CSS formats like ārgba(255,255,255,0.9)ā, ā#ffffffā, āredā? (the āInconsistency with defining colors in a default themeā issue was closed by you).
Are there any plans to restore different colors for zones in history? Check the āDifferent zones in History have same colorā issue.
@piitaya , sorry for tagging you in the post to get your attention.
Updates:
- Some actions take place regarding colors for a Tile card - I hope that this is a part of āusing traditional approaches to define colorsā way.
- As it was already stated many times - as long as a color for a particular domain/device_class/state may be defined by a dedicated unique theme variable, default colors & issues like āwhy red stands for heating?ā, āwhy using this color for color-blinded peopleā etc are NOT a big problem since everything may be customized.
But pretty close I assume !
Actually, quite the opposite.
@Ih8rain2 I wishm but unfortunately there are many that donāt. Just look at the Envisalink integration for instance. It doesnāt support UniqueID and you cannot add it. I answer a question about it at least once a month.
Guys I was not aware. Because for the majority of entities I have an unique id. And for changing names, areas and icons and some other options it works beautifully. My bad !
Just discovered this yesterday after an update. Green icon for a āarmedā security system??? Without UniqueID, what are our options? Really wish I had the skills to modify the Envisalink Integrationā¦
Mitch
Oh youāre not wrong - It NEEDS to be addedā¦ but thatās a completely different discussion.
itās just a typo, not marked that way in github Release 2022.12.6 Ā· home-assistant/core Ā· GitHub
Just follow the marked solution in this post and create a theme to set the color to whatever you want
Will do. Thanks!!
Just a quick comment to say thank you to the Devs for listening to the community and coming up with a fix for the colour problems.
My default non-themed system is now back looking right again.
Cheers.
// HISTORY CHART BAR: OFF & TILE CARD ICON
document.documentElement.style.setProperty('--rgb-state-inactive-color', '255, 0, 255');
is now working for me (2022.12.5)
this will probably be the thread where color caring people join these days, so please let me put forward a question in the color scales.
After some serious readup on dB/dBm, I am trying to color my sensors for signal_strength in their various HA incarnations. They are a varied bunch, but most seem to use the dBm scale where this is the buildup:
-30 dBm: maximum signal strength. If you have this measurement, you are likely standing right next to the access point.
-50 dBm: excellent signal strength.
-60 dBm: good signal strength.
-67 dBm: reliable signal strength. This is the minimum for any online services that require a reliable connection and Wi-Fi signal strength.
-70 dBm: not a strong signal strength. You may be able to check your email.
-80 dBm: unreliable signal strength. You may be able to connect to your network, but you will not support most online activity.
-90 dBm: bad signal strength. You are not likely to connect to internet at this level.
since we dont have a coloring of those (yet) in Ha, like we do have now for eg battery %, I am faking that currently in custom-ui, with the following colors:
sensor.*_signal_strength:
<<: *hide
templates:
<<: &rssi_color
icon_color: >
if (state >= -50) return 'green';
if (state >= -60) return 'gold';
if (state >= -67) return 'orange';
if (state >= -70) return 'darkorange';
if (state >= -80) return 'maroon';
return 'red';
but, and hereās the real question, I am not very happy with the last 2/3 colors. Just doesnt seem to build up correctly for my eyes.
Would there be some universal scaling in UX for this? what would be the most appropriate ādefaultā color schema for scaling those rssi levels.
please let me know if you have some docs on that (or ideas ofc )
ps nevermind the overkiz covers, they use the dB scale, which also uses different numbers/scale.
