2022.12: It does matter!
have you already raised an issue for this?
What device are you running as coordinator?
I haven’t had any issues with my ZHA integration, while using the Sonoff Zigbee 3.0 USB Dongle with any of the 2022.12. releases - but they were a few that reported issues in the GIT…
I also agree, having made the update and seen the colour changes to my screens, I have backed it out. I don’t have the time or energy right now to research fixes to redevelop my UI colours. I spent much time getting the UI to a state where colours indicated states of various items at a glance and these changes have broken all that.
First time I have reversed any HA update!
Sometimes new useful functionality may not be fully useful.
Check this card:
These are four binary_sensors with “connectivity” device_class.
And only one of them has a state displayed - on other 3 graphs a long string “Connected” (or “Disconnected”) could not fit into a graph’s area.
Earlier, when we had “On / Off” only, this problem was faced more rarely.
Issue on Github.
Yes, only version that seems to work with.
No, but I’d imagine it’s already been reported, tho it hasn’t been addressed in the recent incremental updates. I’m using Tasmota flashed on a Sonoff Zigbee Bridge, if that’s makes any difference.
Assumption, the mother of screw ups.
The addons or integrations you guys are discussing are 3rd party aren’t they? Ask on their github.
I’ve resolved my issue, it was changes in the user (location) and HA network configurations ( I changed from DHCP to static ip with the broadcast and DNS entry, once I added the missing info everything started working and polling correct. Why it broke that only the coders know. But mine is fixed.
Please don’t post off-topic things. This is the thread for 2022.12 release and nothing changed in the 2022.12 with history labels.
No need to post here if you already posted an issue on GitHub :wink:
I didn’t read through all the comments, so maybe this has already been asked, but is there any chance that the Local Calander Integration can be set up to allow setting a monthly event based on day of the week and specific week of the month? As it currently stands, I have a month event that I have to configure for each month of the year because the current implementation only allows by date.
I observed these changes THIS release.
And this is related to your recent color chages:
in English we have “Disconnected” for “Off”; in some cases the long word “Disconnected” is not displayed, so a user should distinguish states by colors - which are soooo similar for “Off” and “unknown” these days.
So, a simple option like “show_native_states” (call it as you like) to show native “on/off” could be a good choice.
A github issue is for you, a post here is for users.
We should listen to as many opinions as possible.
Update: the issue was closed by this Dev. Not a surprise.
I have got the same error, but I can’t fix it. It worked great before version 2022.12 , but then it screwed.
I don’t use bluetooth, but esphome stopped work too:
ERROR (MainThread) [homeassistant.config_entries] Error occurred loading configuration flow for integration esphome: cannot import name 'BluetoothServiceInfoBleak' from 'home_assistant_bluetooth' (/var/lib/hass/.homeassistant/deps/lib/python3.10/site-packages/home_assistant_bluetooth/__init__.py)
Help me, please
You (and everyone else :wink:) should vote for this:
You need to update the base requirements in your venv
Hello everybody,
anyone have my same problem? when I click on a “button” on the dashboard, it flashes the whole map
problem
Tnks.
It’s ZHA integration issue, no plugins or add-ons were used.
I’ve already reported it, but it just gets ignored or closed.
That does not make sense if you also say you run native ZHA. What github issue was closed? If you report ZHA issue with a Sonoff bridge running Tasmota then it makes sense it gets closed.
I was referring to this wording
anyone else with this problem?
Does anyone have an issue with their LG WebOS TV?
Logger: aiohttp.server
Source: components/webostv/__init__.py:133
First occurred: 5:36:26 PM (3 occurrences)
Last logged: 5:37:47 PM
Error handling request
  File "/usr/local/lib/python3.10/site-packages/websockets/legacy/client.py", line 138, in read_http_response
    status_code, reason, headers = await read_response(self.reader)
  File "/usr/local/lib/python3.10/site-packages/websockets/legacy/http.py", line 120, in read_response
    status_line = await read_line(stream)
  File "/usr/local/lib/python3.10/site-packages/websockets/legacy/http.py", line 194, in read_line
    line = await stream.readline()
  File "/usr/local/lib/python3.10/asyncio/streams.py", line 525, in readline
    line = await self.readuntil(sep)
  File "/usr/local/lib/python3.10/asyncio/streams.py", line 617, in readuntil
    await self._wait_for_data('readuntil')
  File "/usr/local/lib/python3.10/asyncio/streams.py", line 502, in _wait_for_data
    await self._waiter
  File "/usr/local/lib/python3.10/asyncio/selector_events.py", line 854, in _read_ready__data_received
    data = self._sock.recv(self.max_size)
ConnectionResetError: [Errno 104] Connection reset by peer
  File "/usr/local/lib/python3.10/site-packages/aiohttp/web_protocol.py", line 435, in _handle_request
    resp = await request_handler(request)
  File "/usr/local/lib/python3.10/site-packages/aiohttp/web_app.py", line 504, in _handle
    resp = await handler(request)
  File "/usr/local/lib/python3.10/site-packages/aiohttp/web_middlewares.py", line 117, in impl
    return await handler(request)
  File "/usr/src/homeassistant/homeassistant/components/http/security_filter.py", line 60, in security_filter_middleware
  File "/usr/src/homeassistant/homeassistant/components/http/forwarded.py", line 100, in forwarded_middleware
  File "/usr/src/homeassistant/homeassistant/components/http/request_context.py", line 28, in request_context_middleware
  File "/usr/src/homeassistant/homeassistant/components/http/ban.py", line 81, in ban_middleware
  File "/usr/src/homeassistant/homeassistant/components/http/auth.py", line 236, in auth_middleware
  File "/usr/src/homeassistant/homeassistant/components/http/view.py", line 136, in handle
    result = await result
  File "/usr/src/homeassistant/homeassistant/components/config/config_entries.py", line 180, in post
    return await super().post(request, flow_id)
  File "/usr/src/homeassistant/homeassistant/components/http/data_validator.py", line 73, in wrapper
    result = await method(view, request, data, *args, **kwargs)
  File "/usr/src/homeassistant/homeassistant/helpers/data_entry_flow.py", line 110, in post
    result = await self._flow_mgr.async_configure(flow_id, data)
  File "/usr/src/homeassistant/homeassistant/data_entry_flow.py", line 281, in async_configure
    result = await self._async_handle_step(
  File "/usr/src/homeassistant/homeassistant/data_entry_flow.py", line 368, in _async_handle_step
    result: FlowResult = await getattr(flow, method)(user_input)
  File "/usr/src/homeassistant/homeassistant/components/webostv/config_flow.py", line 98, in async_step_pairing
    client = await async_control_connect(self._host, None)
  File "/usr/src/homeassistant/homeassistant/components/webostv/__init__.py", line 133, in async_control_connect
    await client.connect()
  File "/usr/local/lib/python3.10/site-packages/aiowebostv/webos_client.py", line 73, in connect
    return await self.connect_result
  File "/usr/local/lib/python3.10/site-packages/aiowebostv/webos_client.py", line 105, in connect_handler
    main_ws = await asyncio.wait_for(
  File "/usr/local/lib/python3.10/asyncio/tasks.py", line 445, in wait_for
    return fut.result()
  File "/usr/local/lib/python3.10/asyncio/tasks.py", line 650, in _wrap_awaitable
    return (yield from awaitable.__await__())
  File "/usr/local/lib/python3.10/site-packages/websockets/legacy/client.py", line 659, in __await_impl_timeout__
    return await asyncio.wait_for(self.__await_impl__(), self.open_timeout)
    return fut.result()
  File "/usr/local/lib/python3.10/site-packages/websockets/legacy/client.py", line 666, in __await_impl__
    await protocol.handshake(
  File "/usr/local/lib/python3.10/site-packages/websockets/legacy/client.py", line 326, in handshake
    status_code, response_headers = await self.read_http_response()
  File "/usr/local/lib/python3.10/site-packages/websockets/legacy/client.py", line 144, in read_http_response
    raise InvalidMessage("did not receive a valid HTTP response") from exc
websockets.exceptions.InvalidMessage: did not receive a valid HTTP response
Not that I have noticed, if I remember I’ll test tomorrow.
hi version 2022.12.9 is available for me since today (2023-01-03) , but it refuses to install, popup keeps spinning, and after 1 hour waiting, refreshing the page still shows it is available, opening the page will show ‘installing’
rebooted HA, did not help, after that it shows 2022.12.9 is available again, and 2nd time installing it gets same loop.
any ideas?
