2022.2: Let's start streamlining!
Homekit Controller is up and running on this release as I can confirm.
SOLVED by removing the Yaml for Device_tracker.
When I switch to the new version i get 3 major issues
Screenshot 2022-02-03 at 19.10.23
The zones are there. Status person.user says unknown.
Home Assistant IOS says this:
Screenshot 2022-02-03 at 19.17.52
Any ideas?
Thomas1509, same here. My graph is not updated in the dashboard but the sensor is. Nothing seems to update on that dashboard. My separate devices doesn’t update either.
Was there any update to the Chromecast devices?
All my Google mini’s remain active and all my Chromecast devices remain also active with the text “Backdrop”.
This removal of the Older Nest integration is premature. How can you remove support when the new api does not support Nest Protect and there is no estimate of when it will?!
        ##### Sonoff #####
sonoff:
  username: !secret sonoff_id
  password: !secret sonoff_pass
  mode: local
  reload: always  # update device list every time HA starts
  scan_interval: 60 #(optional, lower values than 60 won't work anymore!)
  grace_period: 600 #(optional)
  api_region: 'eu' #(optional)
  entity_prefix: True #(optional)
  debug: False #(optional)
Edit previous message: no issue with the Chromecast devices, but with the media player cards. The media player cards show active even when the state is idle
If you have NMAP configured in device tracker you can remove it and restart HA. It should get copied across so is not needed anymore. That cleared the device tracker and the iOS errors for me.
Nice, but, is it the Ewelink integration or SonoffLAN from HACS?
Same here Amcrest camera is timing out…seems to reconnect but many warning messages.
Yes, that’s the one… I thought it was the only one?
If its SonoffLAN from HACS, I only can confirm, it works fine here after this update.
What other options are there?
My issue is that they’ve seemed to disappear… the entities seem to have gone into orphan state.
look at 338
I have the same problem. Did you get an ant
I don’t know why they did this but so far it has just caused all of my players to look like they are playing.
From the release notes
" Make idle chromecasts appear as idle instead of off (@emontnemery - #61786) (cast docs)"
Thanks Neil. I disabled the YAML and everything is working fine again.
Hi!
Energy monitor stop working after HA update.
Same issue here. How did you solve it?
Post your errors so we can see what’s causing those integrations to fail to load.
