2022.2: Let's start streamlining!
This blog is a discussion space, not the place to post details about issues. Github is where I put issues and their details.
well apparently the details aren’t good enough in github. At this point it’s not a discussion, you just want to voice your displeasure.
I am getting the following error when running- Check Home Assistant configuration
Testing configuration at /tmp/config
INFO:homeassistant.helpers.storage:Migrating core.device_registry storage from 1.2 to 1.3
INFO:homeassistant.helpers.storage:Migrating core.entity_registry storage from 1.4 to 1.5
ERROR:homeassistant.helpers.check_config:Unexpected error validating config
File “/usr/local/lib/python3.9/site-packages/pkg_resources/init.py”, line 3016, in _dep_map
return self.__dep_map
File “/usr/local/lib/python3.9/site-packages/pkg_resources/init.py”, line 2813, in getattr
raise AttributeError(attr)
AttributeError: _DistInfoDistribution__dep_map
File “/usr/local/lib/python3.9/site-packages/pkg_resources/init.py”, line 3007, in _parsed_pkg_info
grep: write error: Broken pipe
[cont-finish.d] executing container finish scripts…
[cont-finish.d] done.
[s6-finish] waiting for services.
[s6-finish] sending all processes the TERM signal.
[s6-finish] sending all processes the KILL signal and exiting.
Anyone else see this? Trying again.
Wonderful work, thanks alot!
Everything works like a charm here, now for some digging in to all the new stuff <3
I found the solution. I need use the IP address as internal_url (http://192.168.1.118:8123/) , and the link changed after the HA update.
Before it was /media/Disarmed.mp3 and now it is: /media/media/Disarmed.mp3
Is remote_rpi_gpio also being deprecated?
My CPU load is significantly higher since I upgraded to 2022.2.0 on my RPi3B+. The load was about 6-12% previously, it’s now around 22-30%. As a result, the CPU temperature has risen by about 10°C.
Is anyone seeing this as well ?
Thanks!
Yes, I’ve noticed. All my Google Minis now always appear “on”. That means things like the custom:mini-media-player will always show the volume control. Before, the volume would be hidden when the devices weren’t active. I also have a second gen Chromecast that is the only thing I use to watch on one TV. I used to know if the TV was on based on the whether that media_player was on, but now it always appears on.
same issue here. is this really expected and we need to move to event triggers? doesn’t look like there’s mentioned something in the breaking changes?! looks more like a bug.
No…
The update was at about 13.00
A slight increase perhaps…
Mine are idle
Too bad google does the chime even if they appear idle
Thanks devs, this is my first major update since using Home Assistant for about a month and it went pretty smooth. This is a really cool project and I hope to have some time to contribute to it as well.
I was looking at this screenshot:
And I wondered, how to get this done? This is using the Spotify integration I think? I also have Spotify integrated in HA but the media section stays empty. How to get it filled with my Spotify playlists? This looks so nice.
Great! I’ll grab a backup and give it a try myself. Thanks for taking the risk letting us know all went well!
Seeing the same
I believe I figured out why my android TVs were suddenly shutting off. I believe the google assistant ‘local fullfillment’ was causing it. Its a really odd issue and I have a feeling most won’t narrow it down. I don’t think its home assistant per se.
This was added as a feature which I tried to adopt and caused odd things to happen to the android devices. Regular speakers worked fine. I have since removed the option and haven’t had a ghost turning off my theater system.
Hope it helps!
I agree it looks like a bug. I think I’ve seen this before and then it got fixed in one of the point releases.
Oh…
Make idle chromecasts appear as idle instead of off by emontnemery · Pull Request #61786 · home-assistant/core (github.com)
That is a good change then…
I had to select “Spotify” in the source picker in the bottom right first. Then afterwards when selecting a speaker, Spotify shows up as a “folder” for that speaker.
Thanks, what about your CPU load ? Have you seen an increase ?
I’m not able to control my Sonoff devices… the entities seem to have been deleted…
I am on the stock firmware.
Ideas?
