I donât actually use either of them but just had a look and yeah they briefly flash white. Thanks for the tip.
Iâll have a look at your config later.
The Samsung integration can detect my TV, but no device or entity is created after I complete the setup. Itâs just me?
In your config there are modes
, mode_command_topic
and mode_state_topic
Replace them with the new config values preset_modes
, preset_mode_command_topic
and preset_mode_state_topic
, and the warnings will disappear. See the documentation at MQTT HVAC - Home Assistant.
UPDATE: This is not the cause of the warnings. (my bad). modes
are still valid config parameters.
Iâm not sure why, but these started displaying on mobile today. There was no update from the third party icon app. Whatever it was, doesnât appear to be an issue for me in 2022.3.1
SABnzbd
stopped working with 3.1
Logger: homeassistant.setup
Source: components/sabnzbd/__init__.py:170
First occurred: 17:55:12 (1 occurrences)
Last logged: 17:55:12
Error during setup of component sabnzbd
File "/usr/src/homeassistant/homeassistant/setup.py", line 235, in _async_setup_component
result = await task
File "/usr/src/homeassistant/homeassistant/components/sabnzbd/__init__.py", line 218, in async_setup
await async_configure_sabnzbd(hass, conf, use_ssl, name, api_key)
File "/usr/src/homeassistant/homeassistant/components/sabnzbd/__init__.py", line 196, in async_configure_sabnzbd
if await async_check_sabnzbd(sab_api):
File "/usr/src/homeassistant/homeassistant/components/sabnzbd/__init__.py", line 170, in async_check_sabnzbd
await sab_api.check_available()
File "/usr/local/lib/python3.9/site-packages/pysabnzbd/__init__.py", line 93, in check_available
await self._call(params)
File "/usr/local/lib/python3.9/site-packages/pysabnzbd/__init__.py", line 41, in _call
async with timeout(self._timeout, loop=self._session.loop):
TypeError: timeout() got an unexpected keyword argument 'loop'
But where is it written that modes
should be replaced with preset_modes
? Documentation list them both and example values are different so looks like for different purpose:
modes list (optional)
A list of supported modes. Needs to be a subset of the default values.
Default:
[âautoâ, âoffâ, âcoolâ, âheatâ, âdryâ, âfan_onlyâ]
and
preset_modes list (optional, default: [])
List of preset modes this climate is supporting. Common examples include `eco`, `away`, `boost`, `comfort`, `home`, `sleep` and `activity`.
Those are two different things and they also are later on exposed in Lovelace in different ways:
Here an example for another type of climate integration:
Preset and mode are for different purposes and should both be available. My device needs only mode (operation in lovelace) and I donât need the preset. But other devices/integrations need both of them.
Below is my case:
It uses off
and fan_only
modes and a fan_mode
with values low
, medium
or high
. All in line with the integration documentation.
The new âPlay Mediaâ service was working great in my automations yesterday. Now today I can no longer see the new âPlay Mediaâ service available in automations. Is anyone else having this issue?
already an open issue for this
Upgrade was successful but I encountered a little quirk with MQTT Discovery.
In previous versions, you could publish an updated discovery payload, for an existing entity, and the entityâs state
value and attributes would update immediately (if the values were stored on the broker as retained messages).
While trying to enhance my MQTT HVAC climate entity, publishing an updated discovery payload caused the existing climate entity to lose its state and attribute values (became unknown
Thatâs odd because the (retained) values are on the MQTT broker so theyâre not unknown; Home Assistant is already subscribed to the entityâs topics so it should be able to receive the values immediately.
Restarting Home Assistant fixes it (i.e. the climate entity gets the values stored on the broker) but thatâs to be expected because the restart forces Home Assistant to re-subscribe to all topics on the broker.
Iâll probably do a few more tests before reporting this as an Issue.
And additionally here more explanation from KNX integration which clearly explains that HA is having two parameters: hvac_mode and preset_mode - both used for different things:
I believe it is nicely documented in the developerâs documentation:
I am not having the lovelace folder in my media folder. How can i get it there? So i can cast my lovelace? Thx
I noticed that the Rainbird integration doesnât work: it doesnât show any switch of the zones. I checked that someone said it in the realese 2021.12, but I didnât check in that moment. Anybody knows something about it? Thanks!
Maybe this has already been noted by others.
But this update, and previous ones, I am getting a lower user experience feeling.
After I press UPDATE, my Z-Wave devices are not working anymore.
I am using a external docker with a zwave2mqtt service.
Home assistant is not aware of this, just updates and after the update notices the zwave devices are not available.
What I ideally would like to see, is that when I press UPDATE, Home Assistant pops a message,
Warning: your current zwave server needs to be updated.
Do you still want to continue the update [Y/N]?
Dont get me wrong. For me, fixing it is not much fuzz, I am running Docker+Portainer+ouroboros. Just enable ouroboros and wait 2 minutes untill everything is updated.
But I would like to get a notice.
Does this suggestion help?
Modes are still in the documentation, Ill have look later.
Home Assistant will already update the Z-Wave JS integration when it is installed as an add-on during the integration set up. You manage your own zwave2mqtt service so ⌠you are the one that needs to manage it. We canât do it for you.
Love the media and renderer selection ( didnât know I had that many in my network)
Anyone suggestion to include SoundCloud as source?
I know i do. I can and will. But i find out by chance something is off.
It would be nice if HA is aware and pops a notice.
Like: current version detected: xxx.
Required version : yyy or higher
I am not pissed or blaming anyone.
It should tell you in the logs
You are correct. It does. I missed it
But see my sugestion as a general one.
Press update, breaking change? Popup.
Would be nice. No surprise.
