I was interested in trying Play Media automationā¦
ā¦but it doesnāt look like it works with my LG TV??
I had hoped to ācastā camera event footage straight to my TV.
Unfortunately: Media player does not support browsing media.
No option to select camera from media picker.
Friedi
March 10, 2022, 6:55pm
372
Great!
That worked for me Kudos to you!
Thanks. As I could update from 2022.03.2 to 2022.03.3 should I run the commands via ssh then?
michel72
(Michel - espthings.io)
March 10, 2022, 8:10pm
374
Iām having issues with the Tuya cover and the official integration since the latest version:
Home Assistant 2022.3.3
(the other 3 devices are smoke sensors)
It works locally (button) and via the Tuya App. No changes made on my side.
Anyone else having issues with Tuya covers?
After the update I canāt get rid of the Spotify dropdown menu.
I didnāt even invoke it, itās just always there even after a reboot. Anyone else? How do I get rid of it without removing the integration?
Which card? The mini-media player had an update to fix this exact error
basesnow
(Basesnow)
March 11, 2022, 2:59am
377
in addition to the drop downs, there are text fields too. Just spent about an hour in browser inspector and finally got mine tuned in:
mdc-text-field-fill-color: rgba( 75, 92, 105, 0.45)
mdc-text-field-ink-color: "#FFF"
mdc-text-field-label-ink-color: "#FFF"
DavidFW1960:
Which card
Iām using the latest version of the mini media player in HACS
ri27
(Ri27)
March 11, 2022, 3:06am
379
I have the same problem, using the latest version of Mini Media player
from HACS. Vacuum and purifier cards also broken.
Did you find anything on this? I have the same problem
tom_l
March 11, 2022, 4:04am
382
basesnow:
They should be covered by these (respectively):
input-fill-color:
input-ink-color:
input-label-ink-color:
I was under the impression that the input-*
theme variables should cover all the Lovelace mdc items like selects, numbers and datetimes, etcā¦ If the text items were missed then that should probably be opened as a frontend issue https://github.com/home-assistant/frontend/issues
Webrtc isnāt supported but rtsp nest cams work fine.
Thanks! This helped me with my VM-based install.
nickrout:
Latest is not a version.
v1.16.0
But it says āversion downloaded v1.16.1ā so Iām not really sure honestly.
Github says latest is 1.16.0
petro
(Petro)
March 11, 2022, 1:32pm
386
because it isntā a release yet, however thereās a tagged 1.16.1 version that you can use
basesnow
(Basesnow)
March 11, 2022, 1:34pm
387
Thanks! Iāll give those a try and see if I can clean up my theme a little.
tom_l
March 11, 2022, 1:44pm
388
The others you may want are listed here:
The correct fix of the input controls for existing custom themes seems to be:
input-idle-line-color: "var(--dark-primary-color)"
input-hover-line-color: "var(--error-color)"
input-disabled-line-color: "var(--disabled-text-color)"
input-outlined-idle-border-color: "var(--disabled-text-color)"
input-outlined-hover-border-color: "var(--disabled-text-color)"
input-outlined-disabled-border-color: "var(--disabled-text-color)"
input-fill-color: "var(--card-background-color)"
input-disaā¦
petro:
I couldnāt figure out how to use it. Does it fix the dropdown issue?
petro
(Petro)
March 11, 2022, 2:16pm
390
Click on the tags in the releases page and view the listed changes for the tag.
