2022.3: Select and play media
yep same here - found the new integration thanks to Michel! Missed that one on breaking changes somehow
Iā€™ve just created a PR on the browser_mod repo to add media source support to the media player:
Iā€™ve tested it with local media, Radio Browser, and text-to-speach and it is working for them all.
I completely agree, the change of location of the TTS now requires five actions from the user when previously it was two. This is a remarkable downgrade in usability from my perspective and I hope we can just get a configuration option to add it back in to the original location.
The new steps for me are now:
  1. Select the Media option on my Player
  2. Choose TTS
  3. Choose my TTS option
  4. Delete the prepopulated message
  5. Type and send.
Previously it was:
  1. Select Menu on Media Player
  2. Type and Send
Was there a back end reason why this needed to change? I really like the new media player, but this seems to be an oversight of usability in favor of consolidating all things media into the new system.
I do not use Nabucasa and my TTS works on my google cast devices. I have tested two configurations:
  1. Google Translate
  2. Google Cloud with Wavenet
Each of these work as expected, but the requirement to go through the media browser to use it is a downgrade in usability.
What you say is correct, but still the same to automate it, which the end game.
The automation aspect is fine for me, but as mentioned by other users, many of us use this as a quick little broadcasting interface. It worked really well in my house until this update. Now my spouse has stopped using it altogether because its not convenient. I am not sure if I can make a card with a text field and a send button, but that might be only alternative at this point.
I think a text box for the text and a drop-down to select the player.
I think that could be an option. I would prefer just a send button tied to a specific cast target because each room in my house has its own dashboard.
HACS Notify card
type: custom:notify-card
target: tablet
title: Send Notification
label: Lees dit voor uit de speaker:
Does it for meā€¦ Type text, click send. :wink:
afbeelding
Thank you, I was looking through the options already. This is excellent.
EDIT:
After messing around with this a bit, it looks like there is a little more configuration to get a TTS operation to happen. When you set the target to ā€˜tabletā€™ what is being done to make notify/tablet a valid service?
With my configuration I added:
target: media_player.loft_speakers
But this does not work.
I also attempted to make a TTS notify in my config YAML:
notify:
  - platform: tts
    tts_service: tts.google_cloud
    media_player: media_player.loft_speakers
Then configure the card as follows:
target: notify_loft
But this does not work either.
Even easier I think.
you need to make a tablet being able to receive the tts command.
Im doing that using LANnouncer - Home Assistant
I just noticed that Supervisor reports about running an unsuported installationā€¦
## You are running an unsupported installation
Below is a list of issues found with your installation, click on the links to learn how you can resolve the issues.
* [systemd_resolved](https://www.home-assistant.io/more-info/unsupported/systemd_resolved)
What should I do? I have not changed anything on the OS level. I would rather not do a complete OS reinstallā€¦
I had the same thing yesterday, after updating the supervisor to the newest version everything is ok again.
Is something up with 2022.3.4? It is on the HA website, and has been at least 8 hours (I saw it yesterday but saved the update overnight)
However updating is not available in the ui or commandline and using the new ā€œcheck for updatesā€ returns nothing.
The version integration json hasnā€™t been updated:
https://version.home-assistant.io/stable.json
(it only shows 2022.3.3 as available at the moment of posting)
Amusingly, the deprecated updater integration json shows the updated core:
https://www.home-assistant.io/version.json
(shows 2022.3.4 right now)
Uhm, sorry, but what to do. Running 2022.3.3 here and no information about newer versions.
Wait for them to fix the data at https://version.home-assistant.io/stable.json. If it doesnā€™t show up there in your browser, then it wonā€™t be seen by your Home Assistant install either.
Relax and enjoy the last of summer.
It doesnā€™t seem to be tagged/available on Docker hub, either.
