I have a separate set of dashboards for my cast devices, and you can set themes there.
Iām a little late to the party on the play media functionality but I finally got deeper into it and I have a clarifying question. I understand you can basically make home assistant play anything you want. But what if I donāt know what I want it to be or I donāt want it to be the same thing?
Is there a way for me to randomize or shuffle the media selections? I read through the docs twice and I looked every where I could think of in the software. Itās perfectly understandable if that wasnāt a phase 1 item, I just want to make sure Iām not missing some obvious way to do this before I submit a feature request.
Given a trigger, Iād like to be able to randomize selections:
At dinner time, pick one of ātheseā jazz playlists
When I come home, play one of ātheseā radio stations
On Fridays, play one of ātheseā albums
HA already has access to my SONOS playlists and favorites, I just canāt figure out how to shuffle playlists/stations for a selection.
Note: Iām not trying to shuffle every song between lists. Just trying to get it to where itās not playing the same playlist every time the automation fires.
You could tinker around with that:
I did try something similar to this and I was getting errors so I figured I was way off base. It looks like I just had a few incorrect details. Iāll give it another shot with this example, thank you.
I got it. I was using the wrong trigger:
service: media_player.select_source
source: {{ ['Soft Jazz Sax', 'Disco Essentials', 'Ladies First: Female MCs'] | random}}
device_id: 44c16384ae6ac4d727a6f458c9ffbd85
Hi, can someone help me:
I cast with
- service: media_player.play_media
entity_id: media_player.nesthub_google_kueche
media_content_id: _default_
media_content_type: lovelace
But what is the service to stop āplay_mediaā? I need something like āHey google, stopāā¦
Thx a lot
sorry my fault.
media_player.turn_off is the answer.
I tried media_stopā¦
thx
Same problem here, did you find any solution?
No. I never found a solution. My understanding is that you need a Chrome/Google-cast compatible streaming device. LG uses WebOS and a slightly off-spec (from Chrome) casting protocol.
Is Spotify supposed to be in the media. For some reason I can not get this to work. I am a premium Spotify user.
I didnāt find a solution yet. Iām still on 2022.6.
Just found this topic when trying to find out why I cannot play media in my LG TV, I guess the situation is still the same and no luck so far, right?
Right. No fix, nor have I seen any discussion about a proposed fix.
ā¦ of course I canāt be certain
Hey! Did you ever find out how to solve this issue?
