2022.4: Groups! Groups! Groups!
I don’t think this has automatically changed. I think we need to do this manually…it would help to have some guidance on ‘how’ :slight_smile:
The urls still have the lovelace string in the url. I don’t believe you need to change anything.
Add this to your configuration.yaml:
logger:
  default: warning
  logs:
    homeassistant.components.recorder.migration: debug # or 'info' if you prefer less logs
Of course I don’t “need” to change anything to keep my HA working, but if a change in this release is that “Lovelace” is now replaced by “Dashboard”, I’d like to embrace that change by no longer seeing “Lovelace” in the URLs.
I note my Config → Dashboards still directs to http://homeassistant.local:8123/config/lovelace/dashboards rather than e.g. /config/dashboard/dashboards after the upgrade. Is this planned to change?
He already put a note in the readme, I just figured people reading the release notes would want to know.
No need, there’s a big Heads-up warning users.
Hoping to figure it out, but it’s going to need some dev assistance.
And they’re very busy!
So yeah, need all the help I can get, if you know of a way to adjust the new web socket handling in custom-ui, do’nt hold back.
I have linked all the PR’s that cause this, and Paulus’s explanation in the Release party
It’s a bug which will be solved with next patch release (2022.4.1)
I think something is wrong with your install or you have a custom component or something. calculate_offset is no longer in the code base anywhere. Maybe try to update again?
I am using trigger.event.data in a number of templates in automations, all of which are now broken.
This is the error in the automation trace:
Error: Error rendering data template: UndefinedError: 'dict object' has no attribute 'event'
The documentation does not mention any change either.
Would this have any effect or allow for emulated_hue to emulate a v2 hub?
wondering if this is per design, or if we have an issue:
shouldn’t they be ‘off’?
I did notice this: Forced update failed Entity.xxxx. not found. · Issue #69492 · home-assistant/core · GitHub which also seems a bit surprising, maybe related?
please see if you recognize this?
other instance: yes they should be ‘off’
ok, now what :wink: Ill add to the issue.
Do you also have zha issues with conbee on 2022.4.0 and will it also be fixed in 2022.4.1
No issue here with ZHA and my conbee 2.
Do you run HAOS? I do and I have no issue at all
Im running debian/supervised and with the update 2022.4.0 im having a lot of issues with my zha zigbee network and conbee2. I moved back to 2022.3.8 there i zha works fine
why the actual value is not changed rather then just adding another db entry to make the global statistic tally correct
It does change the actual value though, so something did not work as expected.
Can you open an issue and tag it with the recorder integration please?
I see that the utility meter, groups, etc. has not been migrated to the UI automatically. This will be done in future updates or do we need to do it “manually”?
You may need to update ZHA dependencies or SQLite manually. Check this issue: ZHA & Home Assistant Version 2022.3.1 no longer works · Issue #67780 · home-assistant/core · GitHub
Guys my ıp cameras stop working with this update, what is going on?
type: picture-elements
title: Garden PTZ Cam 01
camera_image: camera.ptzcam1
elements:
  - type: state-icon
    tap_action:
      action: call-service
      service: ptz_camera.move_left
      service_data:
        host: 192.168.1.18
    entity: camera.ptzcam1
    icon: mdi:arrow-left-drop-circle
    style:
      bottom: 45%
      left: 5%
      color: white
      opacity: 0.5
      transform: ' scale (1.5, 1.5) '
  - type: state-icon
    tap_action:
      service: ptz_camera.move_right
      service_data:
        host: 192.168.1.18
    icon: mdi:arrow-right-drop-circle
    style:
      bottom: 45%
      right: 5%
      color: white
      opacity: 0.5
  - type: state-icon
    tap_action:
      service: ptz_camera.move_up
      service_data:
        host: 192.168.1.18
    icon: mdi:arrow-up-drop-circle
    style:
      top: 10%
      left: 46%
      color: white
      opacity: 0.5
  - type: state-icon
    tap_action:
      service: ptz_camera.move_down
      service_data:
        host: 192.168.1.18
    icon: mdi:arrow-down-drop-circle
    style:
      bottom: 10%
      left: 46%
      color: white
      opacity: 0.5
  - type: state-icon
    tap_action:
      action: more-info
    icon: mdi:arrow-expand-all
    style:
      top: 5%
      right: 5%
      color: white
      opacity: 0.5
camera_view: live
  - platform: generic
    stream_source: rtsp://admin:@192.168.1.18:554
    still_image_url: rtsp://admin:@192.168.1.18:554
    rtsp_transport: udp
    authentication: digest
    username: admin
    verify_ssl: False
Hi I see this when I do a test with “Check Home Assistant configuration”
[08:40:27] ERROR: The configuration check did not pass!
[08:40:27] ERROR: See the output below for more details.
Testing configuration at /tmp/config**
INFO:homeassistant.helpers.storage:Migrating core.entity_registry storage from 1.5 to 1.6
Failed config
General Errors:
Integration error: zwave - Integration “zwave” not found.
Successful config (partial)
Any suggestions?
try setup through UI, generic camera from intergrations.
