on top of that, I also see the new update entities are very often unavailable. Which is really nasty, because having moved from rest sensors to rely on this new integration doesnt prove to be very reliable currently.
startup itself varies I must admit. Sometimes it really is faster (2 minutes for a full restart where it was more than 4), but sometimes I see the same as Tom, and the exact same messages.
dev tools states is really much laggier than before, and pages with history graphs / apex custom cards dont release the frontend when eg clicking a more-info…
Just wondering if there is / will be an MQTT discovery variable for ‘Switch as X’ ? There is currently a “device_class”, variable in the switch platform, but the only available option right now is “outlet”, and all it does is change the icon in the interface. . It might be nice to expand on that and add these newer options I imagine that is what it was originally intended for.
That looks like an integration is creating tasks at shut down that are not completing. Turn on debug logging for homeassistant.core and it should report the tasks it’s waiting for.
EDIT: Ok False alarm. This was caused by my Cinema Kodi box half crashing. I could still connect to it via SSH and connect to it via the web interface so I thought it was ok, but when I actually went and looked I was unable to control it with any remote control.
After restarting the cinema Kodi box my restart times are back to 60 seconds!
This is with both the Kodi boxes awake. I’ve yet to see what happens when they are asleep but I’m closing the issue.
Since the upgrade to 2022.04 hass becomes unresponsive arround 6am. The log show timeouts on all addons. This morning hass restarted itself. Any ideas?
2022-04-10 05:41:58 ERROR (MainThread) [homeassistant.components.hassio.handler] Timeout on /addons/a0d7b954_grafana/stats request
2022-04-10 05:41:58 ERROR (MainThread) [homeassistant.components.hassio.handler] Timeout on /addons/core_mosquitto/stats request
2```
@IceBotYT - Thanks for your work on the PECO integration, living in Philly it was a nice surprise.
I am trying to come up with an automation use case for the outage sensors. Do you have any ideas?
Hi there, I do not have external url anymore only a message telling to use Nabucasa!
And Yes I have advanced activated, was working last time I got there (Long ago)
Does anyone else have the same behaviour?
Just switched from supervised version to Full HAOS on VM, linked ?
Home Assistant URL
Configure what website addresses Home Assistant should share with other devices when they need to fetch data from Home Assistant (eg. to play text-to-speech or other hosted media).
Simply copying and pasting from the yaml config to trace a script/automation needs yet another extra step.
Must admit the current tendency of Streamlining the UI experience is really taking away from non Ui experience. Trying to voice that as positively as I can.
The GUI of scripts is not working if you do not have script: scripts.yaml
For automations it works because the parser of configutation.yaml allows several automation like shown so you can load both manual yaml files from a directory and allow the GUI to edit automations.yaml
This does not work for scripts for some reason. You would think it would be easy to add since the code is already there for automations.
When you create a script in the GUI it is actually added to the scripts.yaml file. But the scripts never get displayed or loaded because scripts.yaml is not loaded from configuration.yaml
And please note that I want to both run manual yaml scripts and GUI like I do with automations. Complex scripts and automations are a nightmare in the GUI
No, it does not work. It is not documented to work either. The “automation manual” is documented. This is not the case for scripts. But my point is that it should be added to the parser because it currently forces you to choose either manual yaml or GUI. You cannot mix for scripts like you can for automations.
ahh ok, guess it was not intended to , or never though off
And i do agree about your point, the Automation"code" here i learned by making a simple, and checking the yaml(and for some i had to “switch"mode, to make it work), same way i learned html back in late 80, etc.
… thou the automation you make in the gui, regardless of “switching mode” ends up in automations.yaml, same as scripts, if im not wrong … i’ve never seen/use "
automation manual:” in configuration.yaml … sorry, thought it was either “!include” and/or “include_dir_merge_list” or “-named” like themes
Noticed “scripts” are not mentioned, but might work be the same way
Thou as it not mentioned anywhere that you can do as you do, i guess it’s not a Bug, but a FeatureRequest
