Can only second this. This additional click introduced in the last 3-4 releases are very horrible. So many places require now more than a lot of more clicks. Or is hidden, so that no one will find it in the future anymore.
Google Calendars integration seems to be brokenâŚ
Unable to prepare setup for platform google.calendar: Platform not found (cannot import name 'calculate_offset' from 'homeassistant.components.calendar' (/usr/src/homeassistant/homeassistant/components/calendar/__init__.py)).
Thereâs a very small hyperlink error in the âBreaking Changesâ section - the â(documentation)â link under the âGeneric Cameraâ integration points to the Huawei LTE docs.
@ptdalen - Judging by a card that shows me all my Zigbee devices including their RSSI and LQI values, it appears that the Zigbee network is rebuilding itself. Most devices are unresponsive but some did react to a command although with a significant delay. Iâll give it time to complete the process to see if my Zigbee network comes back to life.
After upgrade (otherwise troubless) I get strange error in my log file:
ERROR (MainThread) [homeassistant.setup] Unable to prepare setup for platform openhome.media_player: Platform not found (cannot import name 'UpnpFactory' from 'async_upnp_client' (/usr/local/lib/python3.9/site-packages/async_upnp_client/__init__.py)).
I do not have openhome nor upnp setup in my configuration⌠Any idea what it could be about? Perhaps some custom integration using it (I think iRobot i7+ is using generic camera, that throws another unexpected error).
I have a lot of groups(hue bulbs and zwave switches) set up in YAML and they still work, but they do not show up in the Helper section. Is it because I have them set up in lights.yaml? Should I move the contents of my lights.yaml to groups.yaml or can I just use !include lights.yaml in groups.yaml, then remove !include lights.yaml from my configuration.yaml?
Same problem here ZHA most zigbee devices work some donât problems started right after update. restart and tried some reparing but didnt fix. can i restore backup because i got some DB update warning after update
I appreciate them leaving yaml functionality intact, and I may just be ignorant, but youâd think there would/should be a way to import groups.yaml. I really want to use the UI, but this is almost starting from scratch on getting ~30 lights and switches organized. Why would the previous way of setting up groups not be considered when creating a group system in the UI? I feel like I must be missing something.
I agree. It now takes many clicks for a very common action. Was this overlooked during development? The PR only mentions a technical reason for the change without taking any trade offs into account.
As a side effect, it also somewhat forces the use of the default media player card (instead of mini media player) which in turn lacks the sonos grouping support.
