Something like that would work perfectly on my System screen and I would actually make each on conditional so that it only shows if an update is available. But what I want is a chip card (yes, using Mushroom) that only pops up on my main screen if something needs updating. Or maybe a template for the icon color for the button that takes me to my system screen and changes that icon to red, for example. I think I may just be making myself a template sensor that is on if any of the update sensors are on. (!= âUp-to-dateâ)
Youâre thinking of groups in the group domain. The groups in the UI are not in the group domain. They create an entity in whatever domain you choose. I.e. a group of binary_sensors becomes a binary_sensor.
He still maintains his stance on groups in the group domain.
If you really want to show this somewhere else in the UI I guess you can drop in a markdown card with this:
- type: markdown
content: >-
{{ 'Something needs updating!'
if states.update | selectattr('state', 'eq', 'on') | list | count > 0
else 'Everything up to date!'
Although for reference binary_sensor.updater never did this, it was only for core.
EDIT: I see you may have already gone the group route. Youâre going to have to keep that group up to date though with everything you add and every integration that updates to support update entities in the upcoming releases. If you really want an entity a template sensor is so much easier:
And it works perfectly for what I want! That area of my screen are all conditional cards that only provide info when needed. Lights that are on, doors and windows that are open, etc. I can now navigate to a page dedicated to system admin just by tapping on that icon.
I do like the move towards more simplicity for beginners.
But I do not quite understand why more and more configurations are now forced away from yaml files. Why not store the configuration from the UI in yaml files?
The current backup system is not really nice. If you setup a new system, restoring a backup is usually not the nicest way to go. Nor the safest.
But a copy&paste of yaml files was simple and fast and worked.
I am having to delete more and more yaml files because they are no longer supported. I am being forced to use a UI that is 10 times the work. Configuring brokers etc. seems like a small task, but the sum of tasks gets bigger and bigger the more is moved to the UI.
I hat eto imagine what would happen if I had to re-make all my automations via the UI everytime my RPI crashes and I did not have a backup.
UI is nice, but disallowing yaml files is starting to feel forced and disadvantages, even to beginners like me.
The requirement got downgraded to fix a memory leak. Not sure what you did in terms of upgrades or which installation method you use, but you could manually downgrade pyav.
But we might get forced into automations.yaml. And that would not be good. We are already being forced to use automations.yaml and scripts.yaml if we want to use the editor. The logical next step is to remove all independent yaml files and force the user to use huge single file systems.
Hi I have the message that there is a new release of Home Assistant 2022.4.2 to be updated but I cannot find the Update function as before in the âCONFIGURATIONâ function on the left panel of Home Assistant. How do I update the release?
Iâve never used openhome and got the same error starting 2022.4. After some investigations I found that most likely it is indeed related to false discovery of volumio as opehub player. I remediated it by edding following code to configuration.yaml:
mainly because if you skip an update, the update entity will turn âoffâ and you can not âtrustâ the template based on that entity for available updates.
combining these in a Markdown card can be very useful.
thanks for your ongoing effort to keep up that set of templates btw, really appreciated!
You can find the backup dashboard in the configuration menu, or, if you have upgraded already, click the my button below to create a new backup right away
In my Core installation of 2022.4.2 I am not seeing anything regarding backups in the Configuration. Following the âmyâ button results in â404: Not Foundâ. Is there anything needed to enable this?
Do you have a link to any recent discussions about this. Iâm not able to find any discussions on MariaDB not being recommended anymore.
If itâs worth it Iâll revert back to SQLite, although Iâm unfamiliar with how to transfer long term statistics, which will take some time to figure out. Do I want to make sure itâs worth doing this.
