2022.4: Groups! Groups! Groups!
Seems to me from reading this thread that (1) there was a solution posted; and (2) the person who waited patiently was rewarded by a working system.
I wonder whether some of my issues were caused by that… I don’t know the size of my DB but the backups are 1.1GB which I am guessing is mostly the DB.
This release completely breaks custom-ui. State updates no longer update customized icons or colors until you reload the page.
Post to the custom-ui github then.
If you are responding to me… I did look into testing unreleased ZHA but am still unsure how to do so. I downgraded in hopes it would fix things but some Zigbee devices are not working and a lot of them do not have LQI/RSSI data as they did before. However, many devices I have tried are working as before (w/ 2.3.8) but automations have failed to run, cards are not populating properly, so it seems that the restore did not fully restore the system… something is off.
I waited 2 to 3 hours but the house was crippled with 90 dead zigbee devices. It would be nice for there to be a way to see what is happening in the background (ie DB update).
Certainly agree with that!
I don’t think this has automatically changed. I think we need to do this manually…it would help to have some guidance on ‘how’ :slight_smile:
The urls still have the lovelace string in the url. I don’t believe you need to change anything.
Add this to your configuration.yaml:
logger:
  default: warning
  logs:
    homeassistant.components.recorder.migration: debug # or 'info' if you prefer less logs
Of course I don’t “need” to change anything to keep my HA working, but if a change in this release is that “Lovelace” is now replaced by “Dashboard”, I’d like to embrace that change by no longer seeing “Lovelace” in the URLs.
I note my Config → Dashboards still directs to http://homeassistant.local:8123/config/lovelace/dashboards rather than e.g. /config/dashboard/dashboards after the upgrade. Is this planned to change?
He already put a note in the readme, I just figured people reading the release notes would want to know.
No need, there’s a big Heads-up warning users.
Hoping to figure it out, but it’s going to need some dev assistance.
And they’re very busy!
So yeah, need all the help I can get, if you know of a way to adjust the new web socket handling in custom-ui, do’nt hold back.
I have linked all the PR’s that cause this, and Paulus’s explanation in the Release party
It’s a bug which will be solved with next patch release (2022.4.1)
I think something is wrong with your install or you have a custom component or something. calculate_offset is no longer in the code base anywhere. Maybe try to update again?
I am using trigger.event.data in a number of templates in automations, all of which are now broken.
This is the error in the automation trace:
Error: Error rendering data template: UndefinedError: 'dict object' has no attribute 'event'
The documentation does not mention any change either.
Would this have any effect or allow for emulated_hue to emulate a v2 hub?
wondering if this is per design, or if we have an issue:
shouldn’t they be ‘off’?
I did notice this: Forced update failed Entity.xxxx. not found. ¡ Issue #69492 ¡ home-assistant/core ¡ GitHub which also seems a bit surprising, maybe related?
please see if you recognize this?
other instance: yes they should be ‘off’
ok, now what :wink: Ill add to the issue.
Do you also have zha issues with conbee on 2022.4.0 and will it also be fixed in 2022.4.1
No issue here with ZHA and my conbee 2.
Do you run HAOS? I do and I have no issue at all
Im running debian/supervised and with the update 2022.4.0 im having a lot of issues with my zha zigbee network and conbee2. I moved back to 2022.3.8 there i zha works fine
