again, i don’t understand why remove yaml configuration… imagine filesize, many many files and me want to change files name in the ui… please, mantain both possibilities in these situations…
Will the MQTT change affect MQTT Room Presence - Home Assistant ? I use it with Espresense for room presence. It is the only mqtt sensor that I have and I get the warning Manually configured MQTT sensor(s) found under platform key 'sensor', please move to the mqtt integration key, see https://www.home-assistant.io/integrations/sensor.mqtt/#new_format
The mqtt_room page doesn’t mention that there is a change and what the new format is supposed to be.
I am using Espresense as well, but these sensors are not affected by the change. I have since converted all the mqtt platform and I do not see the error any longer. You must of miss looked on your file.
I don’t fully understand what you posted. I only use mqtt_room and nothing else for mqtt in my configuration file so I don’t understand why I get the warning if mqtt_room is not affected. If it is not affected why would I have to “convert all the mqtt platform” and what does that really mean? There’s some details that I need explained to understand.
Right. But I want to have everything setup for the new format so that when there is a breaking change it’s already set. I still don’t understand why I get the warning if mqtt_room doesn’t show a new format and mqtt_room is the only mqtt sensor I have in my configuration.
I was implying are you sure there is no other platform: mqtt anywhere else you have missed or forgotten to update. Otherwise, try a restart of HA and see if the warning still shows up.
As for me, I thought I got them all, but for got to update the file in my packages folder.
