yeah, well that can’t be can it, because that specific device gets banned, so we need to delete the ip-bans.yaml, and restart before being able to re-log in.nThat’s why it’s such an annoying bug.
Before, I used the trick to toggle my VPN and thus change ip-address, but somehow that doesnt work anymore. Seems the App is clever enough to realize it’s still the same device
\\homeassistant\config.storage\core.entity_registry was corrupted twice as a result of an upgrade from 2022.6.7 to 2022.7.x (I think I tried .2 and .3, but can’t remember for sure). Replacing a version from a backup from 2022.6.7 fixed one issue, but I could not figure out from the logs what else might have gone wrong as this only fixed the issue temporarily. I’ve been holding off updates since then reason.
I’m planning to upgrade again to 2022.7.3 today or tonight my partner is not at home, so it’s a good moment for a maintenance window . I will post here how the update went.
If i switch to 4G or vice versa I am in with a different token on a different ip address and i have a script that deletes the ip_bans file and restarts HA so it’s pretty painless…
I d hardly call that painless at all really, more of hacking yourself out of an issue that shouldn’t be there in the first place.
Which is ok-ish if you handle homeassistant all day like we do. The family though doesnt feel it that way.
They simply notice they’re being logged out all the time.
Might not be tied to this release altogether, but it certainly started with it now.
This was a great update, kudos for all the developers and people that helped to get this update come to life.
One of the new features of this update is the History filter and although no one can argue about it’s usefulness, some people like me say that it really would be nice and useful to have the option to see everything history has to offer like before the update.
If you are one of the people that misses the capability of seeing all the available history info please vote here View All Option And even if you are not one of this people and can’t live without the filter, please also vote because you will still have the filter capability and the option of seeing all if you want.
Well, ALL history … i’m not sure why would be usefull to see hundreds, if not thousands of entities at the same time.
But, what WOULD be useful is use of wildecards. So, if i would enter in entity field, say, “sensor.garage%” i’d get all sensor starting with that. And with wildcards we’d also get those “all” possibility (just by entering %).
Ok, now we have option to select device. But that’s not always as usefull as my suggestion, since same pattern can be on quite many different devices, so adding them all would again result in “mini chaos”.
I found it very useful (before 2022.7) to see all entities on the history page at one glance and I definitely also want to have that feature back! Of course I have configured the history with the recorder.yaml and history.yaml files, so “all” entities does not really mean all existing entities…
On my setup it usually took ~1 minute to show all graphs on History page.
Of course some entities are excluded from Recorder & History.
So, it was not a “look at one glance” ((( (depends on hardware)
But - I do agree that we should have a possibility to show all entities at once (not switched ON by default).
Here is the remove_bans.sh that I have as a command line script. It runs in the ssh addon for HA. It calls ssh-console-ha.sh on the host (probably all you need) Note the ssh & web terminal addon won’t accept the ed25519 private key - only seems to work with the ssh-rsa key (despite the fact that ssh & Web terminal won’t accept ssh-rsa keys anymore for auth)
Not interested in converting my db login security. When do they expect to put back the caching_sha2_password package back? I reverted back to 6.7 until it’s confirmed it’s resolved. Why would you pull the db client authentication mechanism package?
Interesting… after installing 2022.7.4 update today all 3 sensors from “speedtest.net” addon became unavailable. Removing and reinstalling addon helped.
strange…
