This is from the “Setting - System Health - Integration start times”. Running 2022.6.7 the integration raspberry_pi takes much the same as the other integrations. Running 2022.7.1 it takes significantly longer.
And, on my system at least, it is an issue preventing me from running 2022.7.1
Logger: homeassistant.util.package
Source: util/package.py:99
First occurred: 4:33:46 AM (3 occurrences)
Last logged: 4:34:02 AM
Unable to install package numpy==1.21.1: ERROR: Cannot install numpy==1.21.1 because these package versions have conflicting dependencies. ERROR: ResolutionImpossible: for help visit https://pip.pypa.io/en/latest/topics/dependency-resolution/#dealing-with-dependency-conflicts
I have that exact same problem, it is called “raspberry_pi” in the logs, and if you digg deeper in the logs (debug turned on), it is “hassio” and “hardware”.
I already posted about this here in this thread:
It came to grip and let me start after the update of Supervisor, but it still is the most time consuming component, right now taking around 230 secs to start.
@Docrob
Will you do the honor of an issue @github or should I? I woouldn’t be mad if you’d do, but please leave a link here so one (me) can chime in on it.
Has anyone seen any issues with Emulated Hue broken and not working at all after upgrading to 2022.7.2? I had to roll back to 2022.6.7 to get functionality back again as the error in the logs appears as first entry upon startup.
If your problem is with a 3rd party integration being incompatible with python 3.10 then no update of core will change that. You need to figure out which 3rd party integrations you’re using that are broken, create an issue in those repos and wait for an update there. Or disable those integrations for now until the author updates them.
The integration is working with Supervisor 2022.07.0, so I don’t think Python is the problem.
I was having other problems that a reboot of the router fixed, so I will try an update to 2022.07.2 later today. Almost everything else seems to be working fine in 2022.07.0
RESOLVED
Would this be an indicator that the integration is not Py3.1 compatible?
Error setting up entry honeywell for honeywell
10:28:21 AM – (ERROR) components/honeywell/init.py
After restarting HA a few times chasing other issues, the Honeywell integration is working now.
O my god, do not update to any 2022.7 version till all problems fixed!
Most important GPIO feature stopped working even through HACS.
Cant check validations and restart, after hard restart issues still persist, something is wrong with HACS.
WAIT TILL 2022.7.6 at least.
