Unfortunately issue still persists in 2022.7.1
No, but I use
<HOME_ASSISTANT_URL>/auth/external/callback
since I do not use the default config.
That worked perfectly before. I did have everything setup before 2022.7, just tried a reinstall since I couldnāt see the new services in the developer tools.
Core 2022.7.1: Anyone else experiencing this in settings?
System log seems to indicate a problem in the front end:
2022-07-09 09:23:47 ERROR (MainThread) [frontend.js.latest.202207070] http://10.0.0.31:8123/frontend_latest/3d5b24c7.js:1:24886 Uncaught SyntaxError: missing ) after argument list
This is my test installation so not much is installed.
Wrong URL. Should be .../config/dashboard
Though it should also redirect.
Try clearing your web browser cache.
That fixed it, thank you.
Iāve read the āclear cacheā so many times Iām surprised it hasnāt sunk in yet!
Does the log for the addon say it doesnāt accept ssh-rsa keys anymore? It will accept a ssh-ed25519 key which you can make in Puttygen
On upgrading to 2022.7.0 and 2022.7.1 on a RPI4 using HA OS 8.2 the boot time is prolonged significantly compared to 2022.6.7. The issue seems to be with loading raspberry_pi integration which takes 1302s in the log. Thereafter the ārestartā functions in developer tools & settings no longer works. The RPi4 is in a Geekworm NASPi case with a X-C1 board and HA OS is on a SSD. This was not an issue with 2022.6.7 - the integration startup time for raspberry_pi in 2022.6.7 is 198.93s
Anybody any idea why?
Try this insteadā¦ requires appdaemon but works great
Exactly what integration is this? I only see rpi_power
and rpi_camera
the upgrade py 3.10 on the regular monthly cadence is showing a weakness of the do-or-die release schedule. For the first time in over a year, Iāve had to rollback and pin my version. the py upgrade is prudent and necessary to advance the platform, but weāve degraded the extensive integrations platform quality. guess this is one way to cull unsupported integrations and keep the blood movingā¦
Is anyone else having issues with the REST sensor, my sensors are no longer loading since this upgrade
Z2M is acting kinda wonky. somethings have a delayed response. Last night outside Zigbee lights didnāt turn on - did tonight. Does anybody have Z2M similarities?
sort of, do not forget to remove the old credentials from here. Was not aware of it
Hello
some integration stop working in my home assistant
- bmw connect drive
- tapo controller
in both show state unknown, and in the integration panel shows not loaded.
I have no idea - but itās in the logsā¦
No logs = no issue.
Also tapo seems to be a custom component. While in my view it is certainly OK to ask here if anyone else is affected, support should be sought from the author on their github.
Yeah is is not searchable in the docs: Integrations - Home Assistant it certainly exists: core/homeassistant/components/raspberry_pi at dev Ā· home-assistant/core Ā· GitHub. I have no idea why it does not show up in the docs. I have no idea why it is not working for you.
Very sad mi flora is not working anymore, had it just running for one day , bought special a usb Bluetooth adapter for it.
In fact this (raspberry_pi
) was only added a month ago, I am not sure myself what it does, but you should probably post an issue if it is taking 1300 secs to start.
No it is not. At least it is not a general issue.
