Look, I caught an error:
2022-08-05 11:50:27.658 ERROR (MainThread) [root] Uncaught exception
File "/Users/server/Steuerung/homeassistant/bin/hass", line 8, in <module>
sys.exit(main())
File "/Users/server/Steuerung/homeassistant/lib/python3.9/site-packages/homeassistant/__main__.py", line 191, in main
exit_code = runner.run(runtime_conf)
File "/Users/server/Steuerung/homeassistant/lib/python3.9/site-packages/homeassistant/runner.py", line 119, in run
return loop.run_until_complete(setup_and_run_hass(runtime_config))
File "/opt/homebrew/Cellar/[email protected]/3.9.13_1/Frameworks/Python.framework/Versions/3.9/lib/python3.9/asyncio/base_events.py", line 647, in run_until_complete
return future.result()
File "/Users/server/Steuerung/homeassistant/lib/python3.9/site-packages/homeassistant/runner.py", line 101, in setup_and_run_hass
hass = await bootstrap.async_setup_hass(runtime_config)
File "/Users/server/Steuerung/homeassistant/lib/python3.9/site-packages/homeassistant/bootstrap.py", line 143, in async_setup_hass
await async_from_config_dict(config_dict, hass) is not None
File "/Users/server/Steuerung/homeassistant/lib/python3.9/site-packages/homeassistant/bootstrap.py", line 256, in async_from_config_dict
await _async_set_up_integrations(hass, config)
File "/Users/server/Steuerung/homeassistant/lib/python3.9/site-packages/homeassistant/bootstrap.py", line 532, in _async_set_up_integrations
recorder.async_initialize_recorder(hass)
File "/Users/server/Steuerung/homeassistant/lib/python3.9/site-packages/homeassistant/helpers/recorder.py", line 22, in async_initialize_recorder
from homeassistant.components.recorder import const, models
File "/Users/server/Steuerung/homeassistant/lib/python3.9/site-packages/homeassistant/components/recorder/__init__.py", line 23, in <module>
from . import statistics, websocket_api
File "/Users/server/Steuerung/homeassistant/lib/python3.9/site-packages/homeassistant/components/recorder/statistics.py", line 17, in <module>
from sqlalchemy import bindparam, func, lambda_stmt, select
ModuleNotFoundError: No module named 'sqlalchemy'
After I install sqlalchemy it still crashes.
I canât really see the cause, because the log is overwritten as soon as HA restarts.
