### The problem
system halted/restarted upon below error
This is an error …on recorder choking on certain Unicode characters, which are created by various integrations so it seems.
very serious, as it completely breaks the system, which gets in an endless loop of overheating/memory and processor overload and consequent restarts.
### What version of Home Assistant Core has the issue?
2022.8.2
### What was the last working version of Home Assistant Core?
_No response_
### What type of installation are you running?
Home Assistant OS
### Integration causing the issue
Recorder
### Link to integration documentation on our website
https://www.home-assistant.io/integrations/recorder/
### Diagnostics information
_No response_
### Example YAML snippet
endless repeated logging of:
```txt
, count=1, first_occurred=1659944277.1001759>): 'charmap' codec can't encode character '\u0151' in position 133173812: character maps to <undefined>
File "/usr/src/homeassistant/homeassistant/components/recorder/core.py", line 632, in _run_event_loop
self._process_one_task_or_recover(task)
File "/usr/src/homeassistant/homeassistant/components/recorder/core.py", line 645, in _process_one_task_or_recover
return task.run(self)
File "/usr/src/homeassistant/homeassistant/components/recorder/tasks.py", line 211, in run
instance._process_one_event(self.event)
File "/usr/src/homeassistant/homeassistant/components/recorder/core.py", line 743, in _process_one_event
self._process_non_state_changed_event_into_session(event)
File "/usr/src/homeassistant/homeassistant/components/recorder/core.py", line 808, in _process_non_state_changed_event_into_session
if data_id := self._find_shared_data_in_db(data_hash, shared_data):
File "/usr/src/homeassistant/homeassistant/components/recorder/core.py", line 778, in _find_shared_data_in_db
if data_id := self.event_session.execute(
File "/usr/local/lib/python3.10/site-packages/sqlalchemy/orm/session.py", line 1712, in execute
result = conn._execute_20(statement, params or {}, execution_options)
File "/usr/local/lib/python3.10/site-packages/sqlalchemy/engine/base.py", line 1631, in _execute_20
return meth(self, args_10style, kwargs_10style, execution_options)
File "/usr/local/lib/python3.10/site-packages/sqlalchemy/sql/lambdas.py", line 516, in _execute_on_connection
return connection._execute_clauseelement(
File "/usr/local/lib/python3.10/site-packages/sqlalchemy/engine/base.py", line 1498, in _execute_clauseelement
ret = self._execute_context(
File "/usr/local/lib/python3.10/site-packages/sqlalchemy/engine/base.py", line 1862, in _execute_context
self._handle_dbapi_exception(
File "/usr/local/lib/python3.10/site-packages/sqlalchemy/engine/base.py", line 2047, in _handle_dbapi_exception
util.raise_(exc_info[1], with_traceback=exc_info[2])
File "/usr/local/lib/python3.10/site-packages/sqlalchemy/util/compat.py", line 208, in raise_
raise exception
File "/usr/local/lib/python3.10/site-packages/sqlalchemy/engine/base.py", line 1819, in _execute_context
self.dialect.do_execute(
File "/usr/local/lib/python3.10/site-packages/sqlalchemy/engine/default.py", line 732, in do_execute
cursor.execute(statement, parameters)
File "/usr/local/lib/python3.10/site-packages/MySQLdb/cursors.py", line 199, in execute
args = tuple(map(db.literal, args))
File "/usr/local/lib/python3.10/site-packages/MySQLdb/connections.py", line 275, in literal
s = self.string_literal(o.encode(self.encoding))
File "/usr/local/lib/python3.10/encodings/cp1252.py", line 12, in encode
return codecs.charmap_encode(input,errors,encoding_table)
UnicodeEncodeError: 'charmap' codec can't encode character '\u0151' in position 133173812: character maps to <undefined>
home-assistant.log.1 shows never seen lines like:
"/usr/src/homeassistant/homeassistant/components/recorder/core.py", line 778, in _find_shared_data_in_db\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\n if data_id := self.event_session.execute(\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\n File "/usr/local/lib/python3.10/site-packages/sqlalchemy/orm/session.py", line 1712, in execute\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\n result = conn._execute_20(statement, params or {}, execution_options)\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\n File "/usr/local/lib/python3.10/site-packages/sqlalchemy/engine/base.py", line 1631, in _execute_20\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\n return meth(self, args_10style, kwargs_10style, execution_options)\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\n File "/usr/local/lib/python3.10/site-packages/sqlalchemy/sql/lambdas.py", line 516, in _execute_on_connection\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\n return connection._execute_clauseelement(\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\n File "/usr/local/lib/python3.10/site-packages/sqlalchemy/engine/base.py", line 1498, in _execute_clauseelement\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\n ret = self._execute_context(\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\n File "/usr/local/lib/python3.10/site-packages/sqlalchemy/engine/base.py", line 1862, in _execute_context\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\n
### Additional information
pardon the edit, but Ive taken out the irrelevent first impressions, as they turned out to be coincidental.
