I look forward to it!
Every night, all my Bluetooth device would stop working at the same time. I just discovered that my backup is causing this.
My scheduled backup breaks Bluetooth. I have to reboot my server
Every time I restart HAOS, Iām getting a repair suggestion.
Itās because one of my entities is created by an esphome device and itās state is āunavailableā during start-up, resulting in this error
The automation "Synchronize states" (automation.synchronize_states) has an action that calls an unknown service: homeassistant.turn_unavailable.
Iāve adjusted the automation (which came from a Blueprint), so that it doesnāt trigger from āunavailableā and so it doesnāt actually trigger during start-up
Iāve cleared the cache from my Chrome browser, just in case it was showing some legacy error message but it reappears after every restart. Iām surprised that a service call is being checked if the automation hasnāt even triggered.
Iām just wondering if anyone knows if this is expected behaviour?
Post the automation in a new thread, it shouldnāt be getting to the service call to produce that error.
Hi
So I see the new 2022.9.0 release notes.
But where are the links to the forum for this release? where are the community comments?
Am i being stupid?
The link was always at the bottom of the release notes
They are always in the Blog category on this forum.
Thatās where I thought the link was but this is all I get after several refreshes.
And when I hover over where the link should be I get
community.home-assistant.io refused to connect.
I had to google it.
It doesnāt run for me. Iām using windows 11.
Any news regarding the broken Bluetooth Tracker for iPhone? It hasnāt been fixed for three months nowā¦ First time in years that I canāt update.
Nope, needing it as well. Isnāt there, also not there in 2022.9.4
Fortunately, there are others that feel the same about deprecated MDI icons.
If you install custom-icons, they maintain some of the deprecated icons, including the google-home one.
After you install the add-on, replace mdi:google-home with cil:google-home and get on with your day
Their current icon listing is here and Iām sure you could request Discord be added if there isnāt a good one in simple-icons or fontawesome yet.
Deprecated. Depreciated is an accountancy term.
Youāre a good bot.
Sorry not to answer you but raise a question:
How did you pair it through home assistant?
I have a couple of them, reset them to make pairable but Home Assistant doesnāt seem to detect them.
Best regards
I reset them (5 times power off/on) and suddendly I get a message in Home Assistant (>=2022.8) that there is a new device. Then I get a pairing dialog, the LED strip is flashing a fe times and I can input the pairing code from the device. Thatās all.
Hi @bdraco
Is that why I canāt seem to receive any event in HA from one of those Bluetooth remotes, despite getting it connected via bluetoothctl?
Described here: Bluetooth Button (Remote) support - #19 by antonio1475
It seems some people have achieved using the bluetooth multimedia buttons that @yousaf465 mentioned without an integration (well, maybe the Keyboard Remote one?):
Thank you
Someone has to build an integration for those devices before they can be supported
Wondering why
a) this is still not available to be configured in the UI
b) it still uses the old known_devices.yaml
file which I thought was legacy/deprecatedā¦ (Device tracker - Home Assistant)
Iāll give it a try (anyway).
After updating to HA 2022.8.7 ALL entities state of the mobile app (HA Companion app) were unknown
until I opened the app on every device, for some I needed to disable and re-enable the sensors one by one. Everything was fine. After the next HA restart:
- all ālast_rebootā sensors (Android devices) are
unavailable
andorphaned
- which is a pattern.
Update: looks exactly like
Companion's Next Alarm sensor doesnt restore its state after Core restart Ā· Issue #77106 Ā· home-assistant/core Ā· GitHub - one device (iOS) does not provide the āaverage active paceā sensor anymore, itās not in the sensor settings of the mobile app section
All that started with update to 2022.8. How to fix that? Nothing in logs.
Update:
Updating to HA Core 2022.9.7 fixed the āmissing last_rebootā issue.
