About a week before 2023.11.0
And do you then start noticing the addon logs were missing? Or before it also?
Maybe we can compare custom components? Although I donāt believe itās caused by a custom
OK so how do I send a shopping list to a phone?
Created an issue thread:
I admit I am biased because I made the card, but PowerTodoist (available in HACS) is a lot better than this for Todoist integration
But it is geekier, itās for people who are comfortable YAMLing around.
Have a look at all it can doā¦
Any news about a fix on the automations IDās issue?
I have downgraded to 2023.10, and Iām still waiting for a fix in a new release.
If I upgrade to 2023.11.0, I lost a lot of automations working.
Not upgraded to .11 yet.
Could you post a link on github to this issue?
Yes itās this one:
So, for some devices their IDs were changed. Is it about those human-unreadable UUIDs? If yes - never use them myself, always believed that they are kind of ālow-levelā and may be changed any time.
Iām guessing that you meant to say āadd the āLocal To-doā integration, via the [Add Integration] button on the Settings > Devices & Services pageā ?
yes, that seemed to do the trick.
Same here. My partner will probably only ever want Shopping List, and doesnāt want to go hunting for it.
Nifty trick I learnt elsewhere ⦠start with an underline (or other character which comes before āaā in ASCII)
Yes me too
Automation visual editor always seems to use/put those hex-numeric device IDs, so how do you avoid this? Use only yaml editor? I also got the error with few automations, luckily easy to fix. They still worked fine before 2023.11 version. Not sure how, if the IDs already were wrong before this.
Donāt use device triggers. Use State triggers.
Failed automations used time trigger, but had āif conditionsā and those had the ID problem devices.
Still basically the same answer.
Donāt use device conditions, use state conditions.
OK, Iāll try to remember that when adding new automations.
Worth mentioning: ShellyForHASS closes. It was the first Shelly integration in Home Assistant. Many thanks to HĆ„kan Ć kerberg as author and main developer. His recommendation is to use Home Assistantās own Shelly integration.
