Here’s a helpful Community Guide explaining the pros and cons of Device Triggers/Conditions/Actions versus other kinds of Triggers/Conditions/Actions.
I’m running Home Assistant;
- Core 2023.11.1
- Supervisor 2023.10.1
- Operating System 11.1
- Frontend 20231030.1
Since upgrading to Core 2023.11.0, the “Refresh” button on the “Developers Tools/State” tab hasn’t functioned correctly. If I select an “entity” from the list of those shown, then click on the “Refresh” button, the area showing the entities attributes (Set State) clears rather than updating entity details.
I’ve only noticed this behaviour since upgrading to Core 2023.11.0. Prior to the upgrade, pressing the refresh button would update the entities attributes. I’ve restarted HA and rebooted the server in hopes of correcting the issue but it remains. Is anyone else experiencing this behaviour?
Regards
Good day,
I have a slight problem, after I upgrade the core to 11.1 there are errors to do with no platform sensor.average, also homeassintant.util.temperature, how can I overcome this because it prevents restarting, when I restore the previous version I do not have issues. It does not point to a line in the config or to any automation.
Regards
Caswell
I didn’t see this upgrading from 2023.11.0 to .11.1 thankfully.
I have added a photo of the error, how can I resolve this, I am afraid to reboot.
Regards,
Caswell
You are using a custom integration that needs to be updated
There’s already a PR to fix that. It may be available in the next fix release
Since updating to 2023.11 I no longer seem to be able to theme the colours of sliders. e.g. in my theme:
paper-slider-knob-color: '#e45e65' # red
paper-slider-active-color: var(--paper-slider-knob-color)
However the inspector shows:
This is the same in firefox and chrome.
Is anyone else seeing this?
Then I would have to do that on all devices for all users. Not what I asked for. I want to clean up the system and make it easier to use for all users so there isn’t a lot of unused stuff in the menus.
I think Energy Dashboard date selector change made it worse to use. Before there were direct shortcuts for week, month, year etc. But now I have to do extra click to open the calendar to see those. Bring them back to the main page or allow to customize the view via yaml edit.
been stoked on replacing my custom:state-switch cards with the new condition options, and indeed found a few. which is great, in trying to be as core as possible.
However I now realize again what power tool that state-switch card is, as it offers the ‘all’ option if the condition isnt met.
- type: custom:state-switch
entity: mediaquery
states:
'(min-width: 800px)':
!include /config/dashboard/includes/include_sankey_energie.yaml
all:
type: custom:swipe-card
Or, just more than 1 condition in the same card config, which behave as an if/else:
entity: binary_sensor.saver_offline
states:
'on':
type: custom:button-card
'off':
also, the group function in admin/users is so cool, I had forgotten all about that…
entity: group
states:
admin:
type:
user:
type:
instead of the now possible:
- type: conditional
conditions:
- condition: user
users:
- !secret admin_m
- !secret admin_w
card:
So, nice improvement already, several useful conditions. Please keep developing on these options though, and do have a look at state-switch
Won’t mention the template option, as that would probably never make it into core…
@makai is right, and it is the “Home assistant plant” should be updated to 2023.10.0. Had the same issue during beta.
on the new Improv BLE:
I have a few of the m5 stacks, in both voice or bt proxy version. for some time now.
Should I be seeing the new Improv integration in the Integration list now? Because I dint, and when trying to add it, it states
How can I tell my M5 stacks are Improv ready/functioning?
No, the device_id’s werent’ changed. The automations had errors and HA didn’t know it. Now HA knows the errors and wants you to fix them. It creates a repair and disables the automation. I.e. working as intended. There’s no “fix” other than users needing to fix their automations. That’s what I gathered from reading the issue.
All is sorted now, it was not due to the upgrade.
Hello everyone!
Is there a possibility to delete single faulty data points in the statistics? Since this update my statistics sensors go totally nuts whenever I restart Home Assistant. They show random values of up to +/-300000 directly after the restart which mess up the whole statistics and make it unusable. Thanks for your help!
Yes, go to dev tools, statistics
It says “no problem” there for the faulty sensors. But I can’t do anything with the sensors concerning the data values - or do I miss something?
It seems to be the same or a similar issue as this one here: Spikes in statistics average graph around restart · Issue #89000 · home-assistant/core · GitHub
You can go and edit the statistics there (click the ramp icon to the right hand side)
@averater - Then I would have to do that on all devices for all users.
Couldn’t you give each user their own dashboard?
