The RPi3a+ only has 512Mb of RAM, with the later RPi3b+ only 1Gb.
HAOS has a realistic minimum requirement of 1Gb of RAM, and really needs 2Gb to install add-ons even with zram compression.
Despite what the install docs say , as HASS adds features, more RPi3B+ owners are reporting failures and having to upgrade. Simple installs work - just don’t expect too much.
CaptTom
(Tom)
November 23, 2023, 1:53pm
329
RPi 3B+ owner here. Four+ years on and still no problems to report. At this moment it’s sitting at 3-5% CPU utilization and between 58 and 59% memory (out of 1G.)
In all fairness, I’m quite sure I could kill it if I started loading up on resource-intensive features.
I also support a remote site with HAOS on a RPi3B+, but that’s very deliberately a simple install with MQTT only and it ticks by with 1Gb of RAM.
Perhaps it’s selection bias, but I’m seeing more and more posts on the forum with RPi3B+ issues and as HAOS gains features, the trend will likely increase so I’m just trying to manage expectations.
Note that the latest $99 Green has 4Gb RAM which is double that even of the 2Gb Yellow . My guess is my SSD Yellow will benefit from a CM5 when it arrives around 2026+ if for nothing else to speed up ESPhome debug cycles.
mathias
(Mathias Regotz)
November 24, 2023, 12:05pm
332
The update to 2023.11 killed the fibaro integration. The integration becomes a very big delay in reacting. I think, the newly added event handling is the cause.
Is this fixed in the update 2023.3?
nickrout
(Nick Rout)
November 24, 2023, 8:15pm
333
What are you asking? 2023.3 is months old.
I think he means 2023.11.3
Dutcherik
(Erik Duim)
November 25, 2023, 4:24pm
335
The solution for
‘Fibaro integration, new event type gives multiple warnings when using with HC3’
and the related 30 seconds issue are not yet released are they?
But these issues were closed about 3 weeks ago??
user1000
(brandon)
November 26, 2023, 10:10pm
336
beautiful tiles, where did you get those or are they all home grown?
Edwin_D
(Edwin D.)
November 27, 2023, 7:09am
337
This is the standard energy dashboard from HA, it is there already. All you need to do is configure the entities in the dashboard settings. You can also use the cards separately (when you configured the dashbord)
Is it possible to mention clearly in the releasenotes if there will be an upgrade of the database? So that we know we need to backup the whole system before upgrading instead of just the home assistant container?
My database is a couple of gigs, so it takes a little more time to backup
tom_l
December 5, 2023, 7:52am
340
Yes, for example. But 2023.11 also had a database upgrade. Which isn’t mentioned in the releasenotes. That’s why I’m asking.
tom_l
December 5, 2023, 12:54pm
342
It wasn’t mentioned because it did not have one.
Why did my logs say “Database is about to upgrade from schema version: 41 to: 42” after upgrading from 2023.10 to 2023.11 then?
tom_l
December 5, 2023, 10:26pm
344
Maybe because your stats migration failed previously and this is now caught and fixed:
home-assistant:dev ← home-assistant:migrate_stats
opened 06:30PM - 10 Oct 23 UTC
## Proposed change
Describe the big picture of your changes here to com… municate to the
maintainers why we should accept this pull request. If it fixes a bug
or resolves a feature request, be sure to link to that issue in the
additional information section.
The stats timestamp migration had some somewhat rare failure cases that were not accounted for:
- If a user has duplicate rows that were manually inserted or inserted by external stats before we had the unique index they could fail to migrate. We now fallback to a one by one migration when this happens.
- If the user downgraded HA from 2023.3.x to an older version without restoring the database and they upgrade again with the same database they will have un-migrated statistics columns since we only migrate them once.
Because this involves migrating data, this should go through beta. While it means the users in the linked issue will have to wait a month for a solution, we need to make sure it doesn't have any side effects.
## Type of change
What type of change does your PR introduce to Home Assistant?
NOTE: Please, check only 1! box!
If your PR requires multiple boxes to be checked, you'll most likely need to
split it into multiple PRs. This makes things easier and faster to code review.
- [ ] Dependency upgrade
- [x] Bugfix (non-breaking change which fixes an issue)
- [ ] New integration (thank you!)
- [ ] New feature (which adds functionality to an existing integration)
- [ ] Deprecation (breaking change to happen in the future)
- [ ] Breaking change (fix/feature causing existing functionality to break)
- [ ] Code quality improvements to existing code or addition of tests
## Additional information
Details are important, and help maintainers processing your PR.
Please be sure to fill out additional details, if applicable.
- This PR fixes or closes issue: fixes #101466
- This PR is related to issue:
- Link to documentation pull request:
## Checklist
Put an `x` in the boxes that apply. You can also fill these out after
creating the PR. If you're unsure about any of them, don't hesitate to ask.
We're here to help! This is simply a reminder of what we are going to look
for before merging your code.
- [x] The code change is tested and works locally.
- [ ] Local tests pass. **Your PR cannot be merged unless tests pass**
- [ ] There is no commented out code in this PR.
- [ ] I have followed the [development checklist][dev-checklist]
- [ ] I have followed the [perfect PR recommendations][perfect-pr]
- [ ] The code has been formatted using Black (`black --fast homeassistant tests`)
- [x] Tests have been added to verify that the new code works.
If user exposed functionality or configuration variables are added/changed:
- [ ] Documentation added/updated for [www.home-assistant.io][docs-repository]
If the code communicates with devices, web services, or third-party tools:
- [ ] The [manifest file][manifest-docs] has all fields filled out correctly.
Updated and included derived files by running: `python3 -m script.hassfest`.
- [ ] New or updated dependencies have been added to `requirements_all.txt`.
Updated by running `python3 -m script.gen_requirements_all`.
- [ ] For the updated dependencies - a link to the changelog, or at minimum a diff between library versions is added to the PR description.
- [ ] Untested files have been added to `.coveragerc`.
This project is very active and we have a high turnover of pull requests.
Unfortunately, the number of incoming pull requests is higher than what our
reviewers can review and merge so there is a long backlog of pull requests
waiting for review. You can help here!
By reviewing another pull request, you will help raise the code quality of
that pull request and the final review will be faster. This way the general
pace of pull request reviews will go up and your wait time will go down.
When picking a pull request to review, try to choose one that hasn't yet
been reviewed.
Thanks for helping out!
To help with the load of incoming pull requests:
- [ ] I have reviewed two other [open pull requests][prs] in this repository.
[prs]: https://github.com/home-assistant/core/pulls?q=is%3Aopen+is%3Apr+-author%3A%40me+-draft%3Atrue+-label%3Awaiting-for-upstream+sort%3Acreated-desc+review%3Anone+-status%3Afailure
Thank you for contributing <3
Below, some useful links you could explore:
[dev-checklist]: https://developers.home-assistant.io/docs/development_checklist/
[manifest-docs]: https://developers.home-assistant.io/docs/creating_integration_manifest/
[quality-scale]: https://developers.home-assistant.io/docs/integration_quality_scale_index/
[docs-repository]: https://github.com/home-assistant/home-assistant.io
[perfect-pr]: https://developers.home-assistant.io/docs/review-process/#creating-the-perfect-pr
This is the only other db change I could find:
home-assistant:dev ← home-assistant:increase_sqlite_max_binds
opened 11:26AM - 05 Oct 23 UTC
## Proposed change
For sqlite 3.32+ we can increase the max bind vars to purge / migrate more data in one call. For postgresql and mysql we can always use a larger max bind vars.
This is also a small improvement to startup time as well do a few less queries to find the attributes and states meta ids to record initial states
replaces and closes #96955
related issue #101100
## Type of change
- [ ] Bugfix (non-breaking change which fixes an issue)
- [x] Code quality improvements to existing code or addition of tests
## Checklist
been reviewed.
Updated to HA release 2023.11.3 this afternoon. Now it says I cannot use the weather information provided by the Ecobee integration as a platform for the weather: item in configuration.yaml. I’d guess this is somewhere in the ‘breaking changes’ area of a release notes page?
This post is mostly intended as FYI for other Ecobee users… I simply disabled the weather: item altogether. Can’t currently use the NWS integration because it’s not updating the sensor values, even though the Python component is parsing the JSON from NWS successfully.
nickrout
(Nick Rout)
December 6, 2023, 10:05am
346
Yep, the 41 to 42 was committed on October 23
## Proposed change
## Type of change
## Checklist
been reviewed.
this must be something related to your config, my ecobee weather is still coming through without issue on 2023.11.3
edit: for clarity, I am using the ecobee integration, not the homekit integration.
I also have weather pulling from the Meteorologisk institutt (Met.no) integration so that I can also have an hourly forecast available in homeassistant, since the ecobee weather does not
It happened to me in the past that I tried to rollback just the HA container to a previous version, but then HA didn’t startup because the database schema version was newer than it expected. Because I didn’t rollback the database addon (I prefered to keep the data that was generated in the meantime).
So that’s why a little sentence in the releasenotes like 'this release has an upgrade to the database schema" would be real nice. So that people know they need to make sure to backup their database.
tom_l
December 6, 2023, 10:05pm
349
Yes I understand why you want a warning in the notes and I agree it should be included when there is a schema update .
However as I said, this release did not actually include an update . It only included a fix in case you missed previous updates.
So most people who the update worked for in a previous release would not see an update this time.
Something went wrong with your install when it tried to update your install in a previous release or possibly because of this:
Home Assistant now realises you are on the wrong DB version and updated it for you . This did not happen for everyone.
