I personally actually agree with this. I just meant this is the more debatable part of the issues raised (not that I necessarily agreed with it, hence the maybe).
Thatâs definitely a communication faux pas.
For me, personally, the unsolvable issue ATM is the lack of a consider_home
alternative (apart from what Ildar Gabdullin suggested here, which is too much Iâm afraid).
nope, you misread, and misconcluded.
there is (and has been for some time now) 100% user-controllability, and that was what I was referring to. (via the one beautiful automation).
Then my comment is still valid.
Packages in yaml may be managed.
UI settings cannot be united to packages; but this is not related to â2023.12 releaseâ thread directly.
I like the new climate card
Not a huge fan of the changes around the Ping sensor - was trying to change it to do every 90 seconds (5 minutes is too long) and then saw the formula/math needed in this post to do the automation
It appears from comments higher in the thread this difficulty was implemented on purpose, so I just gave up on using Home Assistant for ping all together and just do it through the ping node in Node Red now
What I see is simple arithmetic but if anyone finds it daunting then it can be reduced to this:
{{ now().timestamp() | int(0) % 90 == 0 }}
Use it as a condition with a 30-second Time Pattern Trigger (as explained in the linked example) or simply as a Template Trigger.
Or if youâre already using Node-Red, use mwav3âs suggestion; itâs more convenient. Otherwise, installing Node-Red (and learning how to use it) merely for the use of ping seems like a lot of overhead. Nevertheless, itâs an easy first step into a new world of possibilities with Node-Red.
Or
- platform: time_pattern
minutes: "/1.5"
should work.
Really? Post in the other thread.
Thank you, appreciate the updated formula. I will be the first to admit I am not an expert with Home Assistant automatons, and your posts and expertise has definitely helped me many times when putting them together. I definitely like the visual aspect of automations in node red so have been running it for awhile, but definitely agree would not be worth the overhead of installing node red just for ping.
Will give the automation using your trigger another try and see which way ultimately works best now. My use case for background is I just want to have a sensor that determines if internet is online, and then when it goes offline for over 5 minutes my GSM modem texts me there is an internet outage at the house.
Itâs not supported. The Automation Editor flags it as an error when you attempt to save the automation.
Then thereâs really no reason to alter the poling rate. It will have a 30 second polling rate in 2023.12.1
Oh perfect, thanks Petro. Glad they are going with the 30 seconds over 5 minutes
though I love the beauty of that, and also the optimal flexibility we get with service homeassistant.update_entity
I must confess it would be nice if we could just jot in
automation:
seconds: /90
why would it be too difficult to have the backend take care of that? I suppose many more triggers than only for replacing scan_interval could use that.
What is the main reason that this whole scan_interval is removed?
Isnât a free will of the user to set this on whatever they wantâŚ
If I want a scan_interval of 1 seconds then this is my decision. I can have a good reason for.
Now I have an automation to update some device_trackers with a 5 seconds interval.
If this is the reason, people have to build a automation to make this happen, thatâs ok.
But is the resource impact the same when you used scan_interval vs a automation that update entities?
Just some questions that pops up after reading all those scan_interval stuff
This has been covered several times already. Read the thread. Search the forum.
You have that option. Use automations.
No, it isnât. Read the thread. Hint: external websites might not like it.
Then whatâs the issue?
HA is built to run automations. Take a guess.
HmmâŚ
Actually, it is his decision. Whether or not external websites like it has nothing to do with that. Especially if he is not even pinging external websites. And not being able to configure the interval also means I canât make it longer, so as of 12.1 I will be pinging every 30 seconds even though I only really need every 5 minutes, unless I make the extra effort to create an additional automation. How many people will bother to do that, if their own system isnât really affected by that higher frequency?
I understand that giving people the power to create short ping intervals comes with some risks. Those risks are mainly for the users themselves, they might get excluded from reaching certain websites. That will probably teach them something, but it is not my favorite way users should be educated about these risks. I would prefer doing that by making short intervals part of âadvanced optionsâ or something like that, and by giving them a dialog before this option is activated.
I really donât agree with creating a UI that does not give you the option to change the interval in any way, and instead directing people to a different UI to change the parameters of what the first UI is doing.
You can change it. Itâs been stated multiple times that you disable polling and make an automation that does the polling.
Was that a reply to this?
Because in that case you did not understand what I was saying. I know this is possible. Read the line again. What I mean is that the workaround with the automation is, to me, a weird and unncessarily complex way to achieve this, sweeps all uses of ping including local network applications under the same denominator, doesnât educate clueless users about the problems they might cause and doesnât really solve the problem in the first place.
Have nothing against about deprecation of âscan_intervalâ. This may be anyway replaced by an automation. Moreover, for most integrations I already update entities in automations since it allows me to update them conditionally (âdo not update ifâŚâ).
Things about recent changes of PING that worries me are:
â docs became inconsistent in part of âdevice_trackerâ;
â these changes for many users became sudden; users should be just warned âyaml ping config will be deprecated in 2023.x; scan_interval will be deprecated in 2023.xâ.
What happened in fact was rather hasty. Repeat, these changes did not touch me personally.
In general even this âswitch off polling & use automationsâ way (very smart) is still not giving people 100% control âwhen the entity is updatedâ: entities are still automatically updated on HA startup. I keep asking questions about âhow to disable updating on HA startupâ - and usually this is unanswered or ignored.
These next âmove yaml â UIâ changes touches more & more integrations. Although it was said (ADR) that only integrations of some kind will be moved to UI - I am afraid that this list will grow. Usually I see a reaction from same people (liked by same people) - same âship is sailed and so onâ, also about âthis approach was discussed and agreed by majorityâ. Can I see a thread where it was âdiscussed & approvedâ? (I hope it will not be same story as happened recently with the latest primitive HA logo which was also âdiscussed & approvedâ).
Have responded to the wrong post?
My post was in response to an original post in the 2023.12 Welcome home blog (which you moved along with mine to this), on how to trigger an automation every 90secs. I didnât mention ping at all.
As others have mentioned my suggestion doesnât work, however that is irrelevant to your remark if indeed, it was aimed at me.
