Yeah the CPU Temperature is lost on my RPi. Seems to be the ping thing they have introduced messing with my config yaml. I have rolled back to 2023.11.3 for now till there’s an update or more information.
you don’t say how you are reading the CPU Temp from RPi but this is still working fine for me on 2023.12
you need to change the structure of the sensor in the linked post as the Command Line format has changed since it was posted
Are there some more information about the blueprint reimport? I provide some blueprints in this community mainly hosted on github. I also provide a source url linked to the related file on github.
I’ve recently updated that file, clicked on reimport. I got a success message but the blueprint did not update.
Do I have to provide the blueprint code directly in the first post of my blueprint thread?
I haven’t installed the update yet, so I don’t yet know what the new thermostat will do to my displays, but I imagine it won’t be good.
One big problem I already had with the new version, which you can get at by clicking the dots on the old one, is that if a device is “off”, on the old card you can still turn it on by dragging the temperature setting up. On the new one, you can’t do this.
I have worked in IT since 1979 and if there is one thing I have learned over that time, it is that imposing a change on people that they didn’t ask for simply because you think it is a good idea is guaranteed not to be widely accepted well.
Please separate these two versions and give us the choice to change to the new one IF WE WANT TO.
Anyone here already figured out how to get the Roborock Vacuum Maps? According to the release notes that should now work?
Wondering the exact same question. I cant see any entities for image in my roborock integration.
It may be disabled by default, check your disabled entities in the integration page.
Any way to revert to the old login screen? These multi-click logins are annoying when using password managers. It’s much better to have to enter both username and password every time when auto-filling with my password manager.
Petro, did you consider collecting all climate/thermostat card related posts too? might be good to follow the progress being made outside of the release topic
If there is only one mode, it will be hidden for the default dashboard in the 2023.12.1
Meh, that’s not really overtaking the release thread. Gonna keep it here for now.
Yeah, that was indeed the first I noticed
Not very logical, as a setting is temporary, and the current temperature should be the main visual.
Guess I could share my thermostat card since that’s a topic of conversation right now. It uses a Picture Elements card as the background for the Simple-Thermostat and Mini Graph custom cards.
I manage my thermostat temperature scheduling with a bear of an automation that makes too much use of templates that I should eventually re-write but it works, so my motivation to change it is low.
Yaml for Card
The background image is just a transparent PNG, sized to fit the card.
I’m not convinced that the style
key at the parent level actually does anything since I think that’s for Card Mod, but I removed Card Mod from my installation and the card didn’t change.
type: picture-elements
image: /local/background200.png
style: |
ha-card {
background-size: auto 160px;
#image {
height: 160px;
elements:
- type: custom:simple-thermostat
entity: climate.t6_pro_z_wave_programmable_thermostat_mode
control: false
header: false
sensors:
- entity: sensor.openweathermap_feels_like_temperature
- entity: sensor.t6_pro_z_wave_programmable_thermostat_humidity
hide:
temperature: true
state: false
step_size: 1
style:
width: 90%
height: 100%
top: 60%
left: 50%
z-index: 1
'--card-background-color': transparent
'--ha-card-box-shadow': none
'--st-font-size-xl': 2rem
'--ha-card-border-width': 0px
- type: custom:mini-graph-card
show:
legend: false
show_state: false
icon: false
entities:
- entity: sensor.t6_pro_z_wave_programmable_thermostat_air_temperature
- entity: sensor.accuweather_realfeel_temperature
points_per_hour: 1
style:
width: 100%
height: 100%
opacity: 0.4
z-index: 0
top: 50%
left: 50%
background-color: rgba(0,0,0,0)
pointer-events: none
at first look i thought the new thermostat card was great, but now i’ve updated i noticed that is really garbage.
- the 2 temperatures are swapped
- the fonts are smaller and now not as good readable from a distance
- it’s bigger in height and now does not look good anymore on my display
- i really liked the little buttons for heat, cool, off, etc.
- the + - buttons are nice but they take too much space, they also could be placed beside the temperatures. or just be gone
the new circle animation and glow are nice but due to the above points not acceptable.
i really want to revert back to the old one, is there a way to do that? or is the only option to restore a backup?
or maybe give it more customization options so anyone can make it how they like?
Anyone notice a bug with tts.google_cloud_say no longer working after update to 2023.12.0?
I just discovered something really weird testing this for you.
I was curious because Google Could TTS is working for me here, when called in my tts message script. But then I tried it in the dev tools services and got this error. There were no errors in the log, only the error show in the UI in this screen shot.
So I wrote a test script that just has a google could tts service call. This also work as expected, tts message plays and no log errors.
test:
sequence:
- service: tts.google_cloud_say
entity_id: media_player.dining_room_hub
message: My name is hanna
Calling the service with entity id in the data parameter in the dev tools services UI also works.
As far as I know it should accept a target. It does run when called from script with entity_id in the target. Maybe the dev tools thing is related to your issue. I don’t know if this behaviour existed before the update, I’ve never had a reason to try it in dev tools.
Anyway, found this very strange, I have never seen this discrepancy in behavior before.
Thanks for looking into this! It seems that my logs report “Unknown input format: ‘LINEAR16’”. Unsure what changed.
This is another kick in the teeth for me, the harmony integration was setup using the switch platform long before the select platform was available. Therefore anyone that has been using harmony for a while will likely have things setup using switches.
I would really love some answers as to why this was removed, I have read comments regarding the fact we don’t need 3 ways to control harmony, why the hell not? Unless it is causing or going to cause an issue in the future are we just removing because we can rather than out of necessity?
Not only do I need to change many automations and scripts now, but I also have to rewrite many template sensors that I created to detect certain groups of activity’s to control other home cinema related systems.
Also for example I am going to have to try and rework something for google assistant as it doesn’t work with select entities so I will be unable to ask google to activate an activity.
I could go on but wont as I am sure there wont be a reasonable answer given as to why fully functional options are just simply removed, seriously I would appreciate a technical answer as to why this has been removed as if there is one then fine at least I can spend my weekend trying to write half my HA knowing I am doing it for good reason and not just because someone decided they wanted to remove it.
I’m not sure either, I’m not getting that error but in general posting log errors when you’re asking about something not working would be quite helpful for people trying to help you figure it out.
