You’ll have to provide more details. It’s working as expected on my end.
It had adapted to the long-standing convention for several years, up until this release when it appears that a tech bro chose to ‘disrupt the thermostat paradigm’.
If clearing your cache and refreshing the page does not work, create an issue and make sure to specify what browser you’re using to view HA.
I was really happy to see the CalDAV integration supporting ToDos/Tasks now. That has been one of the features I’ve been really hoping for.
I tried to use a a template in the due_datetime
variable of the todo.add_item
. However no matter what I tried, I only got an error.
The service call I tried looks something like this:
service: todo.add_item
entity_id: todo.chores
item: Fold the dried Laundry!
description: Fold the dried Laundry!
due_datetime: "{{ (now() + timedelta(hours=36)) }}"
However, even with something like due_datetime: "{{ (now() + timedelta(hours=36)).isoformat(timespec='seconds') }}"
, i.e. either returning the time as a datetime
in the first example or as a str
in the second, the service call fails, with the python-caldav
package complaining:
File "/usr/src/homeassistant/homeassistant/components/automation/__init__.py", line 655, in async_trigger
await self.action_script.async_run(
File "/usr/src/homeassistant/homeassistant/helpers/script.py", line 1578, in async_run
return await asyncio.shield(run.async_run())
File "/usr/src/homeassistant/homeassistant/helpers/script.py", line 420, in async_run
await self._async_step(log_exceptions=False)
File "/usr/src/homeassistant/homeassistant/helpers/script.py", line 470, in _async_step
self._handle_exception(
File "/usr/src/homeassistant/homeassistant/helpers/script.py", line 493, in _handle_exception
raise exception
File "/usr/src/homeassistant/homeassistant/helpers/script.py", line 468, in _async_step
await getattr(self, handler)()
File "/usr/src/homeassistant/homeassistant/helpers/script.py", line 704, in _async_call_service_step
response_data = await self._async_run_long_action(
File "/usr/src/homeassistant/homeassistant/helpers/script.py", line 666, in _async_run_long_action
return long_task.result()
File "/usr/src/homeassistant/homeassistant/core.py", line 2067, in async_call
response_data = await coro
File "/usr/src/homeassistant/homeassistant/core.py", line 2104, in _execute_service
return await target(service_call)
File "/usr/src/homeassistant/homeassistant/helpers/entity_component.py", line 272, in handle_service
return await service.entity_service_call(
File "/usr/src/homeassistant/homeassistant/helpers/service.py", line 878, in entity_service_call
single_response = await _handle_entity_call(
File "/usr/src/homeassistant/homeassistant/helpers/service.py", line 948, in _handle_entity_call
result = await task
File "/usr/src/homeassistant/homeassistant/components/todo/__init__.py", line 455, in _async_add_todo_item
await entity.async_create_todo_item(
File "/usr/src/homeassistant/homeassistant/components/caldav/todo.py", line 147, in async_create_todo_item
await self.hass.async_add_executor_job(
File "/usr/local/lib/python3.11/concurrent/futures/thread.py", line 58, in run
File "/usr/local/lib/python3.11/site-packages/caldav/objects.py", line 765, in save_todo
data=self._use_or_create_ics(ical, objtype="VTODO", **ical_data),
File "/usr/local/lib/python3.11/site-packages/caldav/objects.py", line 733, in _use_or_create_ics
return vcal.create_ical(objtype=objtype, **ical_data)
File "/usr/local/lib/python3.11/site-packages/caldav/lib/vcal.py", line 184, in create_ical
component.add(prop, props[prop])
File "/usr/local/lib/python3.11/site-packages/icalendar/cal.py", line 194, in add
value = self._encode(name, value, parameters, encode)
File "/usr/local/lib/python3.11/site-packages/icalendar/cal.py", line 145, in _encode
obj = klass(value)
File "/usr/local/lib/python3.11/site-packages/icalendar/prop.py", line 312, in __init__
raise ValueError('You must use datetime, date, timedelta, '
ValueError: You must use datetime, date, timedelta, time or tuple (for periods)
Am I doing something wrong after all?
Edit: As asked by @petro, I opened a bug report.
Sounds like you found a bug, can you please write it up?
My sensors stopped working after Home Assistant Core 2023.12.0 was installed.
I don’t understand what needs to be done to fix the problem.
Hopefully, someone can tell me what I’m doing wrong.
I can no longer get sensor updates for:
sensor.smart_electric_meter_consumption
sensor.smart_electric_meter_power
sensor.smart_electric_meter_production
Here is my configuration.yaml:
- platform: command_line
unique_id: xcel_meter_power
name: "Smart Electric Meter Power"
#command: "OPENSSL_CONF=/config/xcelcerts/myown/openssl.cnf /usr/bin/curl --ciphers ECDHE-ECDSA-AES128-CCM8 --insecure --url https://10.0.0.226:8081/upt/1/mr/1/r --cert /config/xcelcerts/myown/cert.pem --key /config/xcelcerts/myown/key.pem 2>&1 | grep -o '<value>.*</value>' | grep -Eo '[0-9]+'"
command: "OPENSSL_CONF=/config/xcelcerts/myown/openssl.cnf /usr/bin/curl --ciphers ECDHE-ECDSA-AES128-CCM8 --insecure --url https://10.0.0.226:8081/upt/1/mr/1/r --cert /config/xcelcerts/myown/cert.pem --key /config/xcelcerts/myown/key.pem 2>&1 | grep -o '<value>.*</value>' | grep -Eo '([+-]?[0-9]+)'"
# value_template: "{{ float(value) | multiply(0.001) | round(3) if is_number(value) }}"
# value_template: "{{ value | multiply(0.001) | round(3)}}"
# value_template: "{{ float(value) if is_number(value_json) }}"
unit_of_measurement: "W"
device_class: "power"
scan_interval: 5
command_timeout: 5
unique_id: xcel_meter_consumption
name: "Smart Electric Meter Consumption"
command: "OPENSSL_CONF=/config/xcelcerts/myown/openssl.cnf /usr/bin/curl --ciphers ECDHE-ECDSA-AES128-CCM8 --insecure --url https://10.0.0.226:8081/upt/1/mr/3/r --cert /config/xcelcerts/myown/cert.pem --key /config/xcelcerts/myown/key.pem 2>&1 | grep -o '<value>.*</value>' | grep -Eo '[0-9]+'"
unit_of_measurement: "kWh"
device_class: "energy"
state_class: "total_increasing"
#scan_interval: 86400
scan_interval: 5
command_timeout: 5
unique_id: xcel_meter_productiion
name: "Smart Electric Meter Production"
command: "OPENSSL_CONF=/config/xcelcerts/myown/openssl.cnf /usr/bin/curl --ciphers ECDHE-ECDSA-AES128-CCM8 --insecure --url https://10.0.0.226:8081/upt/1/mr/2/r --cert /config/xcelcerts/myown/cert.pem --key /config/xcelcerts/myown/key.pem 2>&1 | grep -o '<value>.*</value>' | grep -Eo '[0-9]+'"
scan_interval: 5
command_timeout: 5
The Example configuration in //Command Line says do this:
But It doesn’t work either.
Example configuration.yaml entry
command_line:
- sensor:
command: SENSOR_COMMAND - sensor:
command: SENSOR_COMMAND_2
This is what I changed my configuration.yaml to look like:
command_line:
- sensor:
scan_interval: 5
command_timeout: 5
- sensor:
scan_interval: 5
command_timeout: 5
- sensor:
scan_interval: 5
command_timeout: 5
When I make the changes above, this is how it complains:
Close, it should be
command_line:
- sensor:
scan_interval: 5
command_timeout: 5
- sensor:
scan_interval: 5
command_timeout: 5
- sensor:
scan_interval: 5
command_timeout: 5
The new climate card does not allow me to add all features into the card. My AC integration has fan modes (low, med, high etc) and swing modes (horiz, vert, both etc) . These are not offered as ‘features’.
As said most if not all thermostats do.
Anyway it’s funny to vote for a feature request (which I will) to get back what was already there in the previous release
It wasn’t related to the app at all, it was a connectivity problem because of my stupid router. I won’t bother anyone here with that… But thanks for the suggestions
I did some tests and figured it out.
Say you use variable ‘Agenda’, then your template for events was agenda.events
The template now has changed to agenda['calendar.<name>'].events
After update Toshiba air conditioner does not work
Logger: homeassistant.util.package
Source: util/package.py:102
First occurred: December 6, 2023 at 23:11:29 (3 occurrences)
Last logged: December 6, 2023 at 23:11:50
Unable to install package toshiba-ac==0.3.3: ERROR: Cannot install toshiba-ac==0.3.3 because these package versions have conflicting dependencies. ERROR: ResolutionImpossible: for help visit Dependency Resolution - pip documentation v24.0.dev0
If having only one mode, will the HVAC modes be suppressed? I really like the clean design…
One mode, in this context would be “ON” and nothing more. There will generally always be two, at least on and off, be it thermostat of and heat on/cool on or thermostat on and cool on and heat on.
Regardless you can control if you see modes or not.
I love the new design of the thermostat, much more modern.
Not correct, I have KNX thermostats providing only heating mode (on). Therefore it would be nice if the one mode will be suppressed as the button is not useful.
Wait, you mean there’s a way to exclude data from being stored in LTS? Can someone point me to where this is documented?
This would be fantastic, for me. I have no use for the vast majority of the LTS data and always wondered why something like this was kept forever, with no exclude and no keep_days options, like we have with the states and events data.
That would also be great, and would be the most logical database design choice. But, alas, it’s actually stored in the same database, albeit in different tables.
Will the auto-logon feature built into all modern browsers still work with this new logon page?
Right now, I rarely see the logon page. At my house, we all use the same account. If we’ve clicked the “keep my logged on” box once on a device, from then on it goes directly to the dashboard, which is what I want.
I’m hoping I don’t have to select from a list of users (there would only be one) every time.
Yes, separate tables, however the comment still stands:
