It works! Thank you, my friend!
I was just thinking due_date
and due_datetime
, in the Add_item service call might be useful to you if you are using it for your daily agenda.
and due_datetime
Hi! @Frank_Howell opened a topic for changes in the HomeWizard integration, can you move your comment to topic so we can keep everything together? â HomeWizard and 2023.12
Anyone having an issue where the new login page doesnât show? As far as I recall it doesnât appear any different than 2023.11. I can see the user images in Lovelace, on both my user profile and as badges, and Iâm on a trusted network with only IPv4, but it doesnât show the images on the logon screen and I donât see the âWhoâs logging inâ text.
HASSOS on x86 bare metal
Core 2023.12.0
Supervisor 2023.11.6
Operating System 11.2
Frontend 20231206.0
Update: Well I finally figured out that I needed to click on the âHome Assistant Localâ arrow at the bottom, which then shows the new screen with user images. Is there any way to make that the default screen? Otherwise, no one in my family would bother to use it. It takes a second click to get to it, and Iâm all about less clicks.
Update #2: Figured it out - I had to move the homeassistant entry above trusted_networks in configuration.yaml:
auth_providers:
- type: homeassistant
- type: trusted_networks
trusted_networks:
Thank your very much @karwosts for adding the feature to display statistics values in the history graph. Thatâs one of the best and most useful features this year.
I still have some confusion around this. Is long term storage something new? And its completely different from the 10 (default) recorder?
Long term stats were added when energy was added. So 3 years old maybe? Yes itâs a separate database optimized for numerical values and it aggregates the data instead of storing each state change.
found a bug with the deep linked to do links, looks like they end up defaulting to whatever was last selected as a todo item. So if you have 2 items and copy the link for Item A and select Item B, then when you open a new tab and paste the URL it open Item B instead of Item A. This impacts desktop and mobile.
Thanks for the heads up. I had to change a setting in pfsense haproxy to get mine to work also.
@marcus22 @Duke_box @SanderKo85 (and anyone else who had the thermostat card remove Power, Heat, Cool, Auto, etc)
The autogenerated UI will now default to exposing HVAC modes in the thermostat card, which will give you that functionality back without doing anything. This will be available in 2023.12.1, which is planned for tomorrow.
@Ih8rain2 it looks like youâve taken control of your dashboard, you can add/remove features via the UI. Not sure if you saw that because your last post claims you canât find them.
As for those who control your UI,
Result:
Also 2023.12.1 will bring back the 30 second scan interval for ping.
No I rolled back to the previous release where the thermostats looked fine to me. See my post.
Ok, just keep in mind that when you update (to any future release), youâll need to add the features to your configuration because you arenât running the default dashboard.
I checked features drop list but doesnât have anything useful.
The only thing nice about the new thermostat (for me) is the ring. The rest is a step backwards
I would just be great full if the target temperature and the actual temperature would be switched.
and if you want your climates to use a saner step than 0.1 simply add
homeassistant:
customize_domain:
climate:
target_temp_step: 0.5
works just beautifully
I suggest you vote for this Feature Request:
FWIW, I also prefer to see a larger current temperature (and smaller target temperature). My physical thermostat (an HAI Omnistat/2 thatâs well over ten years old) displays it like that.
The thermostart card - not an improvement, at least not yet
First thing to draw the eye on a dashbord : the HUGE BRIGHT coloured mode-change buttons on each thermostat - not the thing you want to detect first. They are BRIGHT even when the thermostat is idle and otherwise low-tuned - seriously ?
Second thing you detect is the setpoint - which you already know - where is the current value, get your glassesâŚ
The update removes functionality from the dashbord - yes itâs possible to get that back by making additional configuration - but that is not what you expect every end-user to do, typically itâs a task for the one(s) doing maintenance. Thus this was a breaking change - but not listed as one.
That wonât be a reason for adaptation⌠there probably is no real life thermostat around without a flame when heating, and yetâŚ
Hi, Im having an issue of when you press a mode button on the new thermostat card it jumps up to the top of the page, how do I stop that?
just tried it. For now, itâs useless.
