### The problem
I have 3x Hikvision DS-2CD2232-I5 cameras that have been workin…g fine with the onvif integration for a very long time. After upgrading to 2023.4.0 all 3 cameras stopped working. The cameras are reachable over the network (from a browser)
The logfile shows
2023-04-06 10:24:51.999 ERROR (MainThread) [homeassistant.config_entries] Error setting up entry Kamera - kældertrappe - 44:19:b6:4e:d2:23 for onvif
File "/usr/src/homeassistant/homeassistant/config_entries.py", line 383, in async_setup
result = await component.async_setup_entry(hass, self)
File "/usr/src/homeassistant/homeassistant/components/onvif/__init__.py", line 30, in async_setup_entry
if not await device.async_setup():
File "/usr/src/homeassistant/homeassistant/components/onvif/device.py", line 112, in async_setup
self.profiles = await self.async_get_profiles()
File "/usr/src/homeassistant/homeassistant/components/onvif/device.py", line 309, in async_get_profiles
result = await media_service.GetProfiles()
File "/usr/local/lib/python3.10/site-packages/zeep/proxy.py", line 64, in __call__
return await self._proxy._binding.send_async(
File "/usr/local/lib/python3.10/site-packages/zeep/wsdl/bindings/soap.py", line 156, in send_async
response = await client.transport.post_xml(
File "/usr/local/lib/python3.10/site-packages/zeep/transports.py", line 235, in post_xml
response = await self.post(address, message, headers)
File "/usr/local/lib/python3.10/site-packages/zeep/transports.py", line 220, in post
response = await self.client.post(
File "/usr/local/lib/python3.10/site-packages/httpx/_client.py", line 1848, in post
return await self.request(
File "/usr/local/lib/python3.10/site-packages/httpx/_client.py", line 1533, in request
return await self.send(request, auth=auth, follow_redirects=follow_redirects)
File "/usr/local/lib/python3.10/site-packages/httpx/_client.py", line 1620, in send
response = await self._send_handling_auth(
File "/usr/local/lib/python3.10/site-packages/httpx/_client.py", line 1648, in _send_handling_auth
response = await self._send_handling_redirects(
File "/usr/local/lib/python3.10/site-packages/httpx/_client.py", line 1685, in _send_handling_redirects
response = await self._send_single_request(request)
File "/usr/local/lib/python3.10/site-packages/httpx/_client.py", line 1722, in _send_single_request
response = await transport.handle_async_request(request)
File "/usr/local/lib/python3.10/site-packages/httpx/_transports/default.py", line 353, in handle_async_request
resp = await self._pool.handle_async_request(req)
File "/usr/local/lib/python3.10/site-packages/httpcore/_async/connection_pool.py", line 253, in handle_async_request
raise exc
File "/usr/local/lib/python3.10/site-packages/httpcore/_async/connection_pool.py", line 237, in handle_async_request
response = await connection.handle_async_request(request)
File "/usr/local/lib/python3.10/site-packages/httpcore/_async/connection.py", line 90, in handle_async_request
return await self._connection.handle_async_request(request)
File "/usr/local/lib/python3.10/site-packages/httpcore/_async/http11.py", line 112, in handle_async_request
raise exc
File "/usr/local/lib/python3.10/site-packages/httpcore/_async/http11.py", line 91, in handle_async_request
) = await self._receive_response_headers(**kwargs)
File "/usr/local/lib/python3.10/site-packages/httpcore/_async/http11.py", line 155, in _receive_response_headers
event = await self._receive_event(timeout=timeout)
File "/usr/local/lib/python3.10/site-packages/httpcore/_async/http11.py", line 191, in _receive_event
data = await self._network_stream.read(
File "/usr/local/lib/python3.10/site-packages/httpcore/backends/asyncio.py", line 34, in read
return await self._stream.receive(max_bytes=max_bytes)
File "/usr/local/lib/python3.10/site-packages/anyio/_backends/_asyncio.py", line 1265, in receive
await self._protocol.read_event.wait()
File "/usr/local/lib/python3.10/asyncio/locks.py", line 214, in wait
await fut
asyncio.exceptions.CancelledError
Could this be related to https://github.com/mvantellingen/python-zeep/pull/1369 ?
### What version of Home Assistant Core has the issue?
2023.4.0
### What was the last working version of Home Assistant Core?
2023.3.6
### What type of installation are you running?
Home Assistant OS
### Integration causing the issue
onvif
### Link to integration documentation on our website
https://www.home-assistant.io/integrations/onvif/
### Diagnostics information
_No response_
### Example YAML snippet
_No response_
### Anything in the logs that might be useful for us?
_No response_
### Additional information
_No response_
