Use VSCode and search for polymer in all files
Take a look here and change your sql queries.
The entity_idās are no longer stored in the states table.
the average text editor will search your www folder and return something like this
Note decluttering is listed twice, because I have 2 different versionsā¦
For those who donāt like breaking their beloved HA but canāt resist clicking on the update button, do like me:
- Create an automation, triggered by the HA components update action, who skip automatically the update until the right moment (here I avoid everything until we are the 15th of the month so that letās the time to the others devs to update their own code like HACS).
alias: HomeAssistant - Skip early update of the current month
description: "Avoid showing update notification of Home Assistant before the 15th of the current month "
- platform: device
type: turned_on
device_id: <id>
entity_id: update.home_assistant_supervisor_update
domain: update
- platform: device
type: turned_on
device_id: <id>
entity_id: update.home_assistant_core_update
domain: update
- platform: device
type: turned_on
device_id: <id>
entity_id: update.home_assistant_operating_system_update
domain: update
condition:
- condition: or
conditions:
- condition: template
value_template: "{{ now().day < 15 }}"
- service: update.skip
data: {}
entity_id:
- update.home_assistant_supervisor_update
- update.home_assistant_core_update
- update.home_assistant_operating_system_update
mode: single
- You could also add another automation to reveal the skipped patch the 15th but in reality, itās not useful as the devs are quite motivated and deliver at least one additional patch before the end of the month.
Thanks HA team ! Love your free product.
PS: I canāt wait adding that in my car and display some traffic alert or reminders from HA
Thank you, will check it.
youāre the man! thanks a lot, that was it!
Iām running Mariadb and Grafana in HA. This release recommends using HA SQL lite. Are there any guides for migrating from Mariadb back to HA SQL lite in Home Assistant?
Thank you. Itās OK now.
Rgds
Excuse me but what do you mean by āPlease update your custom cards.ā. You mean the HACS files (*.js)?
Answering my own post, just in case someone encounters the same problem. The two issues were related, being actually caused by the outdated syntax of the SQL sensors I am using. The (never ending, it seems) changes to the database resulted in some incorrect queries, which, at their turn, were putting the CPU under a continuous heavy load. Solved by correcting the queries, with the invaluable help of @VDRainer.
Decluttering card is a custom card, 2023.4 broke many custom cards. Many of those custom cards have new versions that work with 2023.4. Decluttering card is one of them. So, update your custom card (decluttering card) to the latest version.
I already done it to version 1.0.0.
I am uding lovelace thriugh configuration.yaml.
May be there is something else to do?
Rgds
Refresh your page. Keep in mind that updating decluttering card will only fix decluttering card. It will not fix other custom cards. Youāll have to apply updates for every broken custom card.
I have had problem with the Data Science for long time but decided to write about it now.
I have HA Supervised (healthy and supported). I do not remember exacly when it stopped working.
HASS-data-detective works and is connecting to the database (MariaDB). But there is the following error as in the attached picture.
I can work with engine = create_engine(db_url)
but now there is the same error:
AttributeError Traceback (most recent call last)
File <timed exec>:8
AttributeError: 'Engine' object has no attribute 'execute'
Hope you can advise me how to solve the problem.
decluttering is also mentioning the Polymer copyrights, so hope this will not break since again because of that.
Thereās not a lot of evidence the card actually uses it besides the 26 mentions though.
so keeping fingers crossed
After the update the (non-custom) button-card totaly breaks when the unit_of_measurement of the entity is ā%ā and show_state is true. The card failes to render.
have to reiterate on that I am afraidā¦
I have disabled all of those cards in my config, (they are indeed actually no longer functional, and restarted nevertheless) and still see the warning. So there is more t that than simply text searching for Polymer
since this will happen next release, see Deprecating Polymer | Home Assistant Developer Docs maybe we can get some guidance in āloading Polymer ourselvesā by the dev frontend team?
maybe we can do so, for the time being, as a standalone custom resource?
given several of these cards have not been updated for a while now, it would keep many of us from breaking frontends.
Where can I find this recommendation?
There is no formal recommendation outside the livestream event.
there is this 2023.4: Custom template macros, and many more new entity dialogs! - #15 by bdraco
but whoās to tell if you config fits that description
sqlite is likely just fine for most use cases.
