How does the new, official JVC integration compare to iloveicedgreentea/jvc_homeassistant
on github (which I currently use)?
Cool release! Unfortunately, all my esphome devices immediately broke when updating. I had to roll back to 2023.5.
Good explanation, but it appears even in āsupportedā installs, Storage isnāt working right at this moment:
How many hours till 2023.6.1 - anyone want to bet?
/share is an existing directory. Youāve always had it.
If you choose āshareā as the type, you will find your configured NAS directory within the /share directory
Why are dashboard UI improvements continuously neglected while popup dialogues get new features and polish in every release?
I just want more WYSIWYG control over the UI. I hate creating a house of card_mod across my entire front end.
how did you change the dialog box color? i have been trying for ages.
You donāt have default:
included, so it is defaulting to debug.
You want something like:
logger:
default: info
logs: ...
Wow - something has seriously broken HA in this release. All of my buttons are taking up to 10 seconds to respond to clicks (be it on or off). Itās almost unusable.
Iāve lost track of how many smooth upgrades I have had now, great work team.
Loving the introduction of the media player to Android Remote and the new colour picker on the light more-info. The UI for adding/removing preset is very sexy! Only suggestion is to preconfigure it with only one row of preset colours. At least for me I get a scroll bar with two rows but itās fine with one.
Caution for Daikin Users: This release has broken both my Daikin Ducted with Airbase (Now recognised as āNOTSUPPORTā) and my Daikin Kora (Simply āUnavailableā) heat pumps.
Cheap for what you get. Iād pay more quite happily.
Connection to Synology NAS
Looks like I am failing to do an NFS connection due to Access Denied
I cannot figure out the issue:
- I have a dedicated user configured called āhomeassistantā
- NFS is enabled for the share, and āhomeassistantā user has RW access to the share
Any ideas?
Does someone use the roborock integration and can tell me what is new and supported. Does the map working? Iām using a custom integration and donāt want mess up and try the core integrationā¦
What does Zigbee Channel Auto do? Is this channel hopping, a static default channel or will ha chose the perfect channel for me?
The best question to ask is: is the documentation up to date? If yes, you can find your answer there. If not, it would be great to provide feedback on the integration page (button at the bottom). Roborock - Home Assistant
What Iām most excited about is the breaking change in zwave. The Nice IBT4ZWAVE module is finally recognized as a cover.
Youāre totally right!
That path does not matches what I need to use on my synology, if I had a root folder for homeassistant
that was shared, I would have to use /volume1/homeassistant
Anybody else experiencing issue with Media Browser not displaying controls in the UI anymore?
Iām seeing this after upgrading to HA Core 2023.6 (running Python3.11 virtual environment).
Iāve just filed an issue for this: Media Browser unusable as not displaying controls at the bottom Ā· Issue #16818 Ā· home-assistant/frontend Ā· GitHub.
