Hi Guys
Upgraded to 2023.7.1 from 2023.6.5 last night. Since then the RAINBIRD integration is not loading - I also tried to remove/uninstall the rainbird integration to set it up again but also not able to remove/uninstall it. Tried searching for a solution but nothing came up - anybody else experiencing issues with the rainbird integration ?
Restarted several times but no luck.
File "/usr/src/homeassistant/homeassistant/setup.py", line 215, in _async_setup_component
component = integration.get_component()
File "/usr/src/homeassistant/homeassistant/loader.py", line 813, in get_component
ComponentProtocol, importlib.import_module(self.pkg_path)
File "/usr/local/lib/python3.11/importlib/__init__.py", line 126, in import_module
return _bootstrap._gcd_import(name[level:], package, level)
File "<frozen importlib._bootstrap>", line 1204, in _gcd_import
File "<frozen importlib._bootstrap>", line 1176, in _find_and_load
File "<frozen importlib._bootstrap>", line 1147, in _find_and_load_unlocked
File "<frozen importlib._bootstrap>", line 690, in _load_unlocked
File "<frozen importlib._bootstrap_external>", line 940, in exec_module
File "<frozen importlib._bootstrap>", line 241, in _call_with_frames_removed
File "/usr/src/homeassistant/homeassistant/components/rainbird/__init__.py", line 4, in <module>
from pyrainbird.async_client import AsyncRainbirdClient, AsyncRainbirdController
File "/usr/local/lib/python3.11/site-packages/pyrainbird/async_client.py", line 22, in <module>
from aiohttp_retry import RetryClient, RetryOptions, JitterRetry
ImportError: cannot import name 'RetryOptions' from 'aiohttp_retry' (/usr/local/lib/python3.11/site-packages/aiohttp_retry/__init__.py)
when trying to remove the integration:
Logger: aiohttp.server
Source: components/rainbird/__init__.py:4
First occurred: 10:27:19 (2 occurrences)
Last logged: 11:51:30
Error handling request
File "/usr/local/lib/python3.11/site-packages/aiohttp/web_protocol.py", line 433, in _handle_request
resp = await request_handler(request)
File "/usr/local/lib/python3.11/site-packages/aiohttp/web_app.py", line 504, in _handle
resp = await handler(request)
File "/usr/local/lib/python3.11/site-packages/aiohttp/web_middlewares.py", line 117, in impl
return await handler(request)
File "/usr/src/homeassistant/homeassistant/components/http/security_filter.py", line 85, in security_filter_middleware
File "/usr/src/homeassistant/homeassistant/components/http/forwarded.py", line 227, in forwarded_middleware
File "/usr/src/homeassistant/homeassistant/components/http/request_context.py", line 28, in request_context_middleware
File "/usr/src/homeassistant/homeassistant/components/http/ban.py", line 80, in ban_middleware
File "/usr/src/homeassistant/homeassistant/components/http/auth.py", line 236, in auth_middleware
File "/usr/src/homeassistant/homeassistant/components/http/view.py", line 148, in handle
result = await handler(request, **request.match_info)
File "/usr/src/homeassistant/homeassistant/components/config/config_entries.py", line 87, in delete
result = await hass.config_entries.async_remove(entry_id)
File "/usr/src/homeassistant/homeassistant/config_entries.py", line 1089, in async_remove
await entry.async_remove(self.hass)
File "/usr/src/homeassistant/homeassistant/config_entries.py", line 581, in async_remove
