Heads up for Dutch users who are using the buienradar integration.
If you are seeing “unknown” in your weather related dashboards this morning, don’t worry, it’s not an HA problem. Since late yesterday evening, there has been no weather stations listed in the Buienradar JSON file. The 5 day forecast is still present and available.
You can follow this link to see the current JSON contents. https://data.buienradar.nl/2.0/feed/json
template:
- trigger:
- platform: state
entity_id:
- binary_sensor.oprit_vehicle_detected
- binary_sensor.oprit_person_detected
to: 'on'
# below triggers are required to prevent broken image placeholders
# do cause the state to show the last triggered time, end not perse the time the image was shot
- platform: event
event_type: delayed_homeassistant_start
- platform: event
event_type: event_template_reloaded
image:
- unique_id: last_snapshot_oprit_camera
name: Last snapshot oprit camera
url:
though one has got to bear in mind the date in the picture-entity shows the dat of the last triggered, and not necessarily the date of the moment the image was taken.
taking the trigger on the template reload and homeassistant start events out of the trigger template would solve that, but then would result in a broken image placeholder upon restart, or template reload…
I follow a morning routine where, after my alarm goes off and I am detected by a specific motion sensor, I want my calendar to be read out to me. The blueprint created by @allenporter works as a notification on my smartphone, but it doesn’t function as a voice output. How can I resolve this issue?
will report in the Plugwise topic too, but since this is a first discovery in 2023.7.1, I figured maybe other people experienced it too:
No idea what vn/a might be, and my Plugwise integration is working fine. tbh, I am a bit wary clicking Configureer there, as I dont want to mess up the other integration sections…
Thanks for getting back to us Nick. What would be the best way to inform Shelly of the new grouping advertisement data as I am sure they would like to keep up with HA?
Sometimes it’s the small things that make a difference, love having the Utility Meter helper on the device page. Thanks team for another great release!
I don’t know if the cause is the update but as soon as I updated to 2023.7 from 2023.6.0 a lot of jinja templates start to raise “RecursionError: maximum recursion depth exceeded”
After upgrading to 7.1 my Enphase Envoy is unable to connect.
RuntimeError: Could not connect or determine Envoy model. Check that the device is up at 'http://192.168.xxx.xxx'.
2023-07-07 14:06:40.956 ERROR (MainThread) [frontend.js.latest.202307051] :0:0 Script error.
2023-07-07 14:07:23.161 ERROR (MainThread) [homeassistant.components.enphase_envoy] Unexpected error fetching envoy Envoy xxxxxxxxxxxx data: Could not connect or determine Envoy model. Check that the device is up at 'http://192.168.xxx.xxx'.
File "/usr/src/homeassistant/homeassistant/helpers/update_coordinator.py", line 283, in _async_refresh
self.data = await self._async_update_data()
File "/usr/src/homeassistant/homeassistant/helpers/update_coordinator.py", line 242, in _async_update_data
return await self.update_method()
File "/usr/src/homeassistant/homeassistant/components/enphase_envoy/__init__.py", line 44, in async_update_data
await envoy_reader.getData()
File "/usr/local/lib/python3.11/site-packages/envoy_reader/envoy_reader.py", line 136, in getData
await self.detect_model()
File "/usr/local/lib/python3.11/site-packages/envoy_reader/envoy_reader.py", line 209, in detect_model
raise RuntimeError(
2023-07-07 14:07:28.269 ERROR (MainThread) [frontend.js.latest.202307051] :0:0 Script error.
2023-07-07 14:08:14.481 DEBUG (MainThread) [envoy_reader.envoy_reader] Fetched from http://192.168.xxx.xxx/production.json: <Response [301 Moved Permanently]>: <html>
<head><title>301 Moved Permanently</title></head>
<body>
<center><h1>301 Moved Permanently</h1></center>
<hr><center>openresty/1.17.8.1</center>
</body>
</html>
2023-07-07 14:08:14.485 DEBUG (MainThread) [envoy_reader.envoy_reader] Fetched from http://192.168.xxx.xxx/api/v1/production: <Response [301 Moved Permanently]>: <html>
<body>
</body>
</html>
2023-07-07 14:08:14.489 DEBUG (MainThread) [envoy_reader.envoy_reader] Fetched from http://192.168.xxx.xxx/production: <Response [301 Moved Permanently]>: <html>
<body>
</body>
</html>
2023-07-07 14:08:14.489 ERROR (MainThread) [homeassistant.components.enphase_envoy] Unexpected error fetching envoy Envoy xxxxxxxxxxxx data: Could not connect or determine Envoy model. Check that the device is up at 'http://192.168.xxx.xxx'.
raise RuntimeError(
2023-07-07 14:08:14.491 DEBUG (MainThread) [homeassistant.components.enphase_envoy] Finished fetching envoy Envoy xxxxxxxxxxxx data in 0.146 seconds (success: False)
2023-07-07 14:08:14.492 WARNING (MainThread) [homeassistant.config_entries] Config entry 'Envoy xxxxxxxxxxxx' for enphase_envoy integration not ready yet: Could not connect or determine Envoy model. Check that the device is up at 'http://192.168.xxx.xxx'.; Retrying in background
Got all excited when I saw something about the Energy dashboard until I realised it was just a new gauge.
When will the dashboard actually get some more customisation options ? There is a large thead on Github here asking for colour changing abilities for accessibility / readability reasons etc for example
The browser cache. The problem is, the Javascript files are big and get cached by the browser. Sometimes even a few cache hardresets are needed, to really get rid of the “old” scripts.
