sophof
(Sophof)
July 6, 2023, 4:20pm
103
Seems it’ll be fixed in 2023.7.1
home-assistant:dev ← home-assistant:slimproto-fix
opened 02:20PM - 06 Jul 23 UTC
## Proposed change
The PlayerStates enum was changed upstream, handle this in t… he HA integration as well.
Fixes a KeyError on the renamed IDLE playerstate vs STOPPED
## Type of change
- [ ] Dependency upgrade
- [X] Bugfix (non-breaking change which fixes an issue)
- [ ] New integration (thank you!)
- [ ] New feature (which adds functionality to an existing integration)
- [ ] Deprecation (breaking change to happen in the future)
- [ ] Breaking change (fix/feature causing existing functionality to break)
- [ ] Code quality improvements to existing code or addition of tests
## Additional information
Details are important, and help maintainers processing your PR.
Please be sure to fill out additional details, if applicable.
- This PR fixes or closes issue: fixes #95965
- This PR is related to issue:
- Link to documentation pull request:
## Checklist
Put an `x` in the boxes that apply. You can also fill these out after
creating the PR. If you're unsure about any of them, don't hesitate to ask.
We're here to help! This is simply a reminder of what we are going to look
for before merging your code.
- [ ] The code change is tested and works locally.
- [ ] Local tests pass. **Your PR cannot be merged unless tests pass**
- [ ] There is no commented out code in this PR.
- [ ] I have followed the [development checklist][dev-checklist]
- [ ] I have followed the [perfect PR recommendations][perfect-pr]
- [ ] The code has been formatted using Black (`black --fast homeassistant tests`)
- [ ] Tests have been added to verify that the new code works.
If user exposed functionality or configuration variables are added/changed:
- [ ] Documentation added/updated for [www.home-assistant.io][docs-repository]
If the code communicates with devices, web services, or third-party tools:
- [ ] The [manifest file][manifest-docs] has all fields filled out correctly.
Updated and included derived files by running: `python3 -m script.hassfest`.
- [ ] New or updated dependencies have been added to `requirements_all.txt`.
Updated by running `python3 -m script.gen_requirements_all`.
- [ ] For the updated dependencies - a link to the changelog, or at minimum a diff between library versions is added to the PR description.
- [ ] Untested files have been added to `.coveragerc`.
This project is very active and we have a high turnover of pull requests.
Unfortunately, the number of incoming pull requests is higher than what our
reviewers can review and merge so there is a long backlog of pull requests
waiting for review. You can help here!
By reviewing another pull request, you will help raise the code quality of
that pull request and the final review will be faster. This way the general
pace of pull request reviews will go up and your wait time will go down.
When picking a pull request to review, try to choose one that hasn't yet
been reviewed.
Thanks for helping out!
To help with the load of incoming pull requests:
- [ ] I have reviewed two other [open pull requests][prs] in this repository.
[prs]: https://github.com/home-assistant/core/pulls?q=is%3Aopen+is%3Apr+-author%3A%40me+-draft%3Atrue+-label%3Awaiting-for-upstream+sort%3Acreated-desc+review%3Anone+-status%3Afailure
Thank you for contributing <3
Below, some useful links you could explore:
[dev-checklist]: https://developers.home-assistant.io/docs/development_checklist/
[manifest-docs]: https://developers.home-assistant.io/docs/creating_integration_manifest/
[quality-scale]: https://developers.home-assistant.io/docs/integration_quality_scale_index/
[docs-repository]: https://github.com/home-assistant/home-assistant.io
[perfect-pr]: https://developers.home-assistant.io/docs/review-process/#creating-the-perfect-pr
tom_l
July 6, 2023, 4:22pm
104
Yeah I saw that. Just waiting for '7.1 now.
Cadster
(Cadster)
July 6, 2023, 5:22pm
105
I have got the same issue, my miscale does not work with esphome since my upgrade to 2023.7 docker.
My mi temp/hum sensors still work as are my miflora sensors. Until it’s fixed i go back to OpenMQTT Gateway wich simply works.
update:
miscale issue is solved by esphome 2023.6.5
@disforw … Thanks for the hard work you guys did for the QNAP … Awesome finally via UI
Upgrading 2023.6.4 → 2023.7.0 went rather smooth.
So far only one issue was observed - “Demo” platform causes errors & creates plenty of entities:
opened 06:24PM - 06 Jul 23 UTC
integration: demo
### The problem
I have 3 types of entities of Demo integration defined in y… aml:
cover:
- platform: demo
light:
- platform: demo
device_tracker:
- platform: demo
These is defined according to Docs (https://www.home-assistant.io/integrations/demo/).
After upgrading to 2023.7 these errors are present in Log:
2023-07-06 01:16:43.567 ERROR (MainThread) [homeassistant.components.light] The demo platform for the light integration does not support platform setup. Please remove it from your config.
2023-07-06 01:16:43.568 ERROR (MainThread) [homeassistant.components.cover] The demo platform for the cover integration does not support platform setup. Please remove it from your config.
On "Integrations" page a new entry was automatically added:
and plenty of demo entities were added too (for thermostat etc):
What I expect:
1. Only entities specified in yaml are added.
2. No errors in Log.
### What version of Home Assistant Core has the issue?
2023.7
### What was the last working version of Home Assistant Core?
_No response_
### What type of installation are you running?
Home Assistant Container
### Integration causing the issue
Demo
### Link to integration documentation on our website
### Diagnostics information
_No response_
### Example YAML snippet
_No response_
### Anything in the logs that might be useful for us?
_No response_
### Additional information
_No response_
Check out this issue:
opened 10:29AM - 30 Jun 23 UTC
### The problem
I have 5 ESP32's and about 8 to 10 temperature sensors. All of… them being either LYWSDCGQ or CGDK2.
The last update broke them all. They will only (might) report once after the ESP32 is restarted. They never report a second time.
### Which version of ESPHome has the issue?
2023.6.3
### What type of installation are you using?
Home Assistant Add-on
### Which version of Home Assistant has the issue?
2023.7.0b2
### What platform are you using?
ESP32
### Board
mhetesp32devkit
### Component causing the issue
xiaomi_lywsdcgq, xiaomi_cgdk2
```yaml
e.g. CGDK2
- platform: xiaomi_cgdk2
mac_address: "58:2D:34:12:BC:7C"
bindkey: "f6d5a0db976d1c758a23b24807e0ff2b"
temperature:
name: Server Room Temperature
humidity:
name: Server Room Humidity
battery_level:
name: Server Room Battery Level
e.g.LYWSDCGQ
- platform: xiaomi_lywsdcgq
mac_address: !secret mijia_ble_temperature_3
temperature:
name: "Master Bathroom Temperature"
device_class: "temperature"
state_class: "measurement"
humidity:
name: "Master Bathroom Humidity"
device_class: "humidity"
battery_level:
name: "Master Bathroom Temperature Sensor Battery Level"
```txt
here's the logs from one showing the issue, you'll see a single update from one of the 2 configured sensors, and nothing ever again.
INFO ESPHome 2023.6.3
INFO Reading configuration /config/esphome/master_closet_esp32.yaml...
WARNING 'master_closet_esp32': Using the '_' (underscore) character in the hostname is discouraged as it can cause problems with some DHCP and local name services. For more information, see https://esphome.io/guides/faq.html#why-shouldn-t-i-use-underscores-in-my-device-name
INFO Starting log output from master_closet_esp32.local using esphome API
INFO Successfully connected to master_closet_esp32.local
[06:11:47][I][app:102]: ESPHome version 2023.6.3 compiled on Jun 29 2023, 10:08:45
[06:11:47][C][wifi:543]: WiFi:
[06:11:47][C][wifi:379]: Local MAC: 84:CC:A8:5D:13:60
[06:11:47][C][wifi:380]: SSID: [redacted]
[06:11:47][C][wifi:381]: IP Address: 192.168.20.14
[06:11:47][C][wifi:383]: BSSID: [redacted]
[06:11:47][C][wifi:384]: Hostname: 'master_closet_esp32'
[06:11:47][C][wifi:386]: Signal strength: -69 dB ▂▄▆█
[06:11:47][C][wifi:390]: Channel: 11
[06:11:47][C][wifi:391]: Subnet: 255.255.255.0
[06:11:47][C][wifi:392]: Gateway: 192.168.20.1
[06:11:47][C][wifi:393]: DNS1: 192.168.20.1
[06:11:47][C][wifi:394]: DNS2: 0.0.0.0
[06:11:47][C][logger:301]: Logger:
[06:11:47][C][logger:302]: Level: DEBUG
[06:11:47][C][logger:303]: Log Baud Rate: 115200
[06:11:47][C][logger:305]: Hardware UART: UART0
[06:11:47][C][template.sensor:022]: Template Sensor 'Master Bathroom Temperature Sensor Number'
[06:11:47][C][template.sensor:022]: State Class: ''
[06:11:47][C][template.sensor:022]: Unit of Measurement: ''
[06:11:47][C][template.sensor:022]: Accuracy Decimals: 1
[06:11:47][C][template.sensor:023]: Update Interval: 86400.0s
[06:11:47][C][template.sensor:022]: Template Sensor 'Master Bedroom Temperature Sensor Number'
[06:11:47][C][uptime.sensor:031]: Uptime Sensor 'Master Bedroom ESP32 Ethernet Uptime'
[06:11:47][C][uptime.sensor:031]: Device Class: 'duration'
[06:11:47][C][uptime.sensor:031]: State Class: 'total_increasing'
[06:11:47][C][uptime.sensor:031]: Unit of Measurement: 's'
[06:11:47][C][uptime.sensor:031]: Accuracy Decimals: 0
[06:11:47][C][uptime.sensor:031]: Icon: 'mdi:timer-outline'
[06:11:47][C][template.sensor:022]: Template Sensor 'Master Bedroom ESP32 Free Memory'
[06:11:47][C][template.sensor:022]: State Class: 'measurement'
[06:11:47][C][template.sensor:022]: Unit of Measurement: 'B'
[06:11:47][C][template.sensor:023]: Update Interval: 60.0s
[06:11:47][C][bluetooth_proxy:088]: Bluetooth Proxy:
[06:11:47][C][bluetooth_proxy:089]: Active: YES
[06:11:47][C][restart:068]: Restart Switch 'Master Bedroom ESP32 Restart'
[06:11:47][C][restart:070]: Icon: 'mdi:restart'
[06:11:47][C][restart:091]: Restore Mode: always OFF
[06:11:47][C][xiaomi_lywsdcgq:012]: Xiaomi LYWSDCGQ
[06:11:47][C][xiaomi_lywsdcgq:013]: Temperature 'Master Bathroom Temperature'
[06:11:47][C][xiaomi_lywsdcgq:013]: Device Class: 'temperature'
[06:11:47][C][xiaomi_lywsdcgq:013]: State Class: 'measurement'
[06:11:47][C][xiaomi_lywsdcgq:013]: Unit of Measurement: '°C'
[06:11:47][C][xiaomi_lywsdcgq:013]: Accuracy Decimals: 1
[06:11:47][C][xiaomi_lywsdcgq:014]: Humidity 'Master Bathroom Humidity'
[06:11:47][C][xiaomi_lywsdcgq:014]: Device Class: 'humidity'
[06:11:47][C][xiaomi_lywsdcgq:014]: State Class: 'measurement'
[06:11:47][C][xiaomi_lywsdcgq:014]: Unit of Measurement: '%'
[06:11:47][C][xiaomi_lywsdcgq:014]: Accuracy Decimals: 1
[06:11:47][C][xiaomi_lywsdcgq:015]: Battery Level 'Master Bathroom Temperature Sensor Battery Level'
[06:11:47][C][xiaomi_lywsdcgq:015]: Device Class: 'battery'
[06:11:47][C][xiaomi_lywsdcgq:015]: State Class: 'measurement'
[06:11:47][C][xiaomi_lywsdcgq:015]: Unit of Measurement: '%'
[06:11:47][C][xiaomi_lywsdcgq:015]: Accuracy Decimals: 0
[06:11:47][C][xiaomi_lywsdcgq:013]: Temperature 'Master Bedroom Temperature'
[06:11:47][C][xiaomi_lywsdcgq:014]: Humidity 'Master Bedroom Humidity'
[06:11:47][C][xiaomi_lywsdcgq:015]: Battery Level 'Master Bedroom Temperature Sensor Battery Level'
[06:11:47][C][esp32_ble:238]: ESP32 BLE:
[06:11:47][C][esp32_ble:240]: MAC address: 84:CC:A8:5D:13:62
[06:11:47][C][esp32_ble:241]: IO Capability: none
[06:11:47][C][esp32_ble_tracker:590]: BLE Tracker:
[06:11:47][C][esp32_ble_tracker:591]: Scan Duration: 300 s
[06:11:47][C][esp32_ble_tracker:592]: Scan Interval: 320.0 ms
[06:11:47][C][esp32_ble_tracker:593]: Scan Window: 30.0 ms
[06:11:47][C][esp32_ble_tracker:594]: Scan Type: ACTIVE
[06:11:47][C][esp32_ble_tracker:595]: Continuous Scanning: True
[06:11:47][C][mdns:108]: mDNS:
[06:11:47][C][mdns:109]: Hostname: master_closet_esp32
[06:11:47][C][ota:093]: Over-The-Air Updates:
[06:11:47][C][ota:094]: Address: master_closet_esp32.local:3232
[06:11:47][C][api:138]: API Server:
[06:11:47][C][api:139]: Address: master_closet_esp32.local:6053
[06:11:47][C][api:143]: Using noise encryption: NO
[06:12:07][D][sensor:094]: 'Master Bedroom ESP32 Free Memory': Sending state 75108.00000 B with 1 decimals of accuracy
[06:12:08][D][sensor:094]: 'Master Bedroom ESP32 Ethernet Uptime': Sending state 72172.25000 s with 0 decimals of accuracy
[06:12:38][D][switch:012]: 'Master Bedroom ESP32 Restart' Turning ON.
[06:12:38][D][switch:055]: 'Master Bedroom ESP32 Restart': Sending state OFF
[06:12:38][I][restart:016]: Restarting device...
[06:12:38][I][app:134]: Rebooting safely...
INFO Processing expected disconnect from ESPHome API for master_closet_esp32.local
WARNING Disconnected from API
[06:12:46][C][esp32_ble_tracker:590]: BLE Tracker:
[06:12:46][C][esp32_ble_tracker:591]: Scan Duration: 300 s
[06:12:46][C][esp32_ble_tracker:592]: Scan Interval: 320.0 ms
[06:12:46][C][esp32_ble_tracker:593]: Scan Window: 30.0 ms
[06:12:46][C][esp32_ble_tracker:594]: Scan Type: ACTIVE
[06:12:46][C][esp32_ble_tracker:595]: Continuous Scanning: True
[06:12:46][C][mdns:108]: mDNS:
[06:12:46][C][mdns:109]: Hostname: master_closet_esp32
[06:12:46][C][ota:093]: Over-The-Air Updates:
[06:12:46][C][ota:094]: Address: master_closet_esp32.local:3232
[06:12:46][C][api:138]: API Server:
[06:12:46][C][api:139]: Address: master_closet_esp32.local:6053
[06:12:46][C][api:143]: Using noise encryption: NO
[06:12:47][D][xiaomi_ble:328]: Got Xiaomi LYWSDCGQ (58:2D:34:3A:C4:B9):
[06:12:47][D][xiaomi_ble:331]: Temperature: 23.0°C
[06:12:47][D][xiaomi_ble:334]: Humidity: 80.0%
[06:12:47][D][sensor:094]: 'Master Bathroom Temperature': Sending state 23.00000 °C with 1 decimals of accuracy
[06:12:47][D][sensor:094]: 'Master Bathroom Humidity': Sending state 80.00000 % with 1 decimals of accuracy
[06:12:49][D][api:102]: Accepted 192.168.1.134
[06:12:49][D][api.connection:1030]: Home Assistant 2023.7.0b2 (192.168.1.134): Connected successfully
[06:13:15][D][sensor:094]: 'Master Bedroom ESP32 Free Memory': Sending state 75484.00000 B with 1 decimals of accuracy
[06:13:36][D][sensor:094]: 'Master Bedroom ESP32 Ethernet Uptime': Sending state 55.94300 s with 0 decimals of accuracy
[06:14:15][D][sensor:094]: 'Master Bedroom ESP32 Free Memory': Sending state 75340.00000 B with 1 decimals of accuracy
[06:14:36][D][sensor:094]: 'Master Bedroom ESP32 Ethernet Uptime': Sending state 115.94000 s with 0 decimals of accuracy
[06:15:15][D][sensor:094]: 'Master Bedroom ESP32 Free Memory': Sending state 75500.00000 B with 1 decimals of accuracy
[06:15:36][D][sensor:094]: 'Master Bedroom ESP32 Ethernet Uptime': Sending state 175.94701 s with 0 decimals of accuracy
[06:16:15][D][sensor:094]: 'Master Bedroom ESP32 Free Memory': Sending state 75500.00000 B with 1 decimals of accuracy
[06:16:36][D][sensor:094]: 'Master Bedroom ESP32 Ethernet Uptime': Sending state 235.94701 s with 0 decimals of accuracy
[06:17:15][D][sensor:094]: 'Master Bedroom ESP32 Free Memory': Sending state 75368.00000 B with 1 decimals of accuracy
[06:17:36][D][sensor:094]: 'Master Bedroom ESP32 Ethernet Uptime': Sending state 295.94601 s with 0 decimals of accuracy
[06:17:40][I][ota:113]: Boot seems successful, resetting boot loop counter.
[06:17:40][D][esp32.preferences:114]: Saving 1 preferences to flash...
[06:17:40][D][esp32.preferences:143]: Saving 1 preferences to flash: 0 cached, 1 written, 0 failed
[06:17:40][D][esp32_ble_tracker:245]: Starting scan...
[06:18:15][D][sensor:094]: 'Master Bedroom ESP32 Free Memory': Sending state 75424.00000 B with 1 decimals of accuracy
[06:18:36][D][sensor:094]: 'Master Bedroom ESP32 Ethernet Uptime': Sending state 355.94000 s with 0 decimals of accuracy
[06:19:15][D][sensor:094]: 'Master Bedroom ESP32 Free Memory': Sending state 75424.00000 B with 1 decimals of accuracy
[06:19:36][D][sensor:094]: 'Master Bedroom ESP32 Ethernet Uptime': Sending state 415.94000 s with 0 decimals of accuracy
[06:20:15][D][sensor:094]: 'Master Bedroom ESP32 Free Memory': Sending state 75424.00000 B with 1 decimals of accuracy
[06:20:36][D][sensor:094]: 'Master Bedroom ESP32 Ethernet Uptime': Sending state 475.94000 s with 0 decimals of accuracy
[06:21:15][D][sensor:094]: 'Master Bedroom ESP32 Free Memory': Sending state 75424.00000 B with 1 decimals of accuracy
[06:21:36][D][sensor:094]: 'Master Bedroom ESP32 Ethernet Uptime': Sending state 535.94000 s with 0 decimals of accuracy
[06:22:15][D][sensor:094]: 'Master Bedroom ESP32 Free Memory': Sending state 75424.00000 B with 1 decimals of accuracy
[06:22:36][D][sensor:094]: 'Master Bedroom ESP32 Ethernet Uptime': Sending state 595.94299 s with 0 decimals of accuracy
[06:22:40][D][esp32_ble_tracker:245]: Starting scan...
[06:23:15][D][sensor:094]: 'Master Bedroom ESP32 Free Memory': Sending state 75424.00000 B with 1 decimals of accuracy
[06:23:36][D][sensor:094]: 'Master Bedroom ESP32 Ethernet Uptime': Sending state 655.94000 s with 0 decimals of accuracy
[06:24:15][D][sensor:094]: 'Master Bedroom ESP32 Free Memory': Sending state 75424.00000 B with 1 decimals of accuracy
[06:24:36][D][sensor:094]: 'Master Bedroom ESP32 Ethernet Uptime': Sending state 715.94397 s with 0 decimals of accuracy
[06:25:15][D][sensor:094]: 'Master Bedroom ESP32 Free Memory': Sending state 75424.00000 B with 1 decimals of accuracy
[06:25:36][D][sensor:094]: 'Master Bedroom ESP32 Ethernet Uptime': Sending state 775.94000 s with 0 decimals of accuracy
[06:26:15][D][sensor:094]: 'Master Bedroom ESP32 Free Memory': Sending state 75424.00000 B with 1 decimals of accuracy
[06:26:36][D][sensor:094]: 'Master Bedroom ESP32 Ethernet Uptime': Sending state 835.94202 s with 0 decimals of accuracy
[06:27:15][D][sensor:094]: 'Master Bedroom ESP32 Free Memory': Sending state 75424.00000 B with 1 decimals of accuracy
[06:27:36][D][sensor:094]: 'Master Bedroom ESP32 Ethernet Uptime': Sending state 895.94000 s with 0 decimals of accuracy
[06:27:40][D][esp32_ble_tracker:245]: Starting scan...
[06:28:15][D][sensor:094]: 'Master Bedroom ESP32 Free Memory': Sending state 75424.00000 B with 1 decimals of accuracy
[06:28:36][D][sensor:094]: 'Master Bedroom ESP32 Ethernet Uptime': Sending state 955.94000 s with 0 decimals of accuracy
_No response_
Seems that for now you can’t have both bluetooth_proxy and esp32_ble_tracker on the same device. At least removing the proxy setting from my device solved it for the Miscale.
Cadster
(Cadster)
July 6, 2023, 6:58pm
109
Thanks, will check if it also solves my issue. I didn’t read anyting in the breaking changes though.
It is rather a bug, not a breaking change
Bergtatt
(Anders Kvernberg)
July 6, 2023, 7:47pm
111
Great update!
Still unable to mount my SMB v.1.0 network share. Anyone else made it work?
Smb 1 ??? I think it’s time you update your storage :+)
GSzabados
(Gábor Szabados)
July 6, 2023, 8:25pm
113
How much time is it until it will be the latest/stable? As I see it is already released (about 2 hours ago), but the latest/stable still points to 7.0.
Flagun
(Marek)
July 6, 2023, 8:31pm
115
I have problems with Hyperion integration. I cant control my instances. The status in HA changes but not really.
nickrout
(Nick Rout)
July 6, 2023, 8:47pm
116
Yes it seems to be the case. Not sure whether it is a change in ha or esphome.
so other than creating that image in the /www folder, id love to be able to create the image template sensor in media, and not ip ban the instance when browsing locally.
can this really only be done using all kinds of reverse proxies etc to create a https connection when using the local ip address?
in which case writing that snapshot to the www folder might be the simple solution indeed…
although even that image does indeed not update upon rewrite of a new capture. The image file is overwritten to capture the latest shot, but the template image does Not update at all. As a matter of fact, I can only get it to update reloading the complete template config… not even a page reload/cache clear/refresh makes the last image appear
dinth
(Michal)
July 6, 2023, 9:34pm
120
Same problem here. Seems that the HA switch is switching on/off the effect not the light itself. Unfortunately i temporarily dont have access to my yubikeys and cannot login to GitHub to log an issue
This is weird as there’s no mention of any hyperion changes in the changelog, not to mention a breaking one.
Could you post the link to that issue? Would love to follow that
Updated to 2023.7 bumps resources usage:
Memory use (%)
Processor use (%)
updog
July 7, 2023, 2:54am
123
Where’s the changelog for 2023.7.1?
tom_l
July 7, 2023, 2:56am
124
